Switch wiring portable vapor cooler
Do you have a wire diagram for the switches on a portable swamp cooler?
  • 1,174 Answers
It's impossible to provide info on anything without brand/model info, and you are best asking on a more specific site or the manufacturer's website.
Posted on Aug 12, 2017
    Top Expert:
  • Heating & Co... Master
  • 39,146 Answers
No, Fixya doesn't
SOURCE: head light switch wiring
I hope this diagram works...I'm not great with MS Paint.
Posted on Aug 30, 2008
  • 140 Answers
SOURCE: Electrolux Model E switch wiring diagram
The black wire coming from the power cord connects to one side of the switch and the other black and the red wire go to the other side of the switch. If it turns on with the switch in the off position reverse the sides. Good luck. If you need anymore help just ask. Please rate me so I know if I helped. Thanks.
Posted on Dec 31, 2008
  • 5 Answers
SOURCE: Household wiring
There are 2 3way switches. Usually one end has a wire going to the light, and the other end 3 way switch has the always on power coming in. Between the two switches are 2-wire travellers.
On the actual 3way switches;
2 screws are the same color and the 2-wire travellers go on these. The other screw is a different color -usually black. This screw gets the power on one end, and the switch leg to the light at the other end.
Posted on Mar 14, 2009
  • 82 Answers
SOURCE: 87 regal ignition switch wiring diagram
Thick wires at IGN SW .... Red(s) - supply power from the battery to the IGN switch ... Pink - ignition supply ... Orange - Accessory power ... Purple most RWD sometimes (Yellow most FWD) - Starter .. Did I miss any? It's been a while The thin wires on the IGN swich are for key sense and VATS (if applicable)
Posted on May 08, 2009
  • 174 Answers
SOURCE: need wiring diagram for switch.......
try looking at this site .http://www.toolpartsdirect.com/cgi-bin/partbrands.cgi
Posted on May 31, 2009
Wiring diagram for Dayton IKRT9 portable electric heater
Sounds like it's the on/off switch.
what colour are they. . Usually one is the power supply to the switch and the other will be the return from the switch to the load.
Check these wires with with a multi meter.
Jan 06, 2014 | Kitchen Ranges
Im looking for a fuse box diagram for a 2001 buick lesabre for the rear seat with the vapor line electrical harness attached
The vapor line will never be inclosed inside of the automobile. Electrical lines YES.
In the rear of your auto you have back up lights, tail lights, turn signal lights, LC plate lights. may truck release switch wire, speaker wires, and the emergency fuel shut of switch. If the vehicle is in a front end/back end accident it will tripe the fuel safety switch. It is a red button located in the trunk panels. GB..stewbison
Aug 31, 2011 | Buick LeSabre Cars & Trucks
Swamp cooler fan works good on low but when you turn it to high it goes slower than low is it the switch or motor? is the switch like a riostat which porvides more power and tells the fan to spin faster.
Hi, its possible it could be the motor. You should have a 3 speed motor. The switch should be Hi, Med, Low, cool, same on vent, and pump. If it works good on cool, I would say the riostat switch is the problem not suppying enough voltage to run the fan motor at full speed. They are very easy to change out, just have the new one in front of you. You can go on the Internet and type this in, directions for wiring this and it will show you the diagram. You may want to go up and check the condition of your belt also. Look for cracks, see how loose it is, it should have about 1/2 inch of play when you push down with finger. If not, tighten it by moving the motor bracket. It may be just the belt also. Look at it all. My bet would be the switch. Keep me posted on what you find.
Sincerely,
Shastalaker7
Jun 09, 2010 | Heating & Cooling
I need a wiring diagram for model # CRBIP 97171399
If you have only two wires and two terminals, it doesn't matter which one is which.
The thermostat is a switch. Your black and red wires would be the input and output to that switch. One is always hot, the other is hot only when the thermostat is calling for cooling, that is, when the switch is closed.
May 14, 2010 | Oasis Switch
How could i clean the air cooler, i used have a bad smell when i switch on the cooler fan
What you do is remove the hog hair and replace it. Then clean out the pond. Then remove the blower and take it apart, oil the motor and wash the wheel.
May 04, 2010 | Cfm Kenstar Turbocool Major Portable Swamp...
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
Nov 28, 2009 | Water Heaters
Swamp cooler starts up automatically after power outage
generally ther thermostat is the "brain" of the system, check the wiring diagram (if there is one) or the wiring and see if the on off swtch is inseries or parallell to the thermostat, (should usually be in series if it is I would say that the on off switch is the culprit. you cna verify with an ohmmeter to see if it is staying in the closed position.
Jul 18, 2009 | Heating & Cooling
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
