Question about KitchenAid Kitchen Ranges
Oven not heating. I have a KitchenAid Pro Line Dual Fuel Range
Model: KDRP463LSS, Serial No: XP3506943. The gas cook top is functioning normally. The digital oven display is functioning normally, and not displaying any error code. The oven light when set to Automatic comes on and is functioning normally. The oven heating elements do not turn on in any cooking function selected. I reset the circuit breaker, got the normal PF power failure code, but was able to reset the clock display as normal. Still no heat in any cook mode. The failure was first detected while preheating the oven in normal Bake mode when after 30 minutes the oven had started to heat but then suddenly quit. I allowed the oven to cool over night and from this point on the no heat condition persists. I'm extremely handy when it comes to fixing home appliances, but without a service and repair guide I'm not educated enough to proceed any further. Have any of you experienced this malfunction with this model range?
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
duby1990
  • 370 Answers
SOURCE: Power Failure results in no oven or digital display.
The low voltage has ruined the CCU (clock) YOu will need to replace it. You can order the part via model # on sears.com
Posted on Feb 09, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Range RF315PXDW
It sounds like you are missing part of your input voltage.
I would take a voltage reading at the receptacle and confirm you are reading 220-240VAC. Some homes have the 220 service receptacles wired up with two 120 volt breakers to make up your 220 service. If your home is configured this way, you may have one of the breakers tripped. Or, the receptacle itself may be bad. If you confirm you have the correct voltage at the receptacle, your power cord may be bad.
The reason the clock and display will still appear to work is because the clock only uses 110-120VAC and is tapped off the source voltage. The surface burners and the oven heating elements, however, require the full 220 service.
If you are confused by this explanation, please post back and let me know. Hopefully, this is a problem that will not require any parts or a service call. If the power cord is bad, you can purchase a replacement at any hardware store. I hope this information is helpful.
Posted on Dec 19, 2009
Testimonial: "I will definitely check both the 120v wires in receptacle feeding power to the stove. The breaker in the house breaker box is a single 60amp breaker. "
FixinFax
  • 3085 Answers
SOURCE: Range bake,broil,oven warm-up,oven light do not work
Yes the control panel is bad
Posted on Feb 24, 2010
I have a double oven kitchenaid natural gas range model KGRS505X. When I cook in the upper oven nothing I cook will brown. Buiscuits get cooked but are still ehite when done. What is the problem?
The top oven not maintaining heat why plenty of reasons depending on age could be a weak ignitor, bad temp sensor, is the oven light on if so oven stops heating after 30 seconds any oven maintaining set point temp will brown and if left long enough burn
Jan 26, 2015 | KitchenAid Kitchen Ranges
Need part number for BBQ option to replace griddle
You will need the model number & serial number which may be on the back of the cooker on behind the plate under the oven door, then contact the manufacturer or agent. Reece HVAC are also a very good source to obtain parts from.
May 07, 2014 | KitchenAid KDRP463LSS Dual Fuel (Electric...
Electrolux dual fuel oven will not heat after self clean
The unit needs to be reset. The temperature had tripped the internal sensor of the unit. This usually has to be done by a professional since the back panel needs to be taken off and the power reset inside.
Sep 02, 2012 | Electrolux EW30DS65GS Dual Fuel (Electric...
Why does my oven cook so unevenly? In the top area, the back cooks way faster than the front. In the bottom, the right cooks way faster than the left.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 08, 2011 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I'm looking at a KitchenAide KDDT207B duel-fuel used stove to purchase used from a private party I don't know. Are there reliability concerns?
I have this same oven. It began to intermittently fail when using the oven. The error code suggested it was a problem with the keypad. I suspected it was because the electronics was overheating. The electronics for this model is approximately underneath the right front gas top range. What I found was that the failure occured when both the oven and the right front gas range were being used simultaneously. This caused overheating since the electronics has not fan in this model and the heat radiating down from the pan above the gas range is added to the heat coming from the oven below. The electronics is sandwiched between these two heat sources.
Nov 16, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Oven wont turn on.
Ours did that and I installed a new igniter. Took the old one out and went to a store that sells them. Installed it myself.
Sep 29, 2017 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid KDRP463LSS - No electricity to oven
Pull the range, remove the back cover and locate the thermal switch and the oven TOD. Check both parts for continuity. Replace any of them if it's open.
The thermal switch
partimage.aspx?imgid=z3bqljffahrfnza4nzu3os9mufcvc290b2hwdhjhcc8%3d
The oven TOD
partimage.aspx?imgid=z3bqljffahrfmja4mdazoc9mufcvc290b2hwdhjhcc8%3d
- The part number for the thermal switch is AP3799085
- The part number for the oven TOD is AP3086326
Dec 22, 2008 | KitchenAid KDRP463LSS Dual Fuel (Electric...
Dual fuel kitchenaid; burners work, oven does not
I had a similar problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Nov 29, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Switching from gas to oven
Your model stove is dual fuel. Which means that the burners on the top of your stove are run using gas, and the bake and broil (and possibly a warming draw) are run using electricity. So if you are cooking on the top of your range you are using gas, and if you cook in the oven you are using electicity
Nov 03, 2007 | GE J2B915SS Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
83 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
