Question about Simpson Washing Machines
Can my Simpson washing machine just spin? If I hand wash something I want to just spin not do a whole cycle.
  • Simpson Expert
  • 164 Answers
Yes but what model do you have? We can't see it.
Posted on Aug 17, 2017
  • 187 Answers
SOURCE: Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Posted on Jul 06, 2009
SOURCE: Simpson encore 806 washing machine beeping and screen showing DF
DF means the temperature sensor is faulty. Replace it. Get a new one from your Simpson agent. Turn power off. Open panel by removing the 3 screws at the rear of panel & swing it up. If you are standing behind the machine look on the left hand side at the top of the circuit board. You will see a small white plug with 3 wires (red-white-black) Very carefully pull this plug toward you off the 3 pin base. The other end is the sensor pushed into the water inlet chamber. Pull it out. Push new sensor into water chamber (make sure black rubber o-ring is on it) Push wiring plug back onto 3 pin base. It can only go on one way. Do not force it or twist it as the 3 pins can be easily broken or damaged. Then close panel & power up.
Posted on Aug 12, 2009
SOURCE: washing machine will not advance through the wash cycle
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
  • 1474 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
Changed lid lock on a 750 simpson ezyset washing machine.
most likely a problem program board not moving onto the next cycle and that is why the lid lock is still activated
Feb 08, 2016 | Simpson Washing Machines
My washes machine spins to slow then gets off balance an can I fix it ?
It may not be the clothes but the suspension springs and rods, counterweights etc
see pics
Jun 10, 2015 | Simpson Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
Try running the washer through rinse/spin cycle,then normal cycle without any detergent.
SF is suds failure,or too much detergent or wrong type of detergent.You need to use H E type detergent.
This should clear the machine out.
Apr 01, 2011 | Electrolux Washing Machines
I have a SIMPSON ENCORE 555 heavy duty washing machine. It will do a normal wash cycle, but when it comes to the spin cycle, it doesn't distribute the washing around the drum and hence won't spin. any...
Hi just read your posting.Now does the washing tangle around the agitator?In your posting you mentioned the washing not distributing around the drum.Could you confirm that your machine is a top loader for me,because the word "drum and distribute" are terms for a front loader.If your machine is a top loader which I think it is then the problem could be your brake arm or spin coil is not operating.Please reply and let me know if the clothes are tangling around the agitator.Looking forward to your reply.
Sep 07, 2010 | Washing Machines
Simpson Aquarius washing machine 7kg: water
Jan 08, 2010 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Andrew Taylor
Andrew Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
