Question about The Computers & Internet
My arus wants a username and password for the camera I just installed and I never set one up? Now it won't let me view or connect! What's up with this ?
2 Suggested Answers
drdarklord
  • 98 Answers
SOURCE: my internet won,t connect saying user name and
i am not sure what king of network you may have.. if you have DSL make sure that you have a DSL filter on the phone jacks, next make sure that the router or DSL is seeing green lights called DSL / Power / Ethernet is more likely standing light, next you will see green light flashing / that called Internet.
and rule number one make sure that your user name and password is right. make sure that there no space or some thing that should not be in the password or user name.. if you need more help i am glade to help you more out
Posted on Jun 23, 2010
Deracam will not reset. How do I get it to reset?
If you want to reset your IP Camera to factory defaults, you can use the following 3 methods. After resetting the device you will lose all your settings except Client Settings.
Method 1:Hard reset/ By pressing the RESET button
Step 1- Keep the device powered on for at least 30 seconds to complete its normal startup.
Step 2- Find something like a pin to press the Reset button on the camera and hold it for 15 seconds to restore the settings to factory defaults.
Step 3- Afterwards release Reset button, and the camera will be restored to factory defaults after rebooting.
Note: Reboot process takes about 1 min, please be patient.
Method 2:By using Intelligent IP Installer
Step 1- Install the Intelligent IP Installer with the CD.
Step 2- Run the Intelligent IP Installer. Click Search to find your device.
Step 3- Select your Camera in UPnP device list, click Factory default on the right side.
Step 4- Type the username and password in the login page, the default username and password are both admin. Wait for the device to reboot.
If you changed the username and password before and forgot the username and password, you have to follow
Method 1, make a hard reset.
Method 3:By using Web-based Utility (management page)
Step 1- Open the web browser and type the IP address of the IP Camera into the address bar, press Enter. If you have changed the default port number is 80, Then type the IP address of the camera: new port number into the address bar of web browser.
Step 2- Type the username and password in the login page, the default username and password are both admin. Then click OK to connect to the device.
Step 3- Click SETTING -> BASIC -> Initialize on the left side, and then click Factory default to reset this IP Camera to the factory default settings.
Step 4- Keep waiting until the progress bar shows completion.
Feb 04, 2018 | Miscellaneous
How do I set up remote live viewing on my I pad
you will need a compatible application(iCamViewer) to connect it to your camera or camera server for iPad and that allows you to configure streams and IP settings as as well as your username and password to access the camera.
If you are using static internal IP address so you have to do Port Forwarding Setup.
more technical help http://www.cctvcamerapros.com/iCamviewer-iPhone-App-Setup-Instructions-s/393.htmand router configuration http://www.techsupportrouter.com/support-for-d-link-router.html for your CCTV routers
May 07, 2014 | Computers & Internet
Cannot send emails. Message - connection error(rvermilya@neo.rr.com)
  1. Tap the Home icon
  2. Tap the Grid icon so you can view all installed applications
  3. Tap the Email icon
  4. Enter your Email Address and Password for the account you are setting up and tap Next
  5. Select the type of account: POP3, IMAP, Microsoft Exchange ActiveSync; select either POP3 or IMAP, as appropriate
  6. Enter the Incoming server settings: Username, Password, POP3 server (ex: pop.yourdomiain.com), Port, Security type, and Delete email from server, then tap Done, and then Next
  7. Enter the Outgoing server settings: SMTP server (ex: smtp.yourdomain.com), Port, Security type, Require sign-in (check box), Username, and Password, then tap Done, and then Next
  8. You can now select Account options: Email checking frequency (15 minutes by default), Send email from this account by default (check box), and Notify me when email arrives (checkbox) -- make your selections and tap Next
  9. Your email account is now set up on your Samsung Galaxy Tab and must be named -- also be sure to enter your name to be displayed on outgoing messages
Once completed, the Samsung Galaxy Tab will connect to the account and begin retrieving your email. While viewing the message list, you are also able to change the settings that are assigned to this account by tapping the Menu icon -- which is directly to the left of the Home icon -- and then tapping Account settings.
