Question about Samsung Televison & Video
Am servicing a Samsung flat tv LCD the tv starts out well.and after a short while it starts producing double images even when the menu button is pressed it still has double icons etc
Samsung model is ltf320ap13 I tried changing the fibre connectors resoldered. all open ccts but still in vain
SOURCE: Hidden or Service menu
thank of you but i need access to menu service please help me
please mail key to access to menu service
thanks of you
Posted on Jun 09, 2008
SOURCE: Samsung LCD TV not receiving PC signal
Check your vga cable. Some cables have only 14 pins, some have all 15. The missing pin is pin 9, in the 15 pin cable it carries 5v from the graphics card to the screen. Without that 5v signal most LCD and Plasma television screens won't recognise a PC input. I had the same problem and only managed to fix it when my girlfriend swapped a cable over for me and as she did so glanced inside and said "it's got a bit missing" The cable that came with your PC most likely only has 14 ins as that is all a monitor screen needs.
You can buy a 15 pin cable at most PC or electronic shops, just check that isdoes have all 15 pins befiore you buy it. The cheap ones are just as good as the expensive ones unless you are buying 20 foot cable. For 6 foot cable the cheap ones are just as good as the expensive ones.
Posted on Sep 20, 2008
  • 8 Answers
SOURCE: LN37A550 LCD TV has washed out image
It is possible the problem is caused by a wrong option byte setting in the service menu. The correct setting depends on the type LCD panel used in that version. Version number can be found on a sticker on the right side of the television. A bad main board or TCON board can also cause that type of problem.
Posted on Jan 30, 2009
SOURCE: My desktop HP Director does not want to open
Re-install software
Posted on Jun 21, 2009
  • 102 Answers
SOURCE: Changing Samsung Remote Codes (2 TV's Same Remote Frequency)
There is NO solution to this problem. I'm an electronics engineer. I have three Samsung TV and IR remote extenders. It is a continual problem. If someone told you could "re-program" the Samsung remote, they must have thought you could write assembly level programming code. There is NO incentive for Samsung to modify their highly popular, simple, cheap remote system.
Believe me, I even tried putting polarizing filters over the IR sensors but the ones for cameras do not polarize light at IR frequencies.
Posted on Sep 20, 2009
Samsung 5 Series, 32 inch LCD tv shows double image and picture flickering.
You don't have to take your set to a technician its in the TV settings which you put your self,so use the remote go to TV menu then picture settings you will see that feature then and disable it thanks.
Nov 22, 2016 | Samsung Televison & Video
Double image, how to solve this ?
It has T'Con board. But, it can't be replaced. It is an integral part of the LCD pane; and inside it.
Jul 22, 2015 | Samsung HG32NA470PF 32 LED-LCD TV - HDTV...
How do i get better gaming graphic on samsung lcd tv 32inch
Hmm. What produces the images on the TV?
It's the video card in the computer!
Apr 11, 2014 | Samsung Ln32d403 32 in. LCD TV
Samsung tv displays doubling images
You have a faulty LCD panel, common with older Samsung and Sony sets!
Apr 06, 2014 | Samsung Televison & Video
Samsung lcd tv with double image on screen
T'Con board should be suspected. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Samsung LN46B610 46 HDTVReady LCD TV
My Samsung LN52A650A LCD TV is displaying green shadows and lines after being turned on for 15 minutes. This has been isolated to the display as I get the same result from DVR or DV player.
May not be a do it yourself repair, could be main board or even a loose connection at a plug inside the display panel (fatal) or outside of it.
Oct 15, 2012 | Samsung LN52A650A LCD TV
Can't turn closed caption off on our Samsung Series 7000 LED TV
Make sure it isn't your cable or satellite TV service making the captions, as closed captions on your TV are separate from the ones produced by your service provider. If it isn't your cable/ satellite, open the TV menu and find the Audio/Visual properties section of the menu (audio and visual might be separate sections), and find the closed captions or CC options menu. When you do just change the setting from whatever it is on, to off. If your TV remote is fancier than mine (which it probably is), their could possibly be a closed caption button on the remote for easy access. In this case just push the button and change what you need to.
Jun 07, 2012 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Samsung tv rest code
in order to reset a locked out TV you must contact Samsung technical support, they are the only ones that give you a override code to reset the lock out. the number is listed in your owners manual.
Mar 19, 2010 | Samsung DLP HL-P5663W 56" TV
Red lines and seeing double image
First place to start is with the Main bd. Have a trained Samsung tech troubleshoot the set. Call 1-800-Samsung to set up a service call since your tv is a new model and is under manufacture warranty. Make sure you tell them you want a Samsung Field Engineer to repair your set. They are the most qualified and trained to fix your set.
Jul 08, 2009 | Samsung LN52A850 52 in. LCD HDTV
SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
Feb 22, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Televison & Video Logo
Henry  Thomas
Henry Thomas
