I can get the audio but no picture. I have a DVD player with a receiver. It used to work at one time I can't figure out what buttons I'm pushing or not pushing to get it to work or what remotes to stick with. Thanks.
  • 158 Answers
Check for video mode button on remote or P/N button.press a few times and video should come on
Posted on Jul 31, 2009
Component video problem. Hi I got the Denon AVR-3806 receiver and has it hooked up with a component cable to my background projection TV. To the reciever I have a satellite box connected also with a...
Just fixed this myself - made my head hurt to figure out. 1. Switch to a setting (say DVD). 2. Watch the AVR screen as it switches. You'll see the audio and video settings. For example, Audio = DVD, Video = DVD (Mine showed Audio = DVD, Video = DBS even though is was set correctly using the SETUP for audio and video)3. Under the round control knob on the left, push the (tiny) Video Select button. 4. Turn control know to choose the correct video source
Your system should work right. Mine did.
Jan 03, 2011 | Denon AVR-3806 Receiver
No sound when i put a dvd on can see the picture but their is no sound, was work until kids push some buttons
If the kids pushed some buttons on the receiver, look for "Stereo Direct" button, push it, if you have audio then, that was your problem, if not, press it again then go to the "signal select" button. This will switch the audio between digital and analog. If you still have an issue, post a comment and I will help some more. Hope this helps
Jun 30, 2009 | Pioneer VSX-D511 Receiver
Lost sound programing on my Yamaha 5850 receiver some how can not figure out what went wrong. Do have sound on tuner. When doing setup testing speakers work. Any idea's what I'm doing wrong?
What do you mean by "sound programming"? -- I guess it's the ability to change the sound processing, such as from Stereo to Dolby Digital, or to Dolby Pro Logic or Virtual Surround, etc.? Maybe there's a "Direct" or "Pure" or "Tone Control Defeat" button that was pushed, which often (or always!) bypasses all the sound-processing circuits? Check the front panel and/or your remote for such a button and try that.
If it's a DVD player, it may be that the audio connections were accidently pulled or changed. Assuming it's the latter (more likely): Either the digital/analog output setting of the DVD player or the setup of the receiver could have been changed. Next, this is a guess, but most likely, it is the receiver that was tweaked -- in order to listen to some other source (such as the tuner), and it is no longer set up to process the digital signal, but stays in analog mode -- AND there's no analog audio connection from the DVD player (or it was not set-up to output analog to the receiver, since the preferred signal is digital surround). Am I getting warm?
Jun 10, 2009 | Yamaha HTR-5850 Receiver
Went from audio and video to audio only
Actually, I don't think your problem is a matter of buttons pushed on a couple of remotes at all. I looked around the web and noted several instances that instructors may have confused readers, including those of the notably confusing user manual, as to how many of the multiple video inputs can be used simultaneously, and I believe you should choose the highest fidelity video input, whether optical or even composite, since your symptoms seem those of a situation where several video inputs
are superimposed one upon another, which is an absolute no-no, and can ruin your video amplifier.
Check for multiple video input hookups before you burn out the vid-amp.
Apr 14, 2009 | Televison & Video
Cannot get my mp3 player to operate on the aux input consistently
I have a 2002 Pontiac Montana and I use a 2 pronged RCA plug at one end with a yellow plug and a white plug, and the other end is one plug to use for the MP3 player. Plug your RCA plugs into the bottom 2 plugs. My RCA plugs on my cord are yellow and black the yellow one is in the middle
plug and the black in the bottom one and I use the AUX input for my MP3 player. I have a SANSA
and a Ipod and they both work fine. I hope this helps. Just a FYI so you don't think your radio is
going whacko after you do get the MP3 player to work the AUX will always come on first and you will have to push the AM/FM button on the dash or the steering wheel to get the radio or DVD back on.
And the DVD player will have to be switched on for the AUX to play the MP3 player.
Have fun...
Mar 28, 2009 | OEM Systems Car Audio & Video
Won't Show DVD Picture or Hear From Surround Sound Speakers
The lack of video in the DVD can be isolated to the DVD players output mode, if you are using the component video out on the dvd player then be sure to follow the componet out of Receiver to the tv component inputs, if you are using the HDMI from a DVD HDMI into RECEIVER HDMI then go to TV HDMI, you cannot mix component and HDMI on this model of AVR receiver and acheive results, in other words keep the COMPONENT to Component and HDMI to HDMI signal path, the results will be similiar quality audio and video UNLESS you are doing a blu-ray source which will result 1080P quality, all other video, HD results to 1080i, about the audio, if all 5.1 test tones are satifactory to speakers but on playback modes for DVD or HD tv signals all you are receiving is LR which is basically 2 channel (stereo) you need to enable a MULTI-CHANNEL capability input, this must be a option on the DVD Player Audio MENU output, be sure it is set for DOLBY DIGITAl 5.1 or DTS outputs, be sure to have the receivers digital input enabled if you are running optical cable or coaxial digital for the audio, you will be sending a multi-channel input to the receiver when the Receivers Faceplace LCD displays 5-6 speakers. If it shows only LR or two speakers it is not locking into a 5.1 audio input.
Feb 21, 2009 | Yamaha HTR-6130 Receiver
Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Feb 05, 2009 | Onkyo TX-SR304 Receiver
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
HDMI SOUND PROBLEMS
yes u guys nee dto do all the hdmi directto tv then optcal digital back to sterio digital in for sound only ect not throw sterio kills picture also
Jan 30, 2008 | Yamaha RX-V661 Receiver
My DVD player, stopped playing in color!
check to see if the coding is set to PAL or NTSC, when watching in PAL, NTSC shows up in black and white. ( NTSC is normal for the USA and a hand full of other countries... PAL is used in ASIA, EUROPE, and most everywhwere else).
Oct 18, 2007 | Panasonic DVD-S29 DVD Player
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
