Does anyone have a wiring diagram for a Tempstar heat pump package unit model PH5036AKB4 and/or where can I get it ?
I am needing the wiring diagram for the Tempstar unit model PH5036AKB4 or can anyone tell me where I can get it at. Thank you
  • 2 more comments
  • sherman north Aug 28, 2017
    Tom, can you give me Tempstar's web address, I'm not having any luck looking, I would appreciate it, needing a wiring diagram for Tempstar model ph5036akb4 , Thank you
  • sherman north Aug 29, 2017
    I'm just wanting it for future reference in case I happen to have some problem with the unit, I would appreciate any help you can give me. Thank you
  • Thomas Woodburn
    Thomas Woodburn Aug 29, 2017
    Icpindexing.toddsit.com>documents is the ph55. Likely very similar, could not find the ph50. As I said it should be on the inside of the door! Best Wishes.
  • Thomas Woodburn
    I googled tempstar packaged unit ph5036 wiring schematic. Tempstar is manufactured by i.c.p., likely find what you need through i.c.p., not good enough to send the link, sorry!!
    Top Expert:
  • Heating & Co... Master
  • 44,949 Answers
Try requesting the diagram directly from Tempstar.
Posted on Aug 12, 2017
Testimonial: "Do u know they're email address for requesting that information, if so, send me the link please, Thank you"
  • 1,919 Answers
Should have a wiring diagram on the inside of the door. Or inside the electrical cover if separate panel. What is the issue, possibly we can point you in the right direction!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Aug 29, 2017
Testimonial: "I have to be a member to log into that web site but thanks anyways."
  • 4 Answers
SOURCE: TempStar 10 AC
visit www.gotempstar.com for the schematic on this unit. Coincidentally, your air handler unit should not draw 15.6 amps with an additional 40 for the heater.
Posted on Mar 26, 2009
  • 116 Answers
SOURCE: Need wiring diagram
check the capicitor if it is domed up on top bad check the wires at the compressor to see if burnt take a insulated object and bump the contactor in to see if comp starts if so then out on low voltage circ check for call from stat on common to yellow then follow the connections may be out on low psi switch located in the suction line
Posted on May 10, 2009
  • 232 Answers
SOURCE: no heat need a wireing diagram 1997 package unit
impossible to get wiring diagram without model or manufacturer
Posted on Nov 21, 2009
shastalaker7
  • 1515 Answers
SOURCE: Armstrong Heat pump Package Unit, Model#1B36DA-9B,
Hi, the outdoor unit will start to freeze when it is cold outside, but also it should go into a defrost mode to melt this ice either by the defrost board or defrost thermostat. You will know as steam will rise like smoke and some folks think it is on fire. If it never goes into defrost, get back to us and we can go through some things to check. Merry Christmas,
Shastalaker7
Posted on Dec 24, 2009
  • 82 Answers
SOURCE: i need a wiring diagram for a tempstar gas pack
Go here - http://www.gotempstar.com/go/index.asp?t=86&s=477
enter PGAA in model box.
Posted on Mar 14, 2010
Need wiring diagram for tempstar pa5524aka4
Request the wiring diagram directly from Tempstar.
Nov 27, 2017 | Heating & Cooling
I need wiring diagram for Tempstar furnace model nhgg100ah3
Dec 31, 2016 | Heating & Cooling
What are color of wires that goes to the temperature line switch that controls the defrost cycle?
PDF]4HP13/14 SPLIT SYSTEM HEAT PUMP - Armstrong Air
www.armstrongair.com/_/.../Armstrong_4HP13L_Install_506318-01.pdf
4HP13/14 SPLIT SYSTEM HEAT PUMP .... indoor unit, outdoor unit contains system refrigerant charge for operation ... may be installed with up to 50 feet of line set (no more than ..... The defrost control incorporates 2 pressure switch .... Note: Sensor resistance decreases as sensed temperature increases. Pins/Wire. Color.Missing: tempstar
[PDF]RESIDENTIAL SPLIT HEAT PUMP SYSTEMS
icpindexing.toddsit.com/documents/086477/42808100101.pdf
This Manual Supports Split Heat Pump Units of The Above Series .... two groups is based on a difference in Defrost controls and/or the .... completes a circuit between µRµ ? µOµ in the the thermostat sub-base. 2. .... before connecting line voltage. ...Wire "S1" is the first stage of electric heat through the outdoor thermostat.
[PDF]Trane Installer's Guide Air Conditioner/Heat Pump 4TTZ0 ...
Jan 18, 2016 | Heating & Cooling
Did anyone fine a wiring diagram for aolder model tempstar electric furnace, it is a 1991 also need sequencer wiring digram, ask this before but got no reply, thanks
Hi Horsman:
I'd try (using Google) to track down a dealer or service shop that is familiar with these units. I'm thinking that your chances of getting that information from them would be a lot better from them than from a "random" connection through FIXYA.
Best of luck.
Oct 18, 2015 | Heating & Cooling
Parts list for Tempstar PGAD60E1K1? Anyone have?
Tempstar will only sell to licensed dealer/contractors. You will have to purchase through your local HVAC contractor that deals Tempstar. They will be able to cross your model # to the correct parts. However, you must have an EPA license to purchase the compressor.
Oct 06, 2009 | Heating & Cooling
I have a tempstar 2000 heat pump approx 5 years old. The condenser fan blades will not rotate/operate; however, I can hear the motor hummming. When the unit is off, I can rotate the fan freely. When the...
I think this is a double problem post,so I will answer the top first.
The fan capacitor may be bad or the motor it's self is seizing up and will need replaced.
Second portion of post:
  1. Brown and brown/white go to the new capacitor(If you didn't get a new one with the motor,You will need to)Should be 7.5 mfd
  2. Black To the contactor where the black was originally connected
  3. yellow to the contactor where the red was originally connected
May 06, 2009 | Heating & Cooling
I Am looking for heil NPA HC36 AKOL air conditioner wire diagram
You will need to contact a Heil distributor to get a wiring diagram. Or you can try a dealer but they probably won't help you fix your own unit. That would be taking money out of their own pockets.
Mar 10, 2009 | Heating & Cooling
Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Sep 26, 2008 | Emerson Heating & Cooling
TempStar 10 AC
Jan 07, 2008 | Dishwashers
Heating & Cooling Logo
521 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
