Energy Knight mod.B-HMH24AS BLINKS 5 TIMES
Energy Knight mod.B-HMH24AS BLINKS TIMES LEFT GREEN LIGHT BUT WON'T TURN ON
  • 84 Answers
SOURCE: standby light blinks for 6 times
Did you get this solved yet? Six blinks usuall meand thermal fuse. I can look it up if you still need help.
Posted on Jun 22, 2008
SOURCE: Sony kf-60we610 stand by blinks 5 times
Hey there,
I've had my Sony KF-50WE610 for approx. 4years now and have just experienced the prob you described (though I didn't think to count the number of red blinks). I called Sony TV technical support (888-772-7669, #3 for TV/digital cameras, #1 for TV, then #1 again I think). They said that if the power/standby light blinks 5x, that means there's something wrong with the lamp driver and service will be required. Needless to say, I better go home and count my red blinks! Good luck, I hope this helps a bit. Have a happy and safe holiday!
Posted on Dec 24, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
SOURCE: i turn the tv on the green light blinks 5 times
this isn't a solution, I have the same issue. Mine started doing the 6 red blinks yesterday. How do I fix it? I've changed the bulb before...
Posted on Jun 24, 2010
protvrepair
  • 153 Answers
SOURCE: Heard a pop , bulb blew out , replaced bulb , it
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Posted on Oct 29, 2011
What is the load capacity for a 84 AW white knight tumble drier?
5Kg
White Knight 84AW White Tumble Dryer by White Knight Be the first to review this item
Currently unavailable.
We don't know when or if this item will be back in stock.
  • Construction: Freestanding
  • Control of Drying: Timer Control
  • Display of Remaining Time: No
  • Energy Consumption in kWh at 1400 RPM: 2.5
  • Energy Consumption in kWh at 800 rpm: unknown
  • Energy Efficiency: A
  • Energy Savings Trust Feature: Yes
  • Heating System: Electric (incl. Heat Pump)
  • Height in cm: 85
  • Maximum Loading Capacity in kg: 5
  • Start Delay Option: No
  • Type: Ventilation
  • Type of Loading: Front
  • Width in cm: 59.6
84 aw white knight tumble drier capacity Google Search
Feb 19, 2018 | Dryers
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
Any ideas ?
Remove the power plug and put back after 5 minutes. Go to User manual and check for TV button to restore settings to factory default. If nothing works, you need to go back to service center.
Jun 08, 2013 | Televison & Video
My tv won't turn on when the on button is pushed, but the power light blinks 5 times
5 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Jan 28, 2013 | Panasonic PT-56TW53 56" Rear Projection...
My bpanasonic 48 won't turn on the light blinks
I may if you know what the model number is which is not indicated here.
Jun 14, 2012 | Televison & Video
My sony kds 60a2020 won't come on. When I push the
That is a error code and in several of these sets it means thermal fuse is blown--Google the model number with owner manual or service manual to learn for sure.
Jun 07, 2012 | Sony Televison & Video
My Canon pixma ip 4000 won´t print. The light at the turn on button blinks five times orange and then comes one green blink. I have tried to clean the print head but that didn´t change anything....
this indicates a the print head is not installed correctly or is faulty.
if the green and orange is alternating 5 times then it is caused by the sheet feeder.
Dec 08, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Heating & Cooling Logo
489 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
