Question about GE Microwave Ovens
I have a GE profile oven/microwave combo appliance. Microwave is 1.4 cuft and needs megatron and transformer. Will those parts for any ge 1.4 cuft microwave work in my microwave?
    Sergeant:
  • 260 Answers
GE profile is a series, not a model. Look inside the microwave and you will see a sticker with the model number on it. Take that number and look it up online you will find many options for the part for your unit. Why do you need both? typically with GE it is usually the mag and maybe the rectifier. If a transformer goes bad it typically burns up and smells horrible. I mostly find bad mags on GE, the ones they use are not very good. OM75P = junk
Posted on Aug 24, 2017
SparkGap
  • 363 Answers
SOURCE: I recently purchased this home,
The manual is available on the GE web site
http://www.geappliances.com/service_and_support/literature/
Type in the model number
Good Luck.
Posted on Aug 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium 120 Microwave (Model SCA1000DBB03)
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille, on the floor of the oven behind the control panel, between the door switches, or on the filter board near where the cord comes into the unit.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
stonephoenix
  • 563 Answers
SOURCE: GE Profile Microwave will not heat
Unfortunately, there is no way to tell which part the microwave needs without opening it up for examination. There are a few parts that, if defective, would prevent the oven from heating.
  • a high voltage transformer which passes energy to the magnetron
  • a magnetron which converts high-voltage electric energy to microwave radiation
  • a magnetron control circuit (usually with a microcontroller)
This is NOT a repair that you would want to attempt yourself. The labor for the repair would cost a minimum of $50 and shouldn't exceed $100. You'll also have to pay for the necessary part if it's still available from the manufacture or their parts distributor.
Posted on Feb 04, 2009
SOURCE: oven part works fine, microwave runs but doesnt heat
bad micro switch in door handle, 79.95 for GE man to check,9.61 for the part and changed it myself
Posted on Apr 17, 2009
SOURCE: GE Dual Wave II microwave oven blowing fuse
I have the same issue and the same unit. I wonder if there's a recall...
Posted on Feb 21, 2010
Does GE make a 1650 watt microwave oven?
The highest wattage GE microwave sold to consumers seems to be 1200W. See http://www.geappliances.com/ge/microwave-oven.htm . That's the rated microwave power. The power draw from the outlet on this type of microwave is 1650W. See the Profile series 2.2 cu. ft capacity microwaves, like the PES7227DLBB, http://products.geappliances.com/appliance/gea-specs/PES7227DLBB
I hope this helps.
Apr 22, 2018 | GE Microwave Ovens
Our microwave has stopped working for the second time in two years. When you try to heat something, it hums but not quite like it is heating. There is also a funny smell.
SAFTY FIRST
UN -PLUG IT,,,,, THAT "FUNNY SMELL" SOUNDS LIKE IT IS SHORTING OUT
PERHAPS THE MEGATRON HAS GONE BAD, THE MEGATRON IS THE
HEART OF ANY MICROWAVE
AS A EX- FIREMAN, I KNOW FROM FIRST HAND EXPERIENCE THAT
"A FUNNY SMELL " OR " UN-USUALL SMELL COMING FROM AN ELECTRICAL
ITEM IS A SIGN OF DANGER
Feb 05, 2011 | GE Profile Spacemaker JVM1871 Microwave...
Re: GE Profile Spacemaker XL1800 Loud humming sound when turned on. Please advise
I have the same problem. A repair person said that he thought it was the megatron (whatever that is) He suggested just using the microwave until it quits.
Dec 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My3yr old GE profile microwave doesn't warm up
from what you are discribing , I would be looking at the high voltage transformer
Feb 13, 2010 | GE Profile Over-the-Range Microwave
GE Profile Performance Convection/Microwave Problem Heating
Either magnetron, capacitor, diode pack or transformer has failed causing a fuse to blow.
Jul 13, 2017 | General Electric Microwave Oven
Ge profile 2.0 microwave runs but does not heat
Replace the megatron tube; or replace the unit. GE will have a list of tubes. Remove the panel inside the unit to expose the tube. Get the number off the tube and find the replacement on the GE website.
Nov 08, 2009 | LG LMV1630ST Microwave Oven
Feb 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
