Question about Samsung Televison & Video
I have a 75 inch Samsung tv. it will not turn on by the remote or the button on the tv. I have power to the outlet.
    Top Expert:
  • Samsung Master
  • 12,819 Answers
U have a power supply issue.
Posted on Aug 12, 2017
SOURCE: Samsung 50 inch plasma... no power to tv
We have had our tv for 5 months and we have the same problem, repair man is due to come on Thursday
Posted on Aug 26, 2008
ladywinn
  • 5138 Answers
SOURCE: Sony KV36H5500 WEGA TV (flat screen tube) will not turn on
Pull the back Off Disconnect CRT board connected at End of picture tube then turn set on and see if it comes on with volume, high voltage you can feel front of tv for static elect.... Let me know what happens then i can tell you what is wrong with TV.
Posted on Dec 27, 2008
  • 3 Answers
SOURCE: Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
Posted on Apr 24, 2009
  • 257 Answers
SOURCE: wont turn on
The power supply board has been defected. Replace it with a new one.
Posted on Aug 18, 2009
roety
  • 585 Answers
SOURCE: my samsung 330 lcd-tv wont turn on. the red power
Hi my name is Roety,
I can help you with your issue ,
Most common issue is the power supply capacitors, check and replace any that look swollen like this
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Posted on Oct 28, 2009
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
Need tv code for model un32eh40031
This should help!
Turn on the TV you are programming.
  1. Press and release the "TV" button on your Universal remote.
  2. Press and hold the "Setup" button on your remote until the button blinks twice.
  3. Type in the 5-digit code using the number buttons. Most likely code for a Samsung TV is 10812
  4. If the code is correct, you will get 2 blinks. If the code is incorrect, you will get one long blink.
  5. Use the Universal remote to operate your TV (use Power, VOL, etc..)
Dec 14, 2014 | Samsung UN32EH4000 32-inch LED TV
42 Inch Samsung Flatscreen; 1.5 years old. Won't
First test the wall outlet, try plugging a lamp into the same outlet see if it works. If the outlet works then read the following below. If the wall outlet doesn't work then plug the TV into another outlet.
If its not the wall outlet:
Unfortunately the power supply has a problem sustaining DC output. This can be caused from several fault scenarios. Get someone who is technically savvy and I will show them via e-mail what to test to fix this problem for you. Or you can take it to your local repair center.
Dec 20, 2009 | Samsung HP-T4254 42 in. Plasma Television
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
SONY DVD REMOTE CODE FOR SINOTEC LCD
I just followed the instructions to program the Samsung remote (Press tv button then press and hold the power button whilst pointing at your TV and type in the code) ....I went through every code until my TV turned off....The code for my Sinotec is 75
Jun 14, 2009 | Samsung TXM3296HF 32" TV
Configuring Sky remote
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Sep 20, 2008 | Samsung AH5900092W Remote Control
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Samsung lcd tv
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 07, 2008 | Samsung LN-S2651D 26 in. LCD Television
Samsung TXN3275HF NO Power
Not likely. It sounds like it needs parts inside..(It is almost never just the fuse on a tv) If it would come on with the tv button or the remote button, then it may be easy. Not coming with either proves that the tv needs parts, since you are sure the tv has power.
Feb 11, 2008 | Philips Magnavox Learning Universal Remote
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
