Our J1045IW1/XSA is producing error 3E. How do I access service mode on this unit, and how to I get access to the drum motor? this unit has a solid back with no removable panel.
SOURCE: paper jam alarm in, but there is no jam.
try to reset the printer or turn it off for 1min and then back on. That should work.
Posted on Dec 08, 2008
  • 382 Answers
SOURCE: How to put a belt on a Maytag DE 410 dryer
with some you have to remove the front upper and bottom panel
then lift drum off bogie wheels and move it ahead a few inches then loop it over the drum and around the belt tensioner pulley most swing up and down so thatyou can put belt on
Posted on Dec 19, 2009
  • 11 Answers
SOURCE: HOW TO REMOVE FRONT CONTROL PANEL IN ECOQUEST AIR PURIFIER
behind the front panel fingerboard on each side there is a screw hidden. You have to very slightly and gently with a fine bladed knife pry up those left and right sides to expose the screw. Its a thin piece of plastic covering the screen. Be very careful because there are electronics imbedded in the fingerpad that you are prying up. Gently lift the sticky covering only enough to get to the screws. It can be done but be careful.
Posted on Apr 29, 2010
  • 903 Answers
SOURCE: aficio copier 450 error sc 440
If you already replaced the main motor/drum motor and the error is still there (I'm guessing you shut the machine off and turned it back on, right?) there is probably an overload problem somewhere. If you know how to get into service mode, can you run the motor in the output check (5804)? Is there any kind of noise?
I think the 450 comes with two flywheels on the drum motor for stability -- try removing one of the flywheels to lighten the load and see if that makes a difference.
Posted on May 27, 2010
heatman101
  • 43501 Answers
SOURCE: My Asko T731 dryer frequently does not have enough
Hi, Yes, you are right about the motor/cap. replacing that can be a bugger but you can do it just dive in a go to town... There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 18, 2010
My machine leader stoped it give me a number 3E WHAT THAT MEAN
This video will help you diagnose the fault on your samsung 3e error codes and the video will help you solve the problem
Mar 08, 2013 | Washing Machines
3E error during rinse cycle on Amana NFW7200TW washer
E3 Error: Machine control is attempting to drive the motor but is not seeing any tach response. Visual check shows motor is not moving. (Locked, Hall Sensor fault). The hall sensor is a circuit in the motor. the motor will need to be replaced. Here is a link to the motor.
Oct 18, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
Service manual for Samsung washer J1045
Go to the Samsung website & put in your model number. I have the same machine. http://www.samsung.com/au/support/model/J1045IW1/XSA
Jun 05, 2012 | Washing Machines
Error code 3E says Power 81W OFF so what is this? What do I do?
Error code 3E means high currrent detected. Is anything blocking the drum or motor from turning.
Jan 17, 2011 | Samsung WF328AAW Front Load Washer
Made funny sound , finished load ok. 3E error on next run. is there something i can do myself to remedy the problem
3E error means =overcurrent detected at the motor.
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Open the control panel, there should be a tech sheet in there that explains how to put the machine into service mode (press chime and extra rinse keys for three seconds) and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes... and lots of other stuff that'll help you track this down.
You can also check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Pin #1 and Pin #2 of CN9 == 11.6 ohms
Pin #1 and Pin #3 of CN9 == 11.6 ohms
Pin #2 and Pin #3 of CN9 == 11.6 ohms
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Apr 21, 2010 | Maytag MAH2400 High Efficiency Front Load...
Error code 3e on the maytag washer wah8700awn
I did some researching on you problem and came up with the following:
3E means: Overcurrent detected at the motor.
You can also go ahead and check out the windings on the motor. Unplug harness connector and test from wire insertion side.
Good Luck,
I hope this helps,
Please Rate me,
Thank You
Dec 04, 2009 | Washing Machines
Getting error E3
3E == overcurrent detected at the motor.
Open the control panel, there you will find a tech sheet that explains how to put the machine into service mode and what to do while in service mode to track this down. Once on service mode, you can cycle through and retrieve all diagnostic codes. You will also find serveral other diagnostic service notes. Read them and follow the instructions to test the motor, motor control, and main control board. Hope this helps.
Jul 16, 2009 | Maytag Neptune Washer
Maytag washer 3e fault code
Jan 14, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
