Question about LG Dryers
What is the part number for lint filter for lg dryer model dlex7700ve? One place said it may be part number 5231el1003b.
  • LG Master
  • 2,342 Answers
Try this
http://www.ebay.com/itm/U42-LG-DRYER-LINT-FILTER-ADQ73373201-/112427832904?hash=item1a2d389648:g:WzAAAOSw~y9ZMGaR
Posted on Aug 13, 2017
SOURCE: LG dlg5988W Gas Dryer - flashing "clean filter" light
i got the same problem and no repair man could help . i think i just got mine fixed 6-15-09 .what you do is go behind the dryer , remove the air duct and then remove the pipe that is inside the machine by removing one screw . this will give you access inside the machine .first clean as much as you can of the lint inside by vacuuming it . if you look to the left you will see 2 wires with a black button in the middle this is the ignitor ,clean it good because i think the dirt is not allowing it to light up . i did that and mine is working but the cooling light is still on .
Posted on Jun 16, 2009
SOURCE: Lint Filter Light comes on and cycle is interupted
I just found that the filter itself was not allowing airflow- I tested by blowing through it with my mouth- no airflow. I cleaned it with a high pressure air hose and noticed that the flow is much better now. I cleaned it by hand several times, and washing in water (which may have made theproblem).
Posted on Sep 11, 2009
omaharox
  • 166 Answers
SOURCE: the check filter light keeps coming ob to my lg
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Posted on Jan 20, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have an lg dryer model DLG5966W and the check
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Posted on Jun 17, 2010
richroth
  • 9472 Answers
SOURCE: dryer check filter light keeps blinking and dryer
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Posted on Jan 09, 2011
The lint trap does not fit properly and sometimes sheets/clothing get caught on the corner of it and get spun around several times. Has damaged some of these items. LG DLEX3370W.
pull out the filter and look into the duct that the filter slides down into,if it's blocked with lint you have to clean it out,the dryer should be taken apart and cleaned out at least once a year,and the vent line to so you don't have a fire,the clothes will dry on time and the motor and other parts will last longer.if the filter is damaged replace it,go here put your full model number in and look up parts
https://www.searspartsdirect.com/model-number/DLEX3370W/3204/0151200.html?searchType=modelSearch&q=DLEX3370W&searchTerm=DLEX3370W
Feb 11, 2018 | LG Dryers
Do you repair semi conductor sensors for lg electric dryers?
what is it?send the model number and the problem you're having,no heat?do you mean the moisture sensor under the lint filter?
Jan 07, 2018 | LG Dryers
Where is the lint filter
some lg models do not have lint filters need to know what model you have
May 27, 2012 | Dryers
Lint filter on LG DLEX2901V sticks up in the corner and catches clothes
Look familiar? LG dryer model DLEX3250W. Lint frame does not fit the slot anymore. NOT BECAUSE OF EXTRA LINT it's because the frame is warping.
Dec 07, 2011 | LG DLEX2901V Dryer
I need a lint screen for an old Kenmore dryer model 77950110...Serial # F12518756 Will Part No. AP3671843 work? Tx
That part number you have listed is a internal part number for one of the online parts sites its thier item number for the lint filter and may very well work. The Appliance manufactures OEM part number for that filter is 8557882 it could be purchased at your local appliance parts store or online from a place such as where you got that part number from or also online at;
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 12, 2011 | Kenmore Dryers
LG Dryer Model # DLE 2050 W is not drying. It is getting hot but clothes remain wet even after 2- 1 hour cycles. The information panel is blinking with a message that says "FLOW SENSE". The...
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Feb 14, 2011 | LG Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
Jan 09, 2011 | LG DLE0442 Electric Dryer
I took out the lint filter to clean and it will now NOT slide back into the slot. It just stops about 1/4 of the way up the screen. This is the first time this has happended in the 2 years that i have owen...
you need to clean out the dryer or have someone come in to do it.unplug the dryer,remove the lint filter and then you have to remove the duct that the filter slides into and clean that but you have to take the dryer apart to do this,next you have to vac out the cabinet where the motor is and clean out the vent line,if it's a long run i use a leaf blower to do this,remove the vent line from the back of the dryer,go outside and make sure the vent is clear then go back inside stick the leaf blower into the vent line and blow all the lint outside.you have lint stuck in the tracks that the lint filter slides into,get a skinny long screw driver and poke out the lint,if you have an electric dryer you should do this once every two years if it's gas once a year so you don't have a fire,next time send the model number and the name of the machine you need help with so i can help you better,if you don't know how to take apart the dryer send the model number and i can help you but there is lint stuck in the tracks that the filter slides down into and if that's like that then you need to clean out the dryer
Dec 23, 2010 | Dryers
Neew lint filter
Your washer/dryer was made by Kelvinator / Frigidiare.
(This is the 417 prefix)
See the Sears parts list for your machine:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=417.99175120&pathTaken=partSearch
Do a part search on Lint filter and you should see the part number 3204278
Although the Sears site says that this part is "no longer available", by doing a Google search on the part number itself, you should be able to find a number of places that have that part.
Mar 27, 2010 | Kenmore Washing Machines
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Jan 18, 2010 | LG DLE2514 Electric Dryer
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
