Question about The Office Equipment & Supplies
    Top Expert:
  • The Master
  • 12,962 Answers
13 cubic feet
Posted on Aug 12, 2017
SOURCE: cubic feet
4' = 48"
thickness" x width" x lengh" = cubic inches
2" x 8" x 48" = 768
1 cubic foot is 144 cubic inches
768 divided by 144 = 5.3333333333------
Posted on Dec 10, 2008
  • 1236 Answers
SOURCE: How many cubic feet is this freezer
After looking over their website, which is not very helpful, it appears that it would be approximately 5.0 to 5.2 cubic feet. It seems that in most cases, the model number contains the size. Check it out at
Hope this helps.
Posted on May 19, 2009
  • 655 Answers
SOURCE: I am building a custom box for 2 15 inch Kicker
Hello bgl6176,
According to their specs, the L7's will work in a ported enclosure with as little as 3 CuFt and up to 6 CuFt. Usually with ported, bigger is better, so let's use the 5 CuFt per chamber. I'm assuming that you have room for a 10 CuFt box in the trunk? That's a big box? Almost half as big as a medium sized refrigerator. I hope you don't plan on putting your golf bags in there too. For 10.15 CuFt, a box will need to be 36X29X20, allowing 0.15 for the partition, sub, and port displacement.
To tune each chamber to 30Hz, you need a 4" diameter port 4.6" in length. Lots of custom builders use PVC and even ABS pipe for round ports. You can also buy "pretuned" ports from sites like
You'll have to measure the exact room that you have available and then adjust the dimensions accordingly.
Here's a link to a great site for calculating almost anything in box building and subwoofer related. You can use the old "multiply LxWxD and divide by 1728" and the other formulas too, but here you can plug the figures in and immediately see the results.
Hope this helps.
Posted on Oct 19, 2009
Testimonial: "Thank you so much for your help!"
  • 388 Answers
SOURCE: My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Posted on Dec 19, 2009
  • 15935 Answers
SOURCE: Cubic Feet of Washer
3.2 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Will 51 cubic foot of foam insulation, cover 400 square feet of a wall?
That depends upon how thick the foam insulation is. That is the only way to compute from cubic feet to square feet.
To simplify, assume the foam is 1 foot wide by 1 foot thick by 51 feet long. That is 51 cubic feet of foam. If you slice the block lengthwise at 1 inch intervals, you get 12 slices, each 1 foot wide by 51 feet long by 1 inch thick. This is 51 square feet of coverage at 1 inch. You would be able to cover 51x12, or 612 square feet.
Increase the thickness of the slice to 1-1/2 inches, you only get 8 slices, or coverage for 408 square feet.
Any thicker than that, and you won't get enough coverage for 400 square feet.
Aug 05, 2016 | Cars & Trucks
Area 40 ft long 4ft wide 5 inches deep how many sq yards needed
First step - convert everything to feet - 5" is 5/12 of a foot
40 x 4 x 5/12 = 66.6 cubic feet.
Since a cubic yard is 3 feet by 3 feet by 3 feet, there are 27 cubic feet in a cubic yard.
66.6 cubic feet / 27 cubic feet/cubic yard = 2.5 cubic yards.
Good luck.
Apr 15, 2016 | Office Equipment & Supplies
I am lying rock in my back yard so for me buy rock I Need to change feet into cubic feet
60 x 4 x .33 = 79.2 cubic feet. 27 cubic ft = 1cubic yard. 79.3 / 27 = 2.9 cubic yards
Mar 18, 2015 | Office Equipment & Supplies
How to calculate cubic feet ?
Calculating the cubic feet of a space requires multiplying the area of the bottom times the average height. You get the bottom area by multiplying the length times the width. Remember, to get cubic feet, you need all your measurements in feet to start with.
Here is your formula:
VOLUME (in cubic feet) = Length (in feet) X Width (in feet) X Height (in feet)
If it's a rectangular room you're working with, it is all straightforward. If there are irregular walls, it may be necessary to divide up the room into rectangular sections and then add together their individual volumes. If the ceiling is sloped, you need to use the height that has the same ceiling area above it as below it. Good luck! Truly.
Jul 25, 2014 | Building Materials
Cubic feet calculator
That would depend on the depth. A refrigerator that's 60 inches high by 30 inches wide by 1 inch deep would be just over one cubic foot. A refrigerator that's 60 inches high by 30 inches wide by 30 inches deep would be 31.25 cubic feet.
Mar 17, 2014 | Office Equipment & Supplies
just under 18 cubic feet.
at 4 inches thick there will be 3 square feet to equal 1 cubic foot. there's .6 cubic feet in an 80 lb sac. I'd get 30 bags and be careful not to go over 4 inches deep to often.
Dec 14, 2013 | Office Equipment & Supplies
Yards in a pile of gravel
There are 27 cubic feet in one yard. IF your estimate of pile size is correct, you have 720 cubic feet witch is 26 yards.
Jul 21, 2013 | Fish
29 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
