Question about Garden
My shindaiwa grass trimmer want start sometime when i cut it off why?
My shindaiwa grass trimmer run ok but when i cut it off sometime it don't want to start again but when i take the spark plug out and put it back in it will start i want to know why it want start until i take the spark plug out and put it back in what is cause it want start how do i fix this problem? i replace a new spark plug.
  • 12 Answers
SOURCE: Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Posted on Mar 21, 2009
  • 284 Answers
SOURCE: Home lite String Trimmer Won't Start
be sure your kill switch is set to run positon and the wires from it arent grounding theirself out . Make sure your spark plug is
grnded to metal when you check for spark.(ground to head away from the spark plug hole
You may have a bad ignition module if you still have no spark or the flywheel keyway has sheared for some reason throwing it out of timing.(removal of flywheel is required to see if the keyways are aligned flywheel and crankshaft)
If your flywheel seems tight then you may be ok
not a high failure rate but it has happened.Gap your plug at .030 then.025 see if that makes a difference? keep going to a smaller gap to show you may have a weak module not able to jump a wider gap.
just a couple things to check hope this helps maybe
Posted on Jun 01, 2009
  • 115 Answers
SOURCE: Ryobi 720r trimmer starts ok but stalls when the
The carburator needs to be adjusted a little, thin our your mixture screw when the trimmer is warmed up and idling. Well how do you get it to idle? I usually have to play with the choke lever with the throttle wide open going from choke to partial choke as needed to keep it running. Adjusting can be tricky, you need a small screwdriver. Screw all the way in then back out 3 to 3.5 turns. this should get you close. Adjust idle as needed.
Posted on Jul 06, 2009
woobie dog
  • 1273 Answers
SOURCE: My LawnBoy mower 195 cc 4 cycle that starts fine.
It sounds as though it is starved for fuel. Check the pinhole vent in the fuel filler cap. if it is plugged, the engine will still draw fuel, until a vacuum is pulled on the tank, resulting in no fuel. If this doesn't fix you. check for adequate fuel at the carb, and wirk either forward or backwards from that point, depending on what you find. I'm betting on the vent!
Try it; it may be just the thing!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
  • 342 Answers
SOURCE: My Craftsman 18.5HP Briggs and Stratton Engine
this sounds like an ignition timing issue check that the timing has moved causing it to fire at the wrong time
Posted on Apr 05, 2010
Trimmer runs but will not cut?
Is this gas or electric?
Sometimes if the trimmer cord is too long, the engine does not have enough power to spin it fast enough to allow it to cut.
Mar 19, 2015 | Garden
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
It starts and runs for a bit but as soon as it hits thicker grass it dies
Joe Hi there. Sadly your trimmer will struggle on thick grass as it's not made for it. You could try moving the trimmer like a scythe. This will aid it as your cutting bit by bit.
Sep 27, 2013 | Husqvarna 28cc Gas Line Trimmer
Echo trimmer srm230 runs but will not rev to cut grass
Check the spark arrester in the muffler out let is no blocked with carbon, remove the muffler and check the exhaust port itself is not carboned up.
Jun 03, 2012 | Echo Garden
I just got a grass hog trimmer that used to belong to my sister. The line is not feeding and I don't know how to restring.
The cap on the bottom pops off, and there is a spool in there. Sometimes the line melts to itself in spots and you just have to free it and if you feel you need to then you can cut some off.
I hope this helps you out.
Jul 27, 2011 | Black & Decker 14" Grass Hog Xp...
Strimmer starts ok but strimmer head does not spin fast enough to cut grass
It sounds like the square end in the handle has rounded some and let cable slip
May 01, 2010 | Homelite Mighty Lite Lawn Trimmer
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Ryobi 25cc grass timmer, cuts out when full throttle applied
Are you running a gas/oil mix? If you are try making sure you didnt add too much oil (will usually smoke) and will possibly stall. Your air fuel mixture may be off and need adjusting too.
Aug 17, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
