Question about GE Computers & Internet
I have a digitech GE 4059 but have lost the instrucions and disc
Looking for a manual for a Digitech QM-1589 Sound Level Meter...
hi
I have mini sound level meter, I need to calibrate it. I lost my manual. it is Digitech QM - 1589. Pls help me to do that.
Sumudu
Sep 12, 2013 | Audio Players & Recorders
I need a manual for a Digitech dc-1005 walkie talkie
Hi Mitchell,
I own a Digitech DC1065 80 Ch CB HH, and no problems, so far.
Have you tried the Digitech website?
If so with no luck, may I suggest you join yahoo group specific to your radio Make/Model, there are experts with great info, plus you can download manuals, diagrams and software, etc.,,
I hope this is of help to you. (Ibought my DC1065 on ebay, no manual, but found the unit easy to work out, but I've got a bit of knowledge with radio equipment).
Cheers,
Peter
Jan 20, 2013 | Radio Communications
Cannot download software disc for a digitech usb cassette player #GE-4054
I have original disc, will swap for user manual.
langers8@yahoo.com.au
Aug 25, 2011 | Computers & Internet
I just purchaced a digitech usb cassete player recorder and the software provided is a small disc and wont work on my computer. Can I download the software from you. Thanks Wayne.
digitech is a very hard company to get software from, as they don't have a website. I have a digitech usb tv tuner, and could never find the sofware disc for it or the driver. Luckily I found the disc and could use it. The small disc should be supported by your computer as it is supported by all modern computers. Try borrowing/buying an external disc drive and use that. If it doesn't work then, the disc would be dodgy or broken and get it replaced by the place you bought it at. Would that be Jaycar Electronics?
Jun 05, 2011 | Audio Players & Recorders
Turntable GE-4059 How can I get the drivers for this turntable please Clarrie
You do not need a driver for Digitech turntable GE-4059 player. Just install the setup and play movies and music.
Good Luck!
Nov 18, 2010 | Computers & Internet
GE 15089 7-Day Digital Outlet Timer operating instrucions
GE-15089 timer manual
http://waterheatertimer.org/pdf/GE-15042-15079-15089.pdf
If you need more help with this timer, add a comment at bottom and I will help further
Oct 26, 2010 | Jasco Ge 7 Day Digital Timer 1 Outlet...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Computers & Internet Logo
91 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
