Question about Garden
The needles on my 4600 do not completely reset and the plunge comes onto the stops and shears the shear bolt. moving the needle arm 2" towards the thrower reset the knotter
RickE1
  • 202 Answers
SOURCE: Needle continues to hit plate
2 things you can try. First center your needle. On the bottom right front side of the needle plate there is a locknut. You can loosen this and possibly move (adjust) the needleplate under the needle. Then tighten it. Otherwise (and this is probably the way)... there are 2 styles of needlebar pivot pins. Old and New
Remove the side cover. Old style... On top of the needle bar. Very top, you will see it is connected to a small shaft that is held down with a screw through to it on the side. This holds the needle bar in position. Have your thumb pressing on the top front of the needle bar and slightly loosen the screw. Push or ease off (whichever) on the top of the needle bar until the needle is lined up correctly with the needle plate. Then tighten the screw. Thats the Old Style. The NEW style has a shaft on top on back of the needlebar (maybe a inch long) that is held down by a screw on top of it. This shaft also goes through a spring. Put your thumb on top front of the needlebar and loosen the screw a bit. Remember, its spring loaded so keep your thumb pressed against it until the needle is lined up then tighten the screw.
That should do it. If you think that might be a bit much maybe you should drop it of at your local dealership and have it cleaned, oiled, and adjusted by a tech. That would be best anyway if you bought a used machine. But you can try this first. Good luck.
Posted on Oct 10, 2007
robotek
  • 1512 Answers
SOURCE: Crosley CR-49 Turn table stops
The tone arm may have been forced out of spec to play an entire LP, or the auto cutout function of the player appears to be operating.
If out of adjustment(someone has forced it), the problem can be resolved by loosening the screw that locks the tonearm to its turret, and adjusting the end travel against the distance to the end of the LP you mentioned it wont play. Then of course tighten the locking screw again
Another common problem, is where dried grease between the two small metal plates fixed to mechanism that engage against the center spindle to activate the autostop mechanism. You will need to remove the platter in most cases to get access to this autostop mech to clean away the dried grease and or adjust it.
Good Luck with your listening. Long Live Vinyl :)
regards
Graeme
Posted on Feb 28, 2008
  • 55 Answers
SOURCE: on my rack and pinion the bolts sheared off and
as far as removing steering from rack youll need repair manual for your car. bolts, drill a hole in middle of bolts and pound proper size E-Z out into hole. turn ezout to left to remove. good luck.
Posted on Jul 18, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a ariens model 924 10 horse snowblower
There is a shear bolt for both the right and left side auger ribons/cutters
Posted on Dec 24, 2009
  • 179 Answers
SOURCE: crankcase pulley bolt sheared off
Its a common problem on Kias, can you get at it to drill it out.
how old is car?
Posted on Feb 23, 2010
I have a kolher 149cc engine on a Husqvara lawn mower, it seems to be out of time because is rips the pull cord out of my hand.
take the top of the engine off and remove the flywheel bolt blow out any dirt and look to see if the flywheel key is sheared. if it is replace it and put back together. you may want to check the blade also because for it to shear a key it had to have hit something probably causing the blade to be damaged.
Oct 06, 2017 | Garden
I cant get my needle position to move to the left or the right
The long arm is attached to the needle arm.
1. Move the needle arm right and left with your finger. Is there any resistance? There should be. If not, a spring that is supposed to be attached to the long gray rod has came loose.
2. The spring will be attached so it pulls towards the round cogs (bumpy things).
3. Mechanical sewing machines are very similar. There is a possibility that your adjustment lever has screws came loose.
4. By moving the needle arm back and forth you can monitor what is going on to get a clue of what may be wrong.
Mar 06, 2015 | Sewing Machines
Both augers turn when not trying to clean snow,as soon as I try to use it and snow gets to the augers,only one auger moves on my ariens 520 snowblower
It sounds like the auger always turning is the auger engagement handle/line/connections are not adjusted correctly. They/it is too tight causing the auger to engage before it should. It may be up at the handle where you loosen a jam nut, screw in or out a threaded shaft, and retighten the jam nut. (If you have ever adjusted a bicycle brake it is similar.) (I have a craftsman, made by MTD, and I think I saw MTD also list Ariens.) Or it could be an adjustment somewhere else (but I'm not sure where).
