Question about Amana ABL2222FES Stainless Steel Bottom Freezer Refrigerator
Took apart top load Amana washer to check for a leak, I did tip the washer on its side once. No leak was found, but now it stops during the spin cycle. If no clothes or a small amount of clothes are in it, it will spin and work perfectly. If you open and close the lid it will spin for a few seconds and then stop like it is out of balance, but the clothes are positioned correctly. Any ideas?
watugot
  • 290 Answers
SOURCE: Quick Fix?
The compressor is locking up when it gets hot. We have seen alot of this on the units with Tecumseh compressors. If it is less than 5 yrs old it should still be covered by the sealed system warranty and repaired free of charge.
If it is out of any warranty, there are "fit-all" compressor starters with start capacitors built in them that give it a little extra boost on start-up. They are called 3-in-1 or kickstart starters. This will usually buy you a few months until you can replace fridge.
If it is covered by warranty but will take a few days to get repaired, you can get by ok by unplugging fridge at night and plugging back in in the morning. This is what I tell my customers when I have to order a compressor and so far they have been able to keep from losing food.
Posted on Nov 05, 2007
  • 185 Answers
SOURCE: my amana washer top load
check the motor coupler
Posted on Mar 26, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
philbran
  • 242 Answers
SOURCE: After moving fridge (and waiting 36 hours) compressor won't start
You should worry , the 12 amps is a locked rotor on the compressor , it may be the over load relay control on the compressor as well , try replacing the over load start relay first , they are not expensive , if this does not fix it you can try installing a booster like a rco410 but the comp. can not take that abuse for years from the booster. when the comp. is running normal it will draw roughly 1.5 - 3.0 amps.
Phil
Posted on Apr 11, 2009
SolutionGuy
  • 331 Answers
SOURCE: SQD26VW AMANA STOPS COOLING AT THE TOP,BOTTOM SEEMS TO BE COOLING AND WHEN PROBLE ACUURS THE WATER STOPS
Hi R,
Based on your description, the defrost limit has failed and should be replaced. The job takes about 30 minutes. The part you'll need is a WR50X55. You can find it online by plugging that number into a search engine, or pick one up locally at an appliance parts retailer.
UNPLUG THE FRIDGE BEFORE CONTINUING!!!
Clean out all the stuff in the freezer and remove the shelves. Then remove the panel in the back of the freezer section. You'll see the defrost limit clipped to the evaporator coils at the top right. Remember which tube it's clipped to, then take it off the tube.
Now clip the wires close to the limit and remove the limit. Strip those 2 wires back about 3/8" and connect them to the new limit one wire at a time. Cap these wires off with wire nuts. All you gotta do now is use one of the clips in the kit (I use the "U" shaped one, NOT the "W" shaped one) and clip it to the tube you removed the old one from. Rebuild everything and plug the fridge back in. That's it!
NOTE---> The fan inside the freezer will NOT come on immediately. The derfrost limit you just installed must get below 55 degrees first, then it'll turn the fan on. OK?
If there's anything else I can help you with, please write back. If not, and this has fixed your problem, please rate me.
SG
Posted on Apr 23, 2009
Nav5800aww
The motor sounds like it is overloading and kicking out. Most likely cause: binding brake pads.
Sep 13, 2013 | Amana NAV5800A Top Load Washer
Makes clunking noise when changing modes--does not spin dry
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Amana 3.2 cu. ft. Top-Load Washer
WATER LEAKS DURING SPIN CYCLE .ITHINK I NEED HUB & SEAL;HOW DO I TAKE IT APART. HAVE FRONT PANELS OFF AND TOP RIM BUT CANNOT GET AGITATOR OFF
you nead to replace the idler spring and the drive belt,the idler spring part# 37366,one or two speed washers drive belt part# 40053607,three speed washer drive belt part# 40053606.
Jan 12, 2010 | Amana ALW480DA Top Load Washer
Loud during the spin cycle.
would suspect something in the drain pump rather then something witht he tub, tip unit back and check for debrisin right hand side pump
Mar 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Jul 20, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana ABL2222FES Stainless Steel Bottom Freezer Refrigerator Logo
26 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
