Question about LG Televison & Video
Lg tv fades and then blacks out power off nd on temp fix
3 Suggested Answers
  • 195 Answers
SOURCE: LG LCD TV screen slowly fades to black from one corner to full screen
that is not for DIY it have a problem on lens..
Posted on Jun 25, 2012
  • 75017 Answers
SOURCE: LED TV screen has flickered momentarily and faded to black. I have sound and power buttons light up. LED solid black, not lit. Bad LED Driver board?
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Jul 16, 2016
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: and follow the steps how to repair back light LEDs: Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have the LG Plasma model 50PA550. the TV turns on for a few seconds, then turns off by its self. The more I continue to turn on the TV the quicker it turns back off (until it just doesnt click on anymore...
If you're an electronics DIY...I had the same problem, TV turns on then immediately turns off. Fixed it with an 89 cent capacitor. TV is an LG 50PA5500, two and a half years old. Suddenly stopped working...would switch it on and it would immediately turn off. Sometimes if I left it unplugged for a while and plugged it back in, then it would click at intervals of 1 & 5 seconds repeatedly.
Inspection of the main power board showed C802, a black rectangular film capacitor at the top of the board between the transformer and heatsksink was bulging at the sides. Found the part, 0.022uF 1.25KVDC, on DigiKey (p/n 495-1360-ND) for $0.89 + ~$3 shipping (much cheaper & more reliable than eBay!). Replaced, TV working like new again.
Sep 12, 2013 | LG 50PA5500
Toshiba TheaterView fades to black after turning it on. Sometimes it seems to work fine. This has started 2 days ago and is getting worse. I shut it off for a few minutes then it is fine. It either...
There is a possible poor connection of component in your TV or poor solder or that would be the result of Power IC which is already a technician to fix the poor solder and or replace the IC that cause the problem
Sep 19, 2011 | Televison & Video
The lcd tv (lg 42LG5000) which is now about 15 months old has developed a fault which is intermittent some times when first switched on sometimes after half an hour an hour the left side of the screen...
The backlight inverter is dropping out, on the older lgs the backlight inverter is separate from the power supply, if this is the case you can only obtain it with a new panel.
otherwise the newer lgs have the inverter built on the power supply.
in this case you can replace the entire power board.
May 20, 2010 | Televison & Video
I have an lg imei:359131034362780 nd i put in the
call to costumer care of sim. and they will tell you puk code. dnt fill wrong code more than two times. otherwise your sim will be blocked.
May 02, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Just bought a lg cookie and i put my memory card in and wont how?
try to format it if their is no data in it nd then by pc transfer data in it songs ,mp3,themes,videos...nd enjy it....
Aug 29, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Televison & Video Logo
27 people viewed this question
Computer Repairing
Computer Repairing
