I have Hermann smart 2000 receiver but I do not have the remote. how can I get it.
Hey guys am looking For a remote for hermann audio smart 2000 .any one no where i can find one
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
If you wish to get further advice over phone; visit https://www.6ya.com/.
Dec 26, 2016 | Televison & Video
My remotes won't work. Apparently the remote sensor is not working. This TV does not have a remote in plug on the back. Any ideas?
I have the same TV, but I don't understand what you mean about 'both remotes' or 'remote in plug on the back'. Do you mean a smart remote, the receiver for which connects via the USB?
The original remote uses the IR receiver on the TV. The smart remote only uses IR for the On/Off function; all other controls go via USB.
It is possible that the IR receiver in the TV has failed (I have replaced several on other devices). This is a cheap component, easily replaced by a competent solderer.
Jan 25, 2015 | LG 42LV5500 42 in. LCD TV
Vizio "Smart" TV not working
If the remote wasn't working you should be able to turn it on with the on button, is there any indicator lamps that light or flash or is it like its unplugged?
Nov 25, 2017 | Vizio xrt112 smart tv Remote control for...
Bose remote
  1. what is the Bose remote code to sinc to my Samsung smart TV.
Apr 16, 2014 | Bose PMCII 035323 LCD Remote Control
I have a Motorola "smart
Hi
The possible four digit remote universal remote codes for Motorola TV are:
0020 0003 0093, 0055
Three digit codea are: 003/ 173
OK.
Jul 10, 2011 | Motorola Televison & Video
We purchaed a new LCD tv and now our Dish Network receiver does not work with the remote. The Ttv works fine with te remote but not the receiver.
Hello Haley_cb, this is Cheri Torres with DISH Network customer service. I came across your post and wanted to see if I could be of some assistance. There are a few steps you can walk through to get your DISH remote addressed to your receiver again. First you want to make sure you DISH remote is in SAT mode, you can insure this by pressing the SAT button at the top left of your remote. If you have insured this, here are some instructions on how to address your DISH remote to your receiver again. If you have any further questions or concerns feel free to post back here or you can also email me at Cheri.Torres@Dishnetwork.com.
  1. Go to System Info scree. You can do this by pressing the system info button on the front of your DISH Network receiver box. Another way to get into the system info screen is by pressing the power button once and then the up arrow button once on the front of your receiver. If both options do not work you can try opening the smart card door on the left side of the receiver and pulling out the smart card.
  2. Once you are in the system info screen, hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
Dec 09, 2010 | DISH Network IR Remote Control
My dishnetwork remote control 1 doesn't work. It worked fine yesterday. There is no problem for the battery. When I want to change channel or press guide button, sat light is on but I don't see response...
    • All DISH Network IR remotes
1. Goto System Info screen. You can enter the system info screen by either pressingthe system info button on the front of the DISH receiver box or by pressing thepower button once then the up arrow on the front of the receiver. If theseoptions are unsuccessful you can also open the smart card door on the front leftside of the receiver and pull out the smart card. 2. Onceyou are on the system info screen, hold down the SAT button until all modelights light up. 3. Entera number between 1 and 15 using the numeric keypad on the remote. 4. Pressthe pound (#) button 5. Oncethe SAT button blinks three times, press record. Note: If successful the number selected in step 3 willappear in the System Info screen under Remote Address.
Nov 30, 2010 | DISH Network IR Remote Control
Locked out my 2000 S430
there is a mechanical key that slides out of your smart key. I beleive the release tab is at the base of the smart key. You can then put the mechanical key in the tumbler and unlock your vehicle.
Jun 20, 2009 | 2000 Mercedes-Benz S-Class
Need turn circle dimensions
curb to curb turning circle (mm): 5,304
Here is a link to all the other specs.
http://www.internetautoguide.com/car-specifications/09-int/2000/daewoo/nubira/index.html
Please rate this solution
Jan 16, 2009 | 2000 Daewoo Nubira
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
