Question about Crosley Audio Players & Recorders
I just got a crosley cathedral radio cd player but my dc player won't play ,the am and fm works good but the cd won't play ?
SOURCE: GES050 undercounter radio/cd player
..just read about your reception/interference problems and, having lived through similar situations for some time — particularly with different weather conditions. The following solution has settled it all : wrap power cable around storage brackets at back of radio with a short length then wound around support posts (between radio and cupboard from which radio hangs), then run short length to power supply outlet. In my case this result comes after much experimentation with the length of unwapped power cord (including fully unwrapped and stretched out) and different patterns of winding around the support posts. This final result takes care of everything (better sound, no interference/loss-of-reception when moving around in the room or in front of the radio, weather has no effect, stations received that could not be before due to overlap by nearby, more powerful ones). I have only about 2 1/2 feet of cable running from the brackets at back of radio, then wound once around center support and half around right support to then go to wall and down to receptacle close by (I tried all kinds of combinations of unwrapped lengths and winding patterns around 1 to 3 posts)...individual cases may be different. so GOOD LUCK, 'cause the radio is great...!
Posted on Aug 07, 2008
neutronrace
  • 66 Answers
SOURCE: CD player on Bose radio started making a click sound
did you clean the laser inside? that a thing I would do first
after that mail us again
Posted on Feb 15, 2010
  • 17 Answers
SOURCE: I have a Crosley CR248 cd record player/recorder stopped working
If nothing lights up and the whole unit is dead, you may have a blown fuse, a bad power supply, or an electrical outlet that is not giving you power. (Don't laugh, it has happened to all of us... the "broken" thing wasn't plugged in or the outlet it was plugged into was off for some reason). Anyway, if the thing lights up and everything else in the system works except the turntable going 'round, perhaps there is a slipped or broken belt. Most late-model Crosley turntables have been belt drive, so the first thing to look at if everything else works is to press the buttons to start the record playing and then turn the record gently around with your finger on the label, making the whole platter turn clockwise when looking down at the record. Mechanically, the tonearm should cue up and pivot in to the record and it should gently drop onto the record. If you cue the tonearm up and move it in to the end of the last song on the LP and let it back down and turn the record again, it should follow the record's grooves into the center of the record and then lift and "park" the tonearm after everything is done. During the time the needle is on the record and you are turning the record, you should hear the record playing (it will sound bad, because you won't be turning at the right speed!), but that should indicate that the turntable is working mechanically and electrically.
If everything works like I mentioned except the record player won't make the record turn, the next step is to see why it isn't turning. you'll need to lift the plastic platter off the turntable. Most of these have a snap ring (usually a simple spring wire ring that doesn't go all the way around the center spindle. It may have an E-ring instead. Use a small screwdriver to pop this off and be sure to catch it, it might try to pop off the turntable and fly across the room! Lift the platter and you'll probably find a broken belt underneath. You'll have to replace that to make the records spin again. The hardest part is to locate a replacement belt! If nobody near you stocks belts (lol) then online outfits like LPGear.com can be a source. After you replace the belt and put the platter back on the player, remember to replace the snap ring. You might want to lubricate the platter's bearing with an appropriate lubricant, but that is your call as to whether that will be necessary. This is likely a styrene or simple thermoplastic plastic bearing, so be real careful what you use for a lubricant! if you're not sure, don't use anything! Like I said, it's not a difficult repair, it's just hard to find the part these days! Good Luck!
Posted on Jul 24, 2010
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
SOURCE: I cannot get the CD player to eject the CD. the
I have a ford focus 2005. The standard radio stopped working and the single cd would play but would not eject. I checked the fuses by removing them and now nothing works,. I have the correct code which I have used before but now it will not accept the code - in fact when the buttons are pressed no numbers appear
Andy
Posted on Jun 11, 2012
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
Own a crosley jukebox, cr-12-3. unit is not reading the cd's. any suggestions? i tried a cd cleaning disc. still nothing
Hi
if you can open the jukebox and look for the cd unit. under the place of the disc you should see the laser head its a small lense
try to clean with a qtips could be dust on the eye
it helped me when my cd player did not play
Hope it will help
Oct 21, 2010 | Crosley Jukebox CD Player with AM/FM Tuner
Can i play mp3
Yes it does.....I have included a full list of specs for you for this model
  • DVD/CD player with navigation and built-in amplifier (15 watts RMS/50 peak x 4 channels, CEA-2006 compliant)
  • fits double-sized (4" tall) dash openings
  • motorized 6.5" LCD video screen with adjustable display angle and touchscreen controls
  • plays CDs, CD-Rs, CD-RWs, DVDs, DVD-R/RWs, and MP3 discs
  • GPS navigation (includes GPS antenna and map DVD-ROM)
  • City View mode - 3-D maps that render accurate representations of specific buildings in many cities
  • 6 million points of interest (hotels, restaurants, gas stations, etc.)
  • customizable route preferences
  • separate CD and DVD slots
  • five soundfields: cathedral, club, concert, live, theater
  • 9-band parametric EQ
  • 5 preset EQ curves
  • SIRIUS Satellite Radio-ready (you can add SIRIUS for under $100, plus subscription)
  • compatible with Eclipse HD Radioâ„¢ tuner
  • CD changer controls
  • audio/video input
  • rear-view camera input
  • audio/video output
  • 5-volt front, rear, and subwoofer preamp outputs
  • AM/FM tuner
  • 6 FM/6 AM presets
  • warranty: 1 year
Oct 08, 2010 | Eclipse AVN5500 Car DVD Player
Could some one tell me how to change the stations on my WURLITZER -MODEL WR 18-1015-CD AM/FM- 18" TALL-LIGHT UP i have tried to and i can not get it to work. It only has a remote. Thank you
Here is a link to obtain the owner/user manual for that wurlitzer if you would like it:
http://www.payphone.com/shop/instructions/Wurlitzerwr18.pdf
1. Turn power on using either the remote or power button located behind tuner door.
2. Push CD / RADIO BUTTON (25) to enable FM tuner.
3. Turn FM dial to desired station.
4. Position FM ANTENNA (16) for best reception.
5. Set volume to desired listening level.
Sep 17, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
Turntable will not turn
I should imagine the belt has either slipped off or broke. If you lift up the turntable matt you might see it.
Jun 25, 2010 | Crosley (CR47) Turntable
Crosley CR704 record player wont work, HELP!!!
Make sure the switch on the back for line in, is off! I had mine on and it would not play. Switched it off and all works fine!
Aug 01, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
My Crosley combination turntable/CD/cassette/AM & FM radio has recently started giving me fits. I bought it new in 2003 and, until a few months ago, it worked great. But now the turntable arm won't click...
my Crosley CR6007A-MA turntable's sound is very, very low. You can't even hear it barely. I haven't had it long at all and it wasn't broke due to any sort of abuse. I really have no idea why it would do this for no reason! Help!
Apr 01, 2009 | Crosley Audio Players & Recorders
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
