Can you hook up an N technology tv with ac technology modem and wireless router
    Diehard:
    Visited the website for 60 consecutive days.
  • Computers & ... Master
  • 696 Answers
Should be backwards compatiable. may run at n speed
Posted on Aug 12, 2017
cyrylthewolf
  • 143 Answers
SOURCE: hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Posted on Nov 11, 2007
Eddie333
  • 176 Answers
SOURCE: can't get a wireless router to work with a speedstream 4200
From the telephone outlet the dsl line (telephone line) connects to the dsl jack of the Speedstrem 4200 DSL Modem.
From the modems open port you connect one Cat5 network cable into the port (in back) of the Belkin N Wireless router.
For wireless internet connection to begin you must also do a wireless set-up on the software side of the Belkin router or through their web interface.
Posted on Jan 05, 2009
dante777
  • 623 Answers
SOURCE: how do you hook up your netgear wireless router to
Hi Leon,
have alook at Clearwire's webpage (here), where they describe different setups for your router.
I personally would always prefer to connect the modem to the router via a cable. The cable you will need is an Ethernet (CAT5) cable and the connectors at the end look like this (compared to a phone cable:
You will connect the output of your modem with the WAN port of your router. This port is usually separated form the 4 other LAN ports, which connect to your computers, printers, etc.
(You didn't specify which router model you have, so I can't give you more details, but it should be very obvious, when you look at the back of your router.)
For the initial setup of your router, you should use a second Ethernet cable connected to one of the LAN ports of the router and to the Ethernet port of your computer.
If you need help with the wireless setup of your router, you have to look either in your manual of give me the details of your router (like the model and version, i.e. Netgear WGR614) and I'm happy to assist you.
Posted on Feb 25, 2009
cnavarro
  • 2460 Answers
SOURCE: How to get wi fi at home for itouch?
Your better bet is a wireless access point. It plugs into your router and can be configured to be transparent to the network so that any IP address you get for your wireless device comes from the original router (better for networking).
At the blinkingly fast speeds of your Wireless internet, "N" is a waste. Get the "G". Here's a link to the product I would use...it runs about $50. http://www.tplink.com/products/product_des.asp?id=116
Carl
Posted on Feb 27, 2009
  • 154 Answers
SOURCE: 2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Posted on Apr 24, 2009
My landline is hook up to ciso an thats hook up to netgear how do i make calls out
If it's a cable modem you should have your phone landline connected to the cable model, if you have a "bundle". TV, Broadband, Phone with your provider. For example: I have Comcast/Xfinity bundle, TV, Phone, High Speed Internet. At the Comcast Modem it has a Phone jack RJ-11 for landline and Fax and a RJ-45 for my Wireless Access Point and Ethernet cable.
Jan 18, 2013 | NetGear WGR614 Wireless Router
Iphone 4s won't connect to wireless network
Hi Darren
What type of wireless signal does your new WiFi router support?
I'm guessing you got a new wireless ac router?
The initial run of the ac devices didn't support the older types of wireless signal (b,g,n).
However some of the newer I am fairly certain do.
Either way, the limitation is likely that iPhone 4s supports only up to n and only the 2.4Ghz version of n (not the 5Ghz version).
So Yes, assuming that's the problem, then going back to the wireless g router will fix the problem
However, if your new wireless router/modem does support the other wireless standards it could be that ac is the only signal type turned on. Or if it's NOT an ac device then it may be that the n signal is set to 5Ghz and not 2.4Ghz.