As far as one auger moving and the other not, you may have a shear-pin (shear bolt as the manual calls them) on each side of the auger's shaft (my craftsman has one on each side), and the one on the side that stops turning is sheared off. (It moves without snow present due to the driveshaft inside the outer auger shaft turning, but it won't turn under load (snow).) You may confirm a sheared-pin by turning the machine off and try to turn the auger blade. If it turns somewhat easily, that's a bad shear pin. Remove the old shear pin. If the old one is as long as the new one, that aint the problem. The shear pin in the image is one kind. Mine appear as a straight bolt (no grooves), threaded the entire length. You will have to rotate the auger blade until it aligns with the hole in the shaft. Use a nail that fits and rotate the blade until the nail goes in. Remove the nail and screw in the shear bolt:
The auger clutch control up at the handle looks like this:
25398197-u3i4ko1tk2s0xlbbi4fvvtzj-2-2.png From my manual
Auger Control
  • To check the adjustment of the auger control, push forward the left hand clutch grip until the rubber bumper is compressed. There should be slack in the clutch cable.
  • Release the clutch grip. The cable should be straight. Make certain you can depress the auger control grip against the left handle completely.
  • If adjustment is necessary, loosen the hex jam nut and thread the cable in (for less slack) or out (for more slack). Recheck adjustment. Tighten the jam nut when correct adjustment is reached.
Here's another view of that:
I hope the above info helps you take care of both issues.
Feb 03, 2015 | Ariens Garden
Twisted wire guide for the thread above the needle
Slide it onto the needle clamp from the bottom before you attach the needle clamp to the needle bar.
Mar 14, 2014 | Brother XL-5130 Mechanical Sewing Machine
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Needle skips
A needle is a precision part. Look to see if the needle has a conical point descending from the cartridge needle carrier. If not, replace the needle.
*Always protect the needle while you adjust things!
Pressure is essential for the needle to track. Turn the weight down until the needle just floats above the record. Zero the weight by turning just the weight indicator, not the weight. Now turn the weight to add 1.2 to 1.5 grams. (Always use the manufacturer's recommended weight if different!)
A level surface is important. Make sure the turntable is level.
Test the arm bearings:
Adjust the weight until the arm floats. With a feather, gently push the arm towards the center. Now gently push it back. The arm should move smoothly with no hesitation and easily. Reset the weight to 1.5 grams or less.
If your cabinet is moving when you walk around, the records will skip. Find a different place for the turntable or don't walk around. In severe cases, raise the weight to 1.75 to 2 grams, but this wears the needle fast an can cause distortion.
Mar 22, 2010 | ION Audio Vinyl Recording Turntable
Replace steering column lock & ignition land rover discovery mk1 whats the best way to remove the shear bolts.
use a dot punch and hammer and try, by hitting the sheared head part of the bolt, to turn it anti clockwise, once it starts to move, it should come out very easy,
Mar 11, 2010 | 1998 Land Rover Discovery
When i backspin the arm is forcing itself off the vinyl
IMO the problem can be solved in 2 ways, either move the counterweight on the back of the arm towards the turning point of the arm ( by just adjusting it 10 - 20 % of an whole spin you can adjust a lot), or buy an other needle which is heavier then this one...
Jan 29, 2009 | Technics SL-1210 Turntable
I have a quantum cxl. It will sew normal stiches but it will not sew the decorative stiches
The needle shaft sticks to the curved arm and won't come down because a piece of plastic, about an eighth of an inch thick had broken from age. It prevented the shaft from staying up on the needle arm. Open the cover, try to stitch decorative stitch and see what I mean. Purchase a package of 4-10 by 1/2 nut and bolt pack. Screw the nut all the way onto the bolt. Using needle-nosed plyers, Carefully bend the curved arm slightly, and place bolt into the hole on the top of the needle shaft. Nut will keep it in place. Lowering the needle shaft using wheel, carefully bend arm back in place. Try decorative stitch. It should work. It does for me.
Aug 03, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
