Question about Microwave Ovens
How to change the bulb for kleenmaid wall oven model T055x
    Sergeant:
  • 123 Answers
Changing the bulb
Warning: disconnect the appliance from the power supply before replacing the bulb
- Turn the cover one quarter turn to the left.
- Unscrew the bulb and replace it with a heat-resistant (300 °C) bulb of the same size with an E14 base - 15 W.
Posted on Aug 12, 2017
NN2909/NN-2959. My cooktop bulbs blue out together! Changing bulbs does not correct problem. Is there a fuse somewhere? Any way I can fix this problem?
microwave oven model number but of course their is a fuse in anything. follow power cord from wall into cooker and look for a fusible link is what I would do. Both cooktops out at once is an indication of no power.
Dec 29, 2016 | Microwave Ovens
How do you replace microwave bulb in GE combo microwave and oven wall unit model # JKP86B0F7BB. I also need to know the type of bulb needed.
To replace the bulb part number WB08X10012 you will have to either access control panel to microwave (its behind it) or pull the entire unit out of the wall enough to remove the side panel just behind the control panel. Either way you elect to enter unit please turn off power first for safety. Not an easy task to do, but possible if you able to change this yourself. Cost is high to have a service person do this due to liability issues.
Good Luck
Nov 02, 2013 | Microwave Ovens
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Mwk100x7 kleenmaid microwave displays in lcd panel 'LOC'
I did solve the problem myself after leaving the microwave alone for 20 minutes after which it reverted to the normal functions. Many thanks for your interest. Kind regards, Ash
Oct 04, 2009 | Microwave Ovens
Microwave light is burnt out
Accessing the internal light bulb on model KBMC140HSS bulb will require you to remove the oven from the wall.
You can download Whirlpool / Kitchenaid owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Feb 14, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
How do I replace the bulb inside the oven?
We can probably give you more specific info if you give us a brand and model number. But here's the generic answer:
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
Again, reply back with brand and model and maybe we can get more specific.
We appreciate your thoughtful rating of our answer.
Nov 06, 2007 | Microwave Ovens
GE Spacemaker Microwave
On these models, the oven must be pulled from the wall mount, then the outer cover must be removed. This is apparently to limit the manufacturer's liability. Removing the microwave from the wall is really a two-person job, since it is heavy and awkward. You don't want it to fall or slip, and the edges can be sharp. It helps a lot if you saved the original installation instructions. Once the oven is out of the wall, you can then access the lamp socket. These bulbs are special halogen types that must not be touched by bare hands, since skin oils will shorten their life. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Sep 23, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
