Where are you seeing this green fluid?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: Dometic Rooftop RV Air conditioner
why is our dometic roof top a/c on our boat draining water back into boat. is there a way to clean the drain?
SOURCE: problem with rooftop air conditioner duo therm brisk air box kit
Try having a professional check that the collant lines have not perished. Also have them check the thermostat and that there is actually gas in the system. The warm air suggests that the unit has no gas.
SOURCE: Dometic air conditioner
1The air coditioner does run on Electric. 110V 2. No you do not have to unhook the battery 3. Yes you need to put water in the hot water heater so you do not burn the unit up.
SOURCE: How to put refrigerant in Demotic RV Rooftop Air Conditioner
You will need to add a self tapping port to the suction side of the unit. You will have to determine what the size of the pipe is and then go to a local a/c supply company and buy one. It's kind of like a self tapping supply for water but for high pressure. Hope this helps. I would also put one in on the high side as well so you don't blow the valve in the compressor if you over charge it or the system is dirty.
SOURCE: How can we tell if our dometic rooftop air
Hi; If You have a heat pump then yes on heat strips. Does Your RV have a gas heater. If You gently remove the cover some times You can see the heat coils in the metal air flow tube...Also does the compressor run in heat mode ,if not then best guess You have heat strip capability...alpharome416
