Question about Radio Communications
How do I reset channel on talkabout 250? It is on 9.11 and i want to go to 9.o
What frequency does my motorola talkabout have
If they're all set to the same "Channel" and "Code" you will be able to talk between them.
Apr 15, 2014 | Motorola Talkabout T5300 (14 Channels)...
I changed the batteries on my Motorola Talkabout 250 .......shows full power...both are set for the same channel and code.......but they aren't communicating. Please help.
Remove batteries from both. If there's a "factory reset" option try that. Re-check that they are REALLY on the same channel and code. Also be sure there's nothing stuck in the external headset jack.
Aug 11, 2013 | Motorola Talkabout FRS 250 (14 Channels)...
Issues with Motorola TalkAbout T5900 (14 Channels) 2-Way Radio. Do they need FCC programing & licensing to operate? Because I can not get the to communicate with each other!
Yes they do.The thing about the talkabout is that they work according to the network area they are connected to and the number of the talkabout they are also connected to.So all you need do now is to take the talkabout to motorola shop so that they can confrigure it for you.
Jan 22, 2011 | Motorola TalkAbout T5900 (14 Channels)...
I have a Motorola Talkabout T5419 not receiving
motorola has extra security and will not operate with other radio makes very well. It must be locking out the uniden radios.
Oct 27, 2009 | Motorola Talkabout T5420 (14 Channels)...
Talkabout 250 screen cracked
Sorry, but the answer is no. The fact you cannot change channels indicates the damage is deeper than just the screen.
Jun 25, 2009 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola talkabout sx700
Check your "code" setting. You may be on the same channel, but different codes. The code is the smaller number. Check your owners manual if you have one for resetting the radio to the factory default settings. This will clear any programming issues.
Aug 15, 2008 | Motorola Talkabout SX700 2-Way Radio
Motorola Talkabout T5720 circuit schematic
We are a M dealer and the schematics for the TalkAbout line were never released to the dealer channel.
Jul 13, 2008 | Motorola Talkabout T5720 (7 Channels)...
Motorola Talkabout
Hello trailrunner,
Back when Family Radios first came out a number of manufacturers came out with both standard 14 channel radios and scaled-down single channel radios designed as entry level offerings. My guess is the radio you have is probably a single channel unit based on what you describe. It probably operates on FRS channel 1 (462.5625 MHz).
If you post the model number and FCC ID number (which should be located on a sticker on the back of the radio) I might be able to give you some more information.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 08, 2008 | Motorola Talkabout 2-Way Radios
Talkabout T5720 Frequencies
Hello Ruaal,
The frequencies in the TalkAbout T5720 are not adjustable. The radio operates on the designated Family Radio Service channels located at 462 and 467 MHz. There is no way to change these channels to be at 463 and 464 MHz.
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Motorola Talkabout T5720 (7 Channels)...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
