Question about Nespresso Coffee Makers & Espresso Machines
My machine nespresso Delong hi has water leaking from capsule area filling drip tray and used capsule container rapidly De scaling has been done Can you advise Thank you
    Habit-Forming:
    New Friend:
  • 154 Answers
Give me the model ples
Posted on Sep 05, 2017
  • 3 Answers
SOURCE: Nespresso D300 says "Fill Water" even after I have filled container.
Even if you fill the tank with water, the machine will display this message when it is empty inside (the pipes, heating element, etc.) You need to prime it: run some water through it by running the steamer/hot water wand.  That should take care of it.
Posted on Oct 24, 2007
stefano-61
  • 69 Answers
SOURCE: coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Posted on Jan 08, 2009
SOURCE: water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
Posted on Feb 02, 2009
SOURCE: Nespresso machine does not punch hole on the capsules after close
This problem is most likely being caused by air being trapped in the system. To fix this, please follow the following steps: -
- Turn on the Machine, ensuring there is water in the tank
- Wait until the light stops flashing and the machine is ready for use
- Lift the silver lever on top of the machine into the upright position
- Press the coffee button on your machine
- Push the silver lever back, away from you, and hold it in this position for 3 seconds
- Press the coffee button again to stop the water flow
This procedure releases the air blockage in the system and your machine should function normally again.
(from
Nespresso Club)
Posted on Jun 09, 2010
  • 6 Answers
SOURCE: with our nespresso machine, when you place the
-the short term solution-
1. take your affected capsule. set it on its un-punctured/un-perforated bottom (the thin foil surface) on a flat surface. the three puncture holes should be facing upward on the top of the capsule. by the way, if you shake the capsule you should hear the grounds sound dry as if the capsule was new.
2. find a thin small rubber band. size-wise, ideally, the rubber band will fit loosely around your thumb; with a very small gap between the rubber and your thumb.
3. put the rubber band around the collar of the capsule. the band should be put over the top of the capsule and pushed down until it stops flush against the flange (rim). if the band is correctly placed, the band will be just 1mm flat inside the rolled bare aluminum edge (rim).
4. insert the capsule in your citiz machine as usual. optional: you can orient one of the puncture holes at 12 o'clock position (top dead center) during the insertion process. this time, it will work. you will find the capsule will eject cleanly with the rubber band intact.
5. save the rubber band.
-which machines does this apply to?-
this is a common problem with nespresso machines introduced after 2010, specifically the citiz. i have not seen this problem on the pixie, yet. i would expect this issue on the lattissima plus.
i am assuming that the machine is otherwise functioning properly: meaning that the machine does not have an issue with the water pump, excessive scaling deposits restricting water flow, or some other major mechanical part.
-why is this happening?-
look at the capsule, the post-2010 machines bite new slightly rectangular indentations on the capsule around the top edge of the wall. this is new. nepresso changed the insertion mechanism in response to competitors bringing non-nespresso branded capsules to market: Douwe Egberts/Sara Lee "L'or expressO", Caffe Vergnana "ESPRESSO", etc.
this new insertion mechanism was supposed to thwart knockoff capsules, instead it is unintentionally thwarting your "real" nespresso capsule. the injector needles are not piercing correctly all the way. the injectors poorly lodge: deep enough to make puncture holes but not deep enough to allow water to flow freely into the espresso grounds compartment.
two things can happen:
1. the pressure release valve, inside the brewing chamber which prevents an explosion occurring if the coffee exhaust path becomes blocked, is activated and hot water overflows into your used capsule basket.
2. the hot water flows outside and around the capsule and into your cup as clear hot water.
-what do i do long term?-
contact nepresso. get your machine repaired or replaced. this is a factory manufacturing defect that has nothing to do with you, wear, use, or hard water. refuse to pay the $125 repair fee. demand that they fix the machine free of charge. they will send you a loaner in a plastic shipping crate to use while your is being fixed. you should not have to suffer without espresso or waste legitimately purchased capsules just because nespresso is in a legal fight capsule copycats. this is not your fault.
Posted on Dec 26, 2011
I need to buy a T2/2 >ABS< part for my Nespresso machine, where do I get it?
visit this site for spare parts: https://www.nespresso.com/.../machine-spare-part-pixie-drip-tray-capsule
Dec 06, 2016 | Nespresso Coffee Makers & Espresso...
Leaking water when not in use
possible of leaking internal pipe may need to change /or drip tray to full also cheak water tank and see if it leaks
Mar 28, 2016 | DeLonghi DE LONGHI EN95S M.CAFFE CAPSULE...
My nespresso Larissa only drips a small amount when I press the large cup button?
After starting the machine press all 4 lit buttons on the top of the machine simultaneously for a few seconds. That will reset the volumes to factory settings. Decalcify your machine according to the manual provided with the decalcifying kit and the special nozzle for the milk steamer.
If if that does not work fill the water tank and the (clean) milk frother container with the 50/50 decalcifying solution + water and install as usual for making cappuccino (without a coffee capsule). Turn on machine and when the buttons light up press the large cappuccino button. Instead of cappucino you will get hopefully any of the residue from the entire system flushed out. Repeat until you used up the decalcifying solution in both containers. Discard and rinse a couple of times with clear water in both containers. Good luck - worked for my machine.
Oct 11, 2014 | DeLonghi Coffee Makers & Espresso Machines
Nespresso U coffee does not come through the spout
There are two nozzles in front of the machine attached together, the nose of the bigger one on the top slides into the smaller one on the bottom. When it makes coffee, the spout outside the machine becomes lower so coffee can come out. When it is done making coffee, the spout goes up so water/coffee drips in the drip tray. If one of the nozzles breaks, the spout on the smaller one will not go down and the inside end is lower and coffee goes inside the drip tray. It has nothing to do with cleaning.
Jan 20, 2014 | Nespresso Coffee Makers & Espresso...
Nespresso leaks coffee in capsule tray
check the gaskets or orings for cracks and replace if they look bad .perhaps a little lubricant is needed
Mar 19, 2013 | Coffee Makers & Espresso Machines
Capsule area is leaking
Perhaps capsule holder.
Look Inside on top of this capsule holder for a crack in molded plastic where water come in.
(I have replaced big "O" ring for nothing because the capsule holder is cracked on top).
Jul 04, 2012 | Nespresso Citiz C110
After a move, my Nespresso D90 sprung a major leak. Can anyone provide instructions on how to disassemble the unit and fix the issue or provide information if it is fixable? The leak is more like a steady...
Hi! I have found the user guide for your nespresso d90, you have to click on this link and for free it will start downloading your manual ( www.abt.com/documents/19390/d90cb_use.pdf ).
I hope this will help you! Have a nice day! :)
Sep 02, 2011 | Nespresso D90 Espresso Machine
No coffee comes out, only water despite capsule inserted. Capsule doesn't pierce at the front.
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
May 28, 2011 | Nespresso Citiz D110
My machine leaks water into the capsul box and doesn't punch holes or not enough in the capsule when pushing it in. Coffee is very weak because not enough coffee is reached in the capsule and water is...
Mar 01, 2011 | Nespresso Citiz D110
(from
Nespresso Club)
Sep 18, 2009 | Nespresso C100B Essenza Single-Serve...
Coffee Makers & Espresso Machines Logo
265 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
