Operating manualbook - Computers & Internet
How to Create my Own Windows Based Operating System?
You cannot create your own Windows-based operating system because the windows is the operating system. In order to create an operating system for a computer you have to know a great deal of programming. For even a rudimentary operating system to have a Windows like environment it would take years of development and would not even be as effective as a windows 3.1, windows 95, windows 98 or Windows 2000 operating system. Linux has free operating system that you can install on a PC look up "Redhat" or "how to install Linux on a PC" this is a little involved but people have already done a lot of the work you are speaking about. The Linux operating system is a great operating system of you throughout the world.
Oct 19, 2016 | Computers & Internet
Where can i found a manual for the brother knitting machines kh 212
Well I found the manual for the KH210 (picture from that manual below), it may be similar but not sure.
https://app.box.com/shared/3g5d0rq9q7/2/73526225/657550011/1
is the site. If it doesn't come up, then start here
then click on Brother, then Knitting Machine and it is next to last on Page 2 of this section.
Hope this helps. As I did get to look at it, the carriage is set up very similar to their plastic KX350 machine, so the levers on the side will be the same but will be more sturdier than the plastic bed.
Sep 29, 2014 | Singer Deluxe Knitting Machine
998 manuals
try going on line and type in- fashion maker sewing machine 998- and see what you get. If you get a site then go to the workshop manual and download the pdf file.
Jul 29, 2013 | Sewing Machines
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
What is a E4 code mean
Error Code:
E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System
will shut down.
E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling
operation will be locked out. Fan operation can continue to operate.
E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
Pump operation will be locked out. Air Conditioner, Fan and Furnace operation
E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation
will be locked out. Furnace, heat strip, heat pump and fan mode of operation can
continue to operate but displays the last temperature set-poi
Dec 18, 2012 | Dometic 3313192.000 White Single Zone LCD...
What is the 5 types of operating system?
This are the Operating system types:
As computers have progressed and developed so have the operating systems. Below is a basic list of the different operating systems and a few examples of operating systems that fall into each of the categories. Many computer operating systems will fall into more than one of the below categories.
GUI - Short for Graphical User Interface, a GUI Operating System contains graphics and icons and is commonly navigated by using a computer mouse. See the GUI definition for a complete definition. Below are some examples of GUI Operating Systems.
System 7.x
Windows 98
Windows CE
Multi-user - A multi-user operating system allows for multiple users to use the same computer at the same time and different times.See the multi-user definition for a complete definition for a complete definition. Below are some examples of multi-user operating systems.
Linux
Unix
Windows 2000
Multiprocessing - An operating system capable of supporting and utilizing more than one computer processor. Below are some examples of multiprocessing operating systems.
Linux
Unix
Windows 2000
Multitasking - An operating system that is capable of allowing multiple software processes to run at the same time. Below are some examples of multitasking operating systems.
Unix
Windows 2000
Multithreading - Operating systems that allow different parts of a software program to run concurrently. Operating systems that would fall into this category are:
Linux
Unix
Windows 2000
Hope this information could help you to solve your problem. Mam/Sir don't forget me to rate me up I really appreciate what grade/ratings you will be given to me, it could help me lot to answer more questions especially in explaining in more detailed. Thanks a lot and God Bless.
Jun 27, 2011 | Computers & Internet
Toyota starletEP85,4E-F ENGINE manualBOOK wanted
Ebay there are four of these shop manuals, 27.00 and up
Oct 20, 2010 | 1984 Toyota Starlet
What are the heirarchy of operation?
The following information on "Hierarchy of Operations" was taken from Pages 45-46 of the "Microsoft QuickBasic 4.0: Basic Language Reference" manual for Versions 4.00 and 4.00b. This information also applies to the following products:
  1. Microsoft GW-Basic Versions 3.20, 3.22, and 3.23
  2. QuickBasic Versions 1.00, 1.01, 1.02, 2.00, 2.01, 3.00, 4.00, 4.00b, and 4.50
  3. Microsoft Basic Compiler Versions 5.35, 5.36, 6.00, and 6.00b
  4. Microsoft Basic PDS Version 7.00.
MORE INFORMATION The Basic operators have an order of precedence, that is, when several operation... loadTOCNode(1, 'moreinformation'); The Basic operators have an order of precedence, that is, when several operations take place within the same program statement (without being grouped by parentheses), some operations are executed before others. Operations are executed in the following order:
  1. Arithmetic operations
    1. Exponential (^)
    2. Negation (-)
    3. Multiplication and division (*, /)
    4. Integer division (\)
    5. Modula arithmetic (MOD)
    6. Addition and subtraction (+, -)
  2. Relational operations (=, >, <, <>, <=, >=)
  3. Logical operations
    1. NOT
    2. AND
    3. OR
    4. XOR
    5. EQV
    6. IMP
An exception to the order of operations listed above occurs when an expression has adjacent exponentiation and negation operators. In this case, the negation is done first. For example, the following statement prints the value .0625 (equivalent to 4^-2), not -16 (equivalent to -(4^2)): PRINT 4 ^ -2 If operators on the same precedence level appear in the same expression, they are computed from left to right.
For more information on the "Hierarchy of Operations," consult the Basic language reference manual for your version of Basic. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 13, 2010 | Microsoft Windows XP Professional
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
No Display on SDS2 Intel
yup, i am has a trouble same with bro ajay...cmos error beep : 1-5-1-1...
in manualbook, it is about fsb processor has error..but i dont know how to repair this probl...
anyone known?
thanks a lot all...
rickey in indonesia
Dec 14, 2007 | Intel Server Board SDS2 Motherboard
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
