Question about Boating
2009 60 Bigfoot efi 4 stroke. Trim works perfectly with motor off but struggles with running. Sounds like not getting enough power.
  • Fabrice Wolters Sep 25, 2017
    Hi Lynn henschell, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Does it struggles only with engine engaged in forward or also engine simply idles?
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
  • 636 Answers
SOURCE: 2006 Mercury 9.9 Bigfoot with 4 blade prop on 24
Could be , some props have a pressed hub
Posted on Aug 17, 2009
alicantecoli
  • 22326 Answers
SOURCE: How to install 2007 mercury 40 EFI 4 stroke remote
not sure what you mean here because when i installed mine it just plugged in on the engine ,and the control end as well from what i can remember with some odd cables for the rev counter that i never bothered fitting
Posted on Sep 17, 2009
  • 563 Answers
SOURCE: Motor will not run even though battery fully
Are you sure your amature is good? If the amature wires are deformed; brushes out of synch, motor won't run.
Posted on Nov 01, 2009
  • 5 Answers
SOURCE: HESITATION UPON ACCELERATION
WATER IN YOUR FUEL OR YOUR ENGINES TIMING NEEDS ADJUSTMENT
Posted on Jun 29, 2012
I have a mariner Bigfoot 15 hp ser no OG 811362 it says on casing that it is 4 stroke but the guy I bought it from said it is 2 stroke how can I find this out with the use of she no
According to the ser #, your engine is 4 stroke. Does the engine have a dip stick to check oil level, a 2 stroke will not have this as it uses a fuel/oil mix. Also it will have an oil filter on 4 stroke. Hope this helps.
Jun 15, 2017 | HP Boating
Engine runs rough under load
how old is the motor
4 stroke with valves or a two stroke ?
blades
spark plug , coil , air fuel mix check valves
re check governor setting
if grass is way above the front height of the frame it will struggle
raise the height first to max on the first run
then lower
or use a grass trimmer to knock the level down before mowing
May 17, 2016 | Garden
On my 50 Yamaha two stroke I have power to the trim motor from the green and blue wire but no movement. I have a clicking sound when I move up or down is the motor bud?
Sounds like faulty trim tilt relay.Connect blue green wires direct to battery ,if motor goes up or down then trim is ok but relay is faulty
Aug 10, 2015 | Boating
Power trim has stopped working on 2008 suzuki 4 stroke outboard
Check fuse,trim button,loose wire,trim motor
Aug 15, 2014 | Boating
Why do you get total loss of all electrics
Its possible, but if trim stopped first, then you lost everything else, I would doubt it's the fuse. Unless they're on separate circuits. First check your battery connections and voltage. Next check for power at your fuses. If they're good, check if you have a main power solenoid. If you do, its possible the coil has gotten weak or the contacts are worn. Hopefully this helps. Electrical issues can be a variety of things but are usually simple.
Jul 15, 2014 | Clymer Mercury/Mariner 4-90 HP Four Stroke...
2005 mercury 9.9 hp bigfoot motor
does it get faster with speed the clicking ? could be a bearing !
Apr 28, 2013 | Mercury Four-Stroke Outboard Motors, Model...
Cagiva super city 125 waz perfect now not reving after 6000rpm
Hi, Lallyg45 and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your question and free downloads that you will need please visit the website below. Good luck and have a nice day.
bike wont rev up past 6 000 rpm please help
https://www.tradebit.com/filesharing.php/search/0/1993+cagiva+supercity+125
https://www.oemmotorparts.com/oem2.asp?M=Cagiva
http://www.cagiva.nl/media/owner_manuals/?tx_motomondo_pi4%5Bmodel%5D=&tx_motomondo_pi4%5Byear%5D=-1&tx_motomondo_pi4%5Bmanual%5D=
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 04, 2010 | 1993 Cagiva Supercity 125
HESITATION UPON ACCELERATION 40hp-4 Stroke BIGFOOT Also at times while idiling engine sputters
Try fresh fuel...if carberated then clean out carbs. Sounds like clogged jets from varnished carb bowl and old fuel.
Jul 17, 2009 | Raymarine St6002 Smartpilot Hydraulic...
Boating Logo
37 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
