The electrical power on rv goes out for a couple of seconds and then comes back on what would cause this
    Top Expert:
  • Heating & Co... Master
  • 48,349 Answers
Indicates an electrical contact ( relay ) is temporarily loosing circuit as in bad/loose ground
Posted on Aug 12, 2017
  • Mark Teresa Austin
    Mark Teresa Austin Aug 12, 2017
    That makes since there were 2 plugins in the box on the pole I switched to the other one and it hasn't went out again
  • Bill Boyd Aug 12, 2017
    not exactly where I was thinking but whatever works to fix the fault
5 Suggested Answers
SOURCE: tx-t2782 tv will not come back on
I tried unplugging and plugging again and again but no luck... the TV shows no signs of life.
Posted on Jan 08, 2009
  • 14 Answers
SOURCE: Protron TV, YHI power adapter goes off after a few seconds.
Sounds lika a bad power adapter. I've been repairing them for $60. Let me know if your interested.
Posted on May 28, 2009
SOURCE: monitors has power to it but goes off after a
your monitor is shot, get a new one. just happened to one of mine recently
Posted on Apr 13, 2010
  • 4399 Answers
SOURCE: when u are driving down the road u will lose all
Patty, you may need to check your fuses and make sure they all are properly pushed in. Does the car act different when it does this? I think you may have a loose wire somewhere in your wiring harness around the steering column. The only way to know for sure is by checking them.
Posted on Mar 08, 2011
Generac guardian rv generator starts and runs but after a couple minutes the power stops.....generator still runs??
Usually the generator will shut down if the ac is not present coming out of the generator. You stated that it still runs but no power on the output. Check your breakers first to make sure they are working properly. Depending on what board you have you can check to see if ac is present getting back to the board as well. If your board does not have this then they are using the frequency as a safety disconnect feature. That would lead you back to the regulator or loose connection or..dirty slip rings if this unit has brushes.
Oct 25, 2017 | Generac Electrical Supplies
We had a power surge from the campground electrical hookup. Now our usually quiet ac in the rv is running very noisy. What could cause this?
A power surge can trash the motor inside the compressor and the inside fan motor. Now comes the question will the repairs cost less than a whole new unit?
May 12, 2017 | Heating & Cooling
The green light on front of my HP computer comes on for a couple seconds and then it goes to red light blinking and beeping try to turn off and back on several times and go right back to blinking red
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 04, 2012 | Computers & Internet
The dryer is taking a couple of ctlces to dry items. I opened the door and depressed the button, so that the dryer would run while I was checking for heat. The heat comes on but then after a couple of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Mar 12, 2011 | Kenmore 72802 Gas Dryer
Yesterday I lost all electrical power while driving my 2004 Ford F450 RV. I continued rolling with the gas pedal pushed to the floor and without any power or control for approximately 10 seconds, suddenly...
this is one of those questions that we all dread and we would all be here goes...the most likely cause is going to be a faulty ignition swtch,you can still turn the wheels but no power as the engine thinks you have switched it off.this would never show up on any diagnostic computer........but as i say its just a guess.....and without replacing the switch, you will never know.....seems expensive,replacing bits on a whim.
Aug 14, 2010 | 2004 Ford Super Duty F 450
Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
Apr 11, 2010 | Thetford Norcold RV Cooler/Freezer
I have a durotherm air conditioner on my rv when i turn on the air conditioner the low voltage light comes on
Hi. I can help you. The voltage coming into your RV is determined by a few factors including the size of the power cord you use to bring power into your RV and the voltage available at the outlet. A voltage drop is common when there are lots of power draws occurring at the same time as is often the case in hot weather. You could ask your RV park manager to have the voltage checked as it can often be increased at the transformer on the nearby power pole.
That said for outside of your RV, lets go inside. If you are using a number of electrical appliances at once you may be causing the voltage drop. You can go to any home depot or similar store and purchase a voltage meter which will allow you to check and see what impact each item in your RV has on the voltage.
Jul 16, 2009 | Heating & Cooling
Laptop LCD Screen won't come on and computer keeps rebooting
Try checking the inverter, if that is intermittent, it could short the system and cause the symptoms you are describing.
Apr 03, 2009 | Gateway 7330GZ Notebook
Unit shuts off automatically after power on.
You have an internal short in the electrical line. your wall a/c [120 volts] goes inside and is converted [changed] to DC [ like a super battery] There are a lot of connections coming out of this POWER SUPPLY[super battery] to FEED other electrical circuit. ANY one of the circuits can demand more then power supply can give and will cause it to SHUT DOWN [turn off to protect itself]
unless u know what u are doing [" DANGER!! wILL rOBINSON, DANGER!!] you should not mess with it.
Jan 19, 2008 | Toshiba MD13M1 13 in. TV/DVD Combo
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
