Remove barcode on existing label from which I want to use only text
3 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: barcodes - removed from top of lable
right click onthe barcode adn select none in the popup
if this help you solved you problem, please give me a FIXYA rating.
thanks
Posted on Dec 18, 2008
SOURCE: The scanner will not recognize a bad barcode. the
There are many factors that can make a barcode a "bad" barcode. Moving the barcode closer or farther from the scanner won't solve many of the attributes that make a barcode "bad". It may have a wrong check digit. It may be the wrong type of symbol, or the scanner may not be programmed to see this type of symbol. It may be printed in a color the scanner has difficulty seeing. The substrate or the bars may be too reflective. The scanner may be at the wrong angle (not just distance) from the barcode. Most scanners need to see the barcoce at about 60 degrees--90 degrees is always a problem.
Can you email me a pdf of the barcode? I may be able to identify the problem from that.
Posted on Jun 17, 2009
Barcode Print aliginment is not proper in windows7
Try a different print driver. Go to Zebra web site and download driver for Windows 7'
Apr 22, 2014 | Zebra Office Equipment & Supplies
We're using 4.00 X 2.00 inch labels. The barcode is printing just under an inch long when it should be about 2 inches long so our scanners cannot read the barcodes. The text is printing out the
in some barcode software you can see the preview. if you click on the barcode itself maybe you can stretch it out to fit better. or try swapping to 2 by 4 format and see if that works. good luck
Aug 12, 2017 | Zebra ZM400 Thermal Label Printer -...
What is a label maker used for?
Label makers are used to develop the text design to print on labels.
For eg, in retail industries, they make labels(stickers) for printing Price tags along with item description and barcodes.
Label makers is a software which enables the user to frame their text position, fonts, description etc..! with which they their desired design in labels via a label printer.
hope we made u clear.
if you need info on label makers.
please see our site www.trridevlabelss.com
Jan 24, 2013 | Office Equipment & Supplies
How to print label on b-sx4 label printer
You must use the option send file to printer in the seagull driver not print else it is converted to graphics and sent to the printer.
May 16, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
Cannot print graphics accurately. Barcode and text
Problem with your software.
Tec do have instructions for printing diagonals.
Your software must be sending graphics with grey pixels.
Nov 03, 2010 | Toshiba TEC B-472 Thermal Label Printer
I have godex 1100 barcode printer which is not working. It doesn't print barcode. it responds the print command from the computer and tries to print but halt immidiately blinking status light. It gives...
You did not tell us, whether it is not printing barcode's alone or no text is printing.
You might hear beeps for 2 reasons, Sensor posistion is not correct. or ribbon is not correctly fitted.
Kindly check both these. hope this will solve your problems.
If you have any other queries with barcode printer kindly mail/call us.
Regards Trridev Labelss Mfg Co Web Marketing Division www.trridevlabelss.com email Kirubakaran.rv@gmail.com trridevlabelss@gmail.com
Manufactures of Self adhesive labels and resellers of barcode printers and scanners and ribbons
Sep 14, 2010 | Argox X-2000+ Thermal Label Printer
Zebra 105SE printer will print text and images just fine, but will not print bar codes from any software including Bartender or TechnoRiverStudio. If i export the label as an image I can print it just...
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Apr 17, 2010 | Zebra 105Se Thermal Printer
Currently have a TLP2742 duplicator which prints barcode and text. Need to alter this to just print the text. how do i do it?
Do you know if you are using a label software program to design the label or just ZPL (which is Zebra Programming Language) code direct to the printer? If it is software, then you can open that label design software file and remove the barcode. If it is ZPL, then you need to remove it from the code. I can help with this if you can email me the code.
hilster1968@gmail.com
Jun 26, 2009 | Zebra Eltron TLP 2742 Thermal Label...
Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Feb 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
k24674
jasbo
jasbo
