Question about Garden
Pull cord locked up
I can't start my lawn mower pull cord won't pull
    Sergeant:
  • 210 Answers
Can you turn the blade. If not your engine may be locked up, you could just have something wrapped around the blade shaft. You have to look under your lawn mower.
Posted on Aug 12, 2017
  • 45 Answers
SOURCE: Lawnmower Starting Pull Cord Replaement
There will be a piece of casing that holds the starter mechanism in. Usually held by 4 screws (probably torx screws unless it's an old machine).
Undo these screws and you will find the cord carrier inside.
Observe how the starter dogs are located, and how it all goes together.
You may be able to remove & replace the cord without taking the carrier off the casing, but it is probably easier if you do.
Then you simply remove the old cord, thread a new cord through the hole & tie it. Reassemble the carrier onto the casing. Thread the cord out of the casing & through the handle, tie that end.
Then wind the cord around the cord carrier until there is a slight tension on the spring.
Screw the casing back on the mower and you're away.
Posted on Sep 27, 2008
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
  • 109 Answers
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
Posted on Apr 26, 2009
SOURCE: toro self propelled 22 inch recycler lawn mower start pull cord is "stuck"
Casey,
My son just bought a new Toro self propelled 22" recycler and has had problems on two different occasions. The mower just bogs down to a stop and when he tried to pull the starter cord, it was very VERY difficult to pull. At first I thought the engine had seized up for some reason (no oil?), but we found the problem.
First, disconnect the spark plug wire from the spark plug (to avoid the engine starting); tip the mower on its side and check very carefully the pulley and transmission belt. In his case, a piece of wood had gotten stuck between the belt and the pulley. Removing it fixed the problem (now he mows a little higher so as not to get so close to any debris). (We did have one further problem after that - the engine would not start - not even fire. After pulling and pulling, checking for gas, and checking that the air filter was cleean, we decided to check if the cylinder was flooded - we removed the spark plug, wiped and dried if off, and replaced it. It started right away.)
This belt 'n pulley arrangement isn't the best idea, if you ask me.
Good luck.
Posted on Jun 08, 2009
  • 1111 Answers
SOURCE: I have a briggs and stratton lawn mower ad the pull-cord is stuck
make sure nothing is jammed around the blades...if thats ok, remove the pull cord housing and try and spin the engine. if it doesnt turn, the motor is locked up and needs repaired
Posted on Jul 10, 2009
Performance power 420 mower won't start
remove the starter assembly and then you can see whats going on like a knot in the rope or something
Aug 10, 2012 | Garden
Pull cord pulls hard won't start
Remove the top engine flywheel & pull cord cover
Most likely dirty,as well as worn out. or the cord
is in the wrong place,you will see that,once apart
You can work on it some & down the road
get a new one if you have to
Jun 11, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
My Toro Personal Pace 22"
pull your spark plug and see if it will pull then, if so then it is hydro locked with fuel which can be caused y a bad fuel cap, not venting or a stuck open needle in carb causing gas to flood cylinder
Jul 27, 2011 | Toro Lawn Mower With Toro Power Tools
We broke the pull cord and after pulling the cord won't recoil to proper position.
remove the cord assembly ,, either the cord is off track and needs to be rewound or it broke and needs replacement
Jul 16, 2011 | Toro Super Recycler Super Bagger Lawn...
It won't start. The pull chord won't pull out. Even a little. It was out at one time, in the loop on the mower handle, but I had to let it go into the motor and now it won't come out.
You will probably have to disassemble the rewind assembly and either replace the rope and/or straighten out the cord and properly reconnect it to the flywheel connection. Kits usually are available at the Sears parts store or lawn and garden centers that handle lawn mowers everywhere.
Best wishes,
TF
Jun 03, 2011 | Garden
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
Gary
May 19, 2011 | Garden
Starting issues. Can't pull cord.
Make sure your flywheel brake is not engaged or the cover is hindering the mechanism somehow after it is installed
May 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Pull Start Locks
Disassemble and, re-engage the pull cord locking pawl spring
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
