Question about Brother Sewing Machines
My brother pe770 now is knotting up all the top thread underneath and I have to stop the machine and untangle a mess for 30 minutes. Please help!
  • Brother Master
  • 12,273 Answers
Remove the top thread and rethread with the presser foot RAISED. See if that eliminates the thread (bird) nesting.
Posted on Aug 12, 2017
SOURCE: bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Posted on Feb 08, 2008
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
  • 40 Answers
SOURCE: how do i set the tension on my brother xl-3010
I don't have this machine, but the tension on the bobbin is usually set by the tiny screw on the bobbin case. insert the bobbin into the case so that the thread unrolls counter clockwise. Make sure that there is no lint in the bobbin area.
Posted on Jun 01, 2010
  • 1788 Answers
SOURCE: My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Posted on Jul 27, 2010
SOURCE: Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Posted on Jul 29, 2010
My brother pe770 is allowing bobbin thread to show on top sporadically which makes the stitching look like it is speckled with white. I have adjusted tension..cleaned and changed everything.
Shelia,
when sewing these parts of the design, (small stitches? ) load your bobbin with the same top thread. Just match the top thread color, and done! No more white bobbin thread in the topside of your designs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother PE770 Computerized Sewing Machine
Why is the upper spool of thread not turning, thread is not going thru machine?
The way you are explaining your problem makes me think your. spool is knotted. Check it buy pulling out and unraveling the thread. This may answer your question. GOOD LUCK FRIEND.
Nov 17, 2014 | Brother PE770 Computerized Sewing Machine
50t8 e99670
They say if your bottom thread is messing up, then your top thread isn't threaded correctly.
May 24, 2014 | Singer Sewing Machines
ALWAYS thread collects underneath finished product
have you tried changing the needle?
make sure the thread is on the thread take up lever
is the machine threaded correctly with every thread guide
Mar 08, 2012 | Brother PE770 Computerized Sewing Machine
Discoloration on thread while embroidering
check for burrs around the needle plate areaa & in the bobbin area or any where the thread passes
Brother pe770 bobbin thread is showing on top of fabric.
First check threading. If it is done properly, then it's probably because it is dirty between the lower tension blade and the bobbin case body. Remove this blade, clean, reassemble and it shoud work.
Dec 26, 2011 | Brother PE770 Computerized Sewing Machine
When I thread my machine and start sewing my bobbin thread gets a huge nest underneath and knots underneath my fabric. What am I doing wrong?
It is your top threading, totally rethread, then with presser foot up, pull on top thread, it should feed smoothly, now put the presser foot down, pull thread, it should barely move. This should seat the thread in the tension discs.
Dec 23, 2010 | Brother CS-8072 Computerized Sewing...
My thread keeps getting knotted up underneath. I have followed all the trouble shooting procedures and it still won't work.
Usually it is the top threading, tangled thread or a bent needle that causes that problem. You can call Brother at 1-877-276-8437 and maybe they can suggest something else to try.
Oct 01, 2010 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
62 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
