Question about Briggs Garden
I have a 10H902 0285 E1 Briggs and Stratton 22" self propelled mulching mower. I think my springs are attached incorrectly as it runs so high/fast.
I need a diagram that shows the correct attachment of the 3 springs. Can you help?
  • 95 Answers
SOURCE: Poulan Pro 22" does not mulch!
When you mulch you can only cut 1/3 of the grass off. If the grass is 3" high you can only cut 1" off.If you are cutting more grass of than you are leaving there is no place to hide the clippings.A general rule is if you notice clippings and clumps beginning to lay set the mower up one notch at a time until the clippings are hardly noticeable.If you like a real low cut then mulching is probably not for you,you will probably want to bag the grass instead.Hope this helps.
Posted on Sep 06, 2009
bbreton
  • 437 Answers
SOURCE: need a spark plug size for a yardpro self
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
If you discover you do have overhead valves; A Champion RC12YC, will work.
Posted on Sep 24, 2009
bbreton
  • 437 Answers
SOURCE: Looking for a parts supplier to source Murray push mower 22'' deck
Well I have looked at my suppliers and they are showing it no longer available. So you may have to search around and find an old murray mower that no one is going to fix but has a good deck. good luck.
Posted on Sep 29, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have just aquired a
The Briggs and Stratton 450 series is the engine (4.5 Hp). Is there a model number on the mower deck anywhere? I can probably find you a manual but need that model number. Unless you just want an engine manual.
Murray makes a 20 inch MX450 that has the Briggs and Stratton 450 engine on it but there are numerous makes and models (self propelled) that use this engine.
MX450 parts manual is here:
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=lminvFXBnfBhU7y
If you can come up with a good model number I will search avidly for a manual.
Thanks for choosing FixYa,
Kelly
Posted on Jun 09, 2011
SOURCE: Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
Posted on Mar 12, 2012
How to adjust governor
Yes, you can but the speed should be set with a tachometer. Your local dealer can make this adjustment for you.
Jun 28, 2014 | Craftsman 675 Series 190cc 22" Briggs ...
What kind of battery does it take
Mowers don't typically take batteries. Possibly riding mowers might, but not push/self propelled mowers. They run off a spark plug and gas and that's it.
Jun 13, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
What is spark plug gap setting briggs and stratton 190cc motor
That engine should take an RJ19LM (Champion) Plug and the gap is .030.
Oct 16, 2011 | Poulan Pro 22" Self Propelled High Wheel...
Briggs ad stratton 190cc gap setting
That engine should take an RJ19LM (Champion) and the gap setting is .030
The front drive self propelled wheels stick and squeal
why is the back wheels of my briggs stratton wont stop turning
Aug 29, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
B and s sprint xp40 29kg 2006 self propel
generally the belt gets stretched so check that 1st to see
Jun 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Sep 05, 2009 | Poulan Pro 22" Self Propelled High Wheel...
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
