I had asked for some info about a ' DRYER " lock light coming on and nothing will now function. Not the washer. I've already replaced the control board.
  • 3,037 Answers
Can you please post the make and model number of the dryer in question. Thanks
Benjamin
Posted on Jul 27, 2009
All the function lights and pause lights flash
follow the steps and fix it. USE the VOM . God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
May 28, 2013 | Washing Machines
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Control locked
look on consoles for small lock emblem hold that button down 3-5 secs
Sep 01, 2008 | Whirlpool GHW9200L Front Load Washer
Whirlpool YGEW9250PW1 Electric dryer control locked problem
I had the same problem, but my husband, who is an engineer, figured out that if you pull out the light bulbs that are not reading the correct volts on his volt meter, the control lock light will shut off and the dryer will start working. If you do not know how to do this, you can always buy a new control panel. I know this sounds to simple to be true, but we have bought several new "brains" (control boards), tried unpluging the dryer for days at a time, had an certified whirpool technician come out (who recommended buying a new control board), and nothing worked.
Sep 01, 2008 | Whirlpool GEW9250 Electric Dryer
Washer stopped working
I think your mother board has gone hence none of the other lights are coming on.
If you get the help of a competent Washing Machine engineer they will solve your problem, without having to replace the whole machine.
Regards,
David
Jan 17, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Control lock stays on and nothing else works on the panel. No other lights, no other controls. Disconnected power overnite but nothing changed.
The sound button is the button that you wish the sound to go on when the load is finished drying. Thanks for the advice, I was worried I just bought them and already broken.
Nov 17, 2007 | Whirlpool GEW9250P Electric Dryer
Need to get to the back of the unit...
There are no locking mechanisms. There are two things to watch out for. The lower outer arms of the frame slide to the inside of the front washer panel, but are not attached other than by tension. Also, the brcket frame and the washer both have their own leveler feet. It is easily possible to raise the frame so tightly into the washer that it in effect has the washer sitting on it, making it almost imposible to slide out the washer. If necessary, lower the frame levelers to create a small gap all the way around between the lower frame arms and the washer. Note there are electrical control cables between the control panel and the washer that must be disconnected to pull it out.
Nov 07, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
