Question about Car Audio & Video
I have a ssv works wp-id5 and the four switchs ie mode volume pause and track most often dont work .what could this be
4 Suggested Answers
  • 3 Answers
SOURCE: volume controls
Just sorted it. The solution is a touch long winded but it worked for me.
Sorry for the delay in replying but i THINK have have the solution which I got of the Saitek forums.
I have had the same problem with VOLUME controls on two MS keyboards and a logitech, this worked a treat.
So what do you need to do?
FIRSTLY check Control Panel->Administative tools->Component services and click "Services (local)", on the RHS look for "HID input service" under STATUS it should say STARTED, if it DOES im not 100% if this will help but try anyway. If it DOESN'T this should work.
Go to START->RUN and type REGEDIT and navigate your way to the following:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HidServ\Parameters
If there is a file called "ServiceDll" delete it (make a copy obviously and stick it on your desktop or something). Right click in the RHS of the page and create a NEW->Expandable String Value.
Call it "ServiceDll" (exactly as typed here without quotes), and make the value read "%SystemRoot%\System32\hidserv.dll" (without quotes). Now exit out of Reg edit and go back to Control Panel->Administative tools->Component services. Next to HID input service right click in the gap under STATUS and press START. Close properly and your volume should now work.
Good luck.
Posted on Dec 25, 2008
SOURCE: 2005 Volvo V50, no radio volume, CD shows pause.
I've got the same problem suddenly this morning...
Posted on Jan 28, 2010
SOURCE: Remote does not work always when using the iphone with Home Ip1
If you press and hold menu for about 10 seconds you will hear a beep, quickly press mute then enter and you will hear 4 beeps. Your remote is now synced
Posted on Oct 05, 2011
Adjust volume on bluetooth mini speaker PSNANO PS-38
Quoted from the instruction manual:
"+/>>'" In TF/Bluetooth mode when short press this button: next song; long press: Volume up. Don't work in AUX mode.
"'<<\-" In TF/Bluetooth mode when short press this button: previous song; long press: Volume down. Don't work in AUX mode.
">''" In TF mode, short press this button: Play/Pause; In Bluetooth mode, short press this button: Play/Pause/Answer/End/Cancel dial/Pair. In Bluetooth mode, double click: Last number redial; long press for 2 seconds: reject calls. In TF/AUX mode, press it will be TF card and AUX exchange.
Aug 04, 2013 | Lands Phones
Bought a cd player keenwood kdc-mp428 need a code.
leave it disconnected from batteries
tell me if it does not help?
Jun 29, 2008 | Kenwood Car Audio & Video
I plug in my kenwood cd player and it says enter code and i dont know it
There are a few types of override procedures for Kenwood.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
"TRACK UP BUTTON" for 3 seconds.. and youre done.
Aug 24, 2009 | Kenwood KDC-BT838U Car CD Player
No sound and cd read Paused
I had the same problem a few times. I found that it went into pause mode when the CD was playing and the volume was turned down to zero. Try turning the volume back up. The CD should exit pause mode.
Aug 06, 2009 | 2005 Volvo XC90
How do i auto switchoff my lenovo y410 laptop
I'm not sure if your referring to sleep mode or not but I hope this helps There are several specialty key functions on the Lenovo Y410...here is a list....good Luck....please rate me ...The Fang
The following describes the features of each function key.
Fn + Esc: Turn on/off the integrated camera.
Fn + F1: Put your computer in sleep mode.
Fn + F2: Turn off the LCD screen (any subsequent operation will turn the LCD screen back on).
Fn + F3: Shift to other connected display devices.
Fn + F4: Switch between wide screen and normal mode.
Fn + F5: Enable/disable the built-in wireless networking feature.
Fn + F6: Enable/disable the bluetooth features.
Fn + F8: Enable/disable the touch pad.
Fn + F9: Enable/pause Media Player playback.
Fn + F10: Stop Media Player playback.
Fn + F11: Skip to the previous track.
Fn + F12: Skip to the next track.
Fn + Insert/NmLk: Enable/disable the Numeric keypad.
Fn + Delete/ScrLk: Enable/disable Scroll Lock.
Fn + Pause/Break: Pause to view the system information during start-up.
Fn + up/down arrow key: Increase/decrease display brightness.
Fn + right/left arrow key: Increase/decrease computer volume.
Feb 19, 2009 | Lenovo 3000 Y410 Notebook
Unlock codes
Good Day,
KENWOOD SECURITY CODE CLEAR procedure
These codes are applicable for all Kenwood radios that do not have DVD or DVD screens located on unit.
Your radio will require one of the following procedures.
Type 1
Type 2
Type 3
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key on the remote
The above was pulled from:
http://forum.ecoustics.com/bbs/messages/4/134366.html
Also try:
press reset use remote right after it loads press 552222777 then track forward do this with the remote open so you can use the numbers and make sure its in the audio mode the little switch on the side. prerty simple p.s. nothing will happen on the screen so dont stop pressing the code and press track forward you can now set the code to what ever 4 dig code you want in the set up screen
Also try: bypasse code of "2222" Hope this helps
Jul 06, 2008 | Kenwood KDC-MP235 CD Player
Locked car sterio
I found this on another site that I used for my kenwood and it worked (mine was type 3):
Type 1
Type 2
Type 3
push buttom "track up" for 3 seconds
Hope this helps.
Jun 07, 2008 | Car Audio & Video
Cd code on radio kenwood
You need the remote control to clear the code, if you don't have one, then you may need to go to a KENWOOD agent, or purchase one for your use.
KENWOOD SECURITY CODE CLEAR procedure Your code number is 5227 (KCAR)
Type 1
Type 2
Type 3
Please rate ne FixYa for this solution. Good Luck :)
Jan 30, 2008 | Kenwood KDC-MP4028 CD Player
Songs that i sync from limewire dont work
What mode do you have your device under? limewire tracks shouldnt say bad tracks because they dont have DRM license install in them...i would recommend to delete evrything from that device and try again....
Jan 02, 2008 | SanDisk Sansa e260 MP3 Player
Need to find out the four digit code
Type 1
Type 2
Type 3
Dec 14, 2007 | Car Audio & Video
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