To find out you can typically login to a router/modem through a browser of a device connected to the network it's providing. Then try going to http://192.168.0.1/
If that's the correct address you'll see an interface to manage the router (you may have to login... not something anyone here can help with). If that address doesn't work here are a few more to try:
http://192.168.1.1/
http://10.0.0.1/
Good luck
You can see the specs for the phone here: https://support.apple.com/kb/sp643?locale=en_US
Jan 19, 2018 | D-Link Xtreme N DIR-655 Wireless Router
I JUST BOUGHT THE D-LINK DIR-615 (N300) _ WIRELESS ROUTER, IT TELLS ME TO HOOK UP TO MY MODEM BUT I DO NOT HAVE A MODEM, I HAVE DSL BUT IT IS RUN FROM THE OUTSIDE BOX ALONG WITH MY TV AND PHONE, MY DSL...
The router needs to have a modem to run off from, Even DSL provides modems if you do not have a modem then your DSL ISP (Internet Service Provider) did not provide you with one. I would suggest to follow the ethernet cord and see where it plugs into. You will need a modem to use a router.
Feb 18, 2011 | D-Link DIR-615 Wireless Router
Connecting My Cable TV Modem To Wireless Router
yes you can. you simply plug the modem into the input port on the wireless router and then plug which ever device you want to hardwire into the back of the wireless router. that's all :)
Nov 16, 2009 | Computers & Internet
Please excuse my very limited knowledge of wireless connectivity! I currently have Juno DSL, with a 2wire modem (2071 - no wifi) and I want to add wifi capabilities to my house. I assume that I need a...
As I understand it, you currently have a DSL line with a computer plugged into a modem that is attached to the DSL. Now, you want to use wireless throughout your home.
My choice of router manufacturer is Linksys though there are other manufacturers of wireless technology.
What ever manufacturer you choose, get the device. Hook it up according to the instructions you will find inside the device box.
It will go something like this: Attach a cat 5 cable from the "uplink" port on your router to the DSL modem. Plug your wired computer into any of the 4 other ports. Everything is off, right? Cycle the modem - wait for the lights to settle down. Plug in your new wireless, wait for the lights to settle. Turn on your computer. Turn on your wireless. Wou may have to connect using the windows wizard.
A tool I use for network management is Network Magic, a Cisco product. Cisco also owns LlinkSys.
Get the program, free download and eval period. After the eval period you may purchase or continue to use the product with some features disabled.
http://www.purenetworks.com/download/
Thanks for posting your question at FixYa.com
Please vote
thanks
a
Nov 13, 2009 | Computers & Internet
I have a cable modem that I know works since I'm connected to it directly right now. I'm trying to hook it up to an older Linksys wireless router and it is not recognizing it even after I reset it. The...
I use the same wireless G router that you have pictured. If you reset the router with the small reset button the security should be removed. If your laptop does not find the SSID which should be just LINKSYS after a reset make shure your technologys are the same. Is the wireless adapter on your laptop a G also? If you are using a N technology on your laptop it may not connect to or even see the G SSID
Aug 31, 2009 | Linksys Wireless-G Broadband Router
Just moved
You need to hook up the AC power supply to your router, hook up your cable modem to your router, there should be a specific port on your router, most likely yellow in color, you'll hook the modem to the router using the supplied ethernet cable, it looks like a big phone cord.
Apr 21, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have problem? how can we connect router in
- Check physical connection (Connect the modem to the WAN or Internet then hook one of the computer to the LAN connection.
- Open a browser then access the configuration page of the router.
- Under on tools create user ID and password.
Another is:
- Open the wireless settings under setup.
- Change the wireless network name/ SSID and set the encryption or security to WEP or WPA.
- Check the wireless network connection if you can log in with the wireless network name/ SSID with the password.
^_^
Feb 18, 2009 | Blitzz Technology (BWA611) Router
Want to hook laptop up to home computer via cable modem
You need a router or a wireless router to do that.
If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Nov 19, 2008 | Computers & Internet
Blitzz BWA611 Router
a router shouldnt need to dial for a connection, go to open your internet browser and go to tools, then internet options, then click connections tab and select never dial a connection so as to stop internet explorer looking for a modem connection
Aug 30, 2007 | Blitzz Technology (BWA611) Router
Computers & Internet Logo
David Payne
David Payne
