Question about Microwave Ovens
Why does my. MAgic Che f microwave smoke inside when I cook bacon?
    Prodigy:
    An expert who has answered 500 questions.
  • Microwave Ovens Expert
  • 547 Answers
Although bacon can be cooked in a microwave, cooking any low water content food is ******* an oven, and can shorten the lifespan of the magnetron.
The smoke you're seeing is probably from the grease in the bacon. However, there's a slight chance it's from the power transformer as these sometimes fail slowly. You should be able to tell from the type of odor.
Posted on Aug 12, 2017
    Top Expert:
  • Microwave Ovens Master
  • 39,415 Answers
Your manual should tell you what can and cannot be cooked in a microwave oven.
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Posted on Sep 15, 2006
SOURCE: GE xl1800 spacesaver microwave
It sounds like you could have one or two problems. Using the oven with metal in it could cause the magnatron to go bad at its tip causing it to arc and making a popping sound. It could be that there is bare metal exposed somewhere causing the popping sound. Take it in for service!!
Posted on Feb 24, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: MICROWAVE WON'T HEAT OR COOK
Sorry if you misunderstand, but I offer free advice so you or someone you know can fix things yourself.
Chances are you have a bad magnetron or other high voltage part, but I won't bother you with details now.
You take care of yourself.
Posted on Jul 20, 2008
sclarke7
  • 222 Answers
SOURCE: Microwave still runs but is not cooking food
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
Posted on Sep 10, 2009
SOURCE: Venting of microwave - house stinks of bacon
Interesting post, because I have the same problem! I have spent the better part of today researching and taking our microwave apart (partially) to inspect the top portion re: outside vent. Everytime the microwave is on, the "active vent door" (manufacturer's term, not mine!) opens. Apparently this is normal. But it also opens when you turn on the vent fan, when cooking on the stovetop. I don't like this feature, because I think it 'overrides' the outside venting system. I double checked our outside vent to ensure that when this oven was installed, the person did in fact allow the flap to be open when the fan is on (he did). So I think what 'our' problem is, is that the microwave active vent sort of interferes with the outside vent, thus more of the cooking smell being blown into the house instead of the outdoors. I was thinking of simply disconnecting the gizmo that make the active vent door open each time you use the oven and/or vent fan option however I don't think that's a good idea as apparently the main purpose of the active vent door is to keep the electronics of the microwave oven from overheating. The more I read about this version of microwave, the less impressed I am with it. Lots of electronic issues with it. I am not fussy either with having the microwave over the cooktop. Sorry I don't have a solution for your problem but I do feel your pain!!!
Posted on Apr 11, 2010
Burning smell or smell stuck in the vent?
sweet smell from an electrical appliance is ozone cause fir high voltage discharge ( like the sweet smelling air after a lightning strike
take it in for a proper diagnosis
May 31, 2017 | Microwave Ovens
I was cooking bacon. The microwave sounded to let me know that it was done. When I went in to the kitchen there are no lights on the inside, the clock is dead and none of the buttons work.
The line fuse is probally blown. Remove screws that hold the cabinet, and replace the fuse with the same type and rating. That should get you going again.
Mar 21, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a oster microwave and cannot find how long to cook certain things like bacon.
Thick or medium rashers of bacon in a 750 Watt microowave take about a minute per rasher. If you put the bacon on a glass tray and cover with paper kitchen roll, (NOT RECYCLED AS THAT MAY CONTAIN METALIC TRACES), it stips the spitting and keeps the microwave nice and clean.
Hope that helps.
Nov 14, 2010 | Sunbeam Microwave Ovens
Small amount of white smoke coming out of kenmore convection microwave in oven mode
That is usually caused by a build up of fat from microwave cooking on the heating element. It will clear under normal conditions and return if one cooks foods like bacon etc, un covered to prevent splashing of the food that is being cooked.
Hope that helps.
Oct 31, 2010 | Kenmore 63793 Convection / Microwave Oven
It don't heat anything any more. power is on turns counts food doesn't even get warm. i bought this unit from wal-mart in Joplin Missouri. 4/18/08 Wal-mart will not help me because it out of there 90 day...
one would surely assume that a product would last more than 5 months. of course you know not to put metal in a microwave, so the real question is, have you ever cooked bacon in it? I can assure you that this is a very bad idea, as the grease gets sucked up into the fan and distributed all over the sensitive circuitry inside the unit. mine actually caught on fire while cooking bacon, so now we are back to the skillet. in conclusion, the micron is probaly fried in it and it is not worth fixing. chunk it and get a new one.
Sep 11, 2008 | GE Microwave Ovens
Ge JVM1190 appears to be working but does not cook.
I spoke with a qualified microwave technician who advised me to buy a new microwave as the problem I was having indicated that the magnetron tube had blown. What a waste of time to ask for help from you.
Sep 01, 2008 | GE JVM1190 Microwave Oven
We just bought the microwave 2 days ago. Was cooking bacon & when I went to put more in it won't come on. The light is out & nothing will work. Checked the house fuse & unplugged the microwave...
I would guess that the magnetron overheated since bacon is a low-moisture food.
(Does your manual suggest putting a half-cup of water in the unit when cooking bacon or popcorn?)
If it didn't come back on (even after resetting the unit by unplugging it for a few minutes then trying again) then I would say the magnetron thermal cutout blew.
But since it's under warranty, GE will fix it for you free.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | GE Microwave Ovens
Magic chef over the oven microwave shuts off.
Is not normal for a microwave to shutdown after 4 minutes of operation.
From the info you are providing, It looks like the magnetron might be overheating causing the thermal fuse to shut it down until it cools down. There may also be a loose connection in one of the switches or a cold solder joint in the low voltage power supply.
I would suggest to check and make sure that the fans are functional, If always did; it could be that there isn't much air circulation where the appliance was installed.
Mar 03, 2008 | Microwave Ovens
Micro wave just quit working
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 28, 2007 | Magic Chef MCD1311ST Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
