Question about The Office Equipment & Supplies
2000 Intrepid Repair Manual, where do I locate the sizes of the select fit bearings that is marked on the motor . I need it to get the prop. bearings for rebuild ?
I think they are letters to give you the size range that fits each bearing.
checkitright
  • 1362 Answers
SOURCE: Will not select legal paper when printing and faxing, letter only.
You have to go into the menu and change the setting to Legal.
here is the manual:
http://www.fixya.com/support/p202524-panasonic_panafax_uf_595_plain_paper/manual-7600/page-3
Posted on Oct 23, 2007
captainjeffq
  • 52 Answers
SOURCE: looking for prop spline size for stainless prop Yamaha 150 VMax
almost all splines should fit on that vmax, Ive owned one and used a few different props for different applications
Posted on Apr 13, 2009
  • 10865 Answers
SOURCE: Will the tire size 235/40/R18 fit on my 2000 Oldsmobile Alero?
Take your Alero to any reputable tire dealer and they will assist you in hopes of selling you something. Just tell them you want an estimate and that you want to be sure you won't have a rubbing problem with this change.
Posted on Apr 16, 2009
  • 47 Answers
SOURCE: Identification
appreciate you are trying to be accurate, but using original codes on worn crank maybe irrelevant, ideally you should use plastiguage (do a google search)
Posted on Aug 09, 2009
  • 39 Answers
SOURCE: Pisont ring sizes and bearings
they should be the same as factory if you haven't bored the engine but you could measure them and see
Posted on Dec 06, 2009
Where do you put antifreeze on 2002dodge intrepid
Terry, Add coolant to the reservoir located under hood, mounted by shock tower and fuse/relay center, fill to the full mark on side of coolant reservoir when cold, recheck after running and engine cold again. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Add Coolant Dodge Intrepid 1998 2004 2000 Dodge Intrepid ES 2 7L V6
Auto Repair Replace Engine Coolant Radiator Overflow Bottle Dodge Intrepid...
How to Remove Dodge Intrepid Radiator eHow
Jun 26, 2016 | Cars & Trucks
WHAT IS THE ENGINES MAIN BEARINGS PART NUMBERS
There are a few different sizes of bearings so a part number cannot be given.
In order to work out which bearing sizes will be needed you need to look at the code markings that are stamped onto your crankshaft and crankcases.
each bearing size is worked out from the combination of these two marks.At the very least you will require a manual to show you where each mark is and what sizes each combination means...
May 23, 2012 | 1996 kawasaki VN 1500 Vulcan Classic
Kawasaki main bearings part number
May 23, 2012 | kawasaki Motorcycles
I need to replace my a/c compressor on my 1999 Dodge Intrepid,the bearings are bad how can I fix it so I can still drive it without replacing a/c compressor?
Get a smaller serpentine belt that would fit the rest of the drive pulleys and not attach to the pulley on the clutch pulley of the AC compressor.Inquire at an auto parts store or Dodge dealer to find out what size of belt could be used on an Intrepid without AC,
Nov 09, 2011 | 1999 Dodge Intrepid
What motor fits a 2000 dodge intrepid
You have a 2000 and 2002 listed so the 2000 had options for a 2.7, 3.2, and 3.5 liter 6 cylinder engines the 2002 had a 2.7 and several variations of the 3.5 motor
Feb 22, 2011 | 2002 Dodge Intrepid
I bought a 2000 intrepid for a parts car, but after buying and realizing it was a nice car, I decided to fix the knock in the motor(2.7) After putting two rod bearings in it and putting it back together,...
What do you mean, put in 2 bearings? did you measure the crank? bearing clearances? what do you mean by wont start? wont crank? cranks but wont run?
Nov 12, 2010 | 2000 Dodge Intrepid
Need a repair manual for a 2000 dodge intrepid
There are two online sites who deals in repair service manual for Dodge interpid 2000 model. Check both the sites by clicking on it directly. the online site number one:--- http://www.tradebit.com/filedetail.php/105494890-2000-dodge-intrepid-service-repair-manual-download ----------------- The online site number two:--- http://www.car-stuff.com/mmparts/dodge-intrepid/repair_manual.html ------------------- Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Aug 16, 2010 | Dodge Intrepid Cars & Trucks
How do chamge the belts 2002 intrepid 3.6 motor
diagram should be under hood or in manual, also should have location of tensioner, all that is needed is the proper size wrench
Mar 22, 2010 | 2002 Dodge Intrepid
Looking for prop spline size for stainless prop Yamaha 150 VMax
Apr 12, 2009 | Boating
THERMOSTAT PICTUREDIAGRAM OF 1999 DODGE INTREPID, 2.7 ENGINE SIZE
It is located on the left side of the engine down where the lower rad hose meets the engine block. It is fairly difficult to change.
Oct 02, 2008 | 1999 Dodge Intrepid
32 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