Sep 12, 2012 | Samsung Galaxy Tab 10.1-Inch, 16GB, Wi-Fi
Just installed my wrt120n linsys router, it succesfully was installed in my desk computer,but I accidentally skiped the "Learn about connecting other computers" step, and now only this computer...
Did you set a username and password for the router. If you did go to your computer and make sure your wifi is turned on. If they are turned on then go to the name of the router that said linksys and try to connect to the router using the username and password. If you didn't set a username and password then it should just connect. If you don't remember your username and password then on the back of the router there will be a reset button hold down for 1 min to be safe and start from the beginning but your wifi signal should be working without a password
Jun 24, 2011 | Linksys WRT120N Router
Hi, I am posting all the steps which I did to connect my Micromax Q5 phone with my PC for Aircel Internet. In my Q5 phone: Menu -> Settings -> Connectivity -> Data Conn....
You gave a detailed information of your issue. You have not done any mistake. The problem is with Aircel. With prepaid card you cannot browse from your PC. If you are using postpaid Aircel, you can browse from PC.
Suggestion: You can use Docomo, Airtel to browse from PC.
Cheers...!!! Mr.Maduraikaran.
Mar 18, 2010 | Goko Camera Ltd Macromax FR-350 35mm Point...
My belkin n mimo wirelss router won install
You really don't need the cd to install the router - if you connect the router to your PC with an ethernet RJ45 cable, this should give you access to your LAN & the internet. You can then access your router to set up your wireless connectivity.
To access your router open your web browser & in the address bar, type 192.168.2.1 - you might be asked for a username & password - for username: admin password: leave blank or if this does not work type : admin for password
Mar 24, 2009 | Belkin Computers & Internet
Zyxel 600 security
Open a web browser like internet explorer or firefox. Enter the ip address of your router in the address bar of your browser. By default the ip address should be set to 192.168.1.1. You should see a box prompting you for your username and password.
Enter your username and password now. By default the username is admin, and the password is 1234. Click the Ok button to log in to your router
Click on wireless setup and you should have options there to change the security settings and setup a WEP key(password).
once you do this.
click on start
click on run
type ncpa.cpl
right-click wireless local area connection
click on view available wireless networks
and connect to your network again using the new password that you have just setup
Feb 20, 2009 | Zyxel Prestige 600WH Wireless Router...
ROUTER INSTALLATION AND CONFIGURATION
connect existing modem to the router
reset router (located at the back)
connect computer to one of the 4 ports of the router
run internet connection wizard & choose "computer is connected to a gateway / internet connection is always ON"
for wireless:
connect a computer to the router hard-wired
for your router, open a browser and access 192.168.1.1
leave it blank for the username and admin for the password field
click wireless tab, change the Wireless Network Name (SSID):
click save settings
next click Security Mode: and choose WPA2 Personal
make a password in the WPA Shared Key: field
click save settings
on the computer, go to view available wireless network & click the wireless network name you made, connect, enter password when prompted.
good to go
Jan 24, 2009 | Linksys Wireless-G Broadband Router
A network error occurred while connecting to server
See section B. Yahoo Messenger in info below.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Nov 15, 2008 | Labtec 961307-0914 Webcam
Modem/router
You need to call your INTERNET SERVICE PROVIDER. You need a USERNAME and PASSWORD from your ISP when you set your modem to bridge. This username and password will serve as your connection authentication. Once the modem is already bridged you have to set the INTERNET CONNECTION TYPE on the router to PPPOe(that is where you type your USERNAME and PASSWORD). When you are already online, you might need to forward the port number for your ip camera for it to work.
Good Luck
Mar 11, 2008 | Computers & Internet
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
