Question about Epson Office Equipment & Supplies
Epson surecolor 150c error. I replaced every part that goes to the error but it is still popping up.
Error 4d epson wf-2650
i cant find anything on that error. i suspect that the scanner unit is physically broken and it wont move when the printer goes through its startup process.
You can try unplugging it from the wall while it is still turned on
wait 20 minutes or so and then plug it in again
that should reset the entire printer
But if there is something physically broken in there the error will just pop up again.
You would need to have it repaired or replaced frankly its probably cheaper to just buy a new one.
Dec 28, 2016 | Epson Office Equipment & Supplies
Brother dcp-150c unable clean can troubleshoot this problem? plz help me. thanks
To help you troubleshoot the error 'Unable clean 46', please follow the instructions given below:
- Pull out the AC plug.
- Put back the AC plug while holding down the 'Menu' button and keep holding it (15 sec).
- Now you are entering the 'MAINTENANCE' mode and 'Error 46' pops up in the display.
- Select 8 by using the arrow buttons ,push OK and select 0 and push OK.
- 00:00 00:01 OK (the display is showing this message).
- Now push the 'MONO' button 25 times until you see PURGE: xxxxx
- Select 2, push OK, select 7,push OK,select 8,push OK, select 3,push OK.
- The purge counter indicates now: purge: 00000
- Switch OFF the printer and wait for 1 minute and Switch it ON.
- Now try to print.
If issue persists, it is recommended to contact Brother Support Center for further assistance from the link given below:
Jun 08, 2016 | Brother 32 Lc970 Bk/c/m/y Ink Cartridges...
It won't feed any paper when starting to print
check the paper feeding rollers . and clean it using small cloth
Sep 20, 2015 | Epson SureColor P600 Inkjet Printer
BRAND NeW return to place of purchase under warranty is it not
Apr 14, 2015 | Epson Office Equipment & Supplies
Fatal error 1a39
Fatal error 1a39 - The description says:
"Service Call Error
Code: 1A39
Category: Hardware
Error Name: Head Error
• Connection failure of the HEAD FFC.
• Electric parts or components are damaged due to improper HEAD FFC connection such as connecting it at an angle.
• The drive circuit in the PRINT HEAD is damaged.
• The fuse of the MAIN BOARD has blown.
Check Item:
Is the HEAD FFC connected properly without being connected at an angle and any abnormalities such as peeled terminals?
1. Replace the HEAD FFC. (See P.127)
2. Replace the PRINT HEAD. (See P.126)
3. Replace the MAIN BOARD. (See P.111)
As a point of reference, your three manuals are here (link below), which is where I found this info. (See the first manual listed - in the chart on page 53: Table 2-2). Good luck!
Aug 20, 2014 | Epson SureColor T-Series T3000 Inkjet...
This is the counter inside the printer which stops the printer unless it is reset. Follow the below steps to do the reset on your printer.
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer
May 25th, 2011 • Printer
How to Reset Brother DCP 110C, 115C, 120C, 130C, 135C, 145C, 150C, 165C, 185C, DCP 195C Printer:
1. Press the Menu, then Mono Start key then press the UP arrow key 4 times to make the machine enter the maintenance mode and "ERROR 46′ pops-up in the display.
2. Enter maintenance mode 80: Select 8 by pressing the UP/DOWN arrow key and push OK key and select 0 and push OK key
3. Now Press MONO arrow key several times until you see PURGE:XXXXX
4. Select 2 and push OK, Select 7 and push OK, 8 and push OK, select 3 and push OK and the purge counter is now reset to 00000.
5. Press STOP/EXIT key to go to root of maintenance mode
6. Enter code 99 to exit maintenance mode: Select 9 and push OK, Select 9 and push OK.
Jul 24, 2011 | Brother DCP-110C All-In-One InkJet Printer
Error 46
The error 46 indicates that the ink absorber pad is full and needs to be replaced. According to their site here, you will need to have an engineer replace it for you, although I bet you could purchase a new one from their store.
Jul 29, 2010 | Brother Office Equipment & Supplies
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Brother dcp 150c problem
dear sir/maddam
i have printer Brother type DCP 150 C,
Now in the display show ERROR MC 48-49,
we can not sovling this problem,
please advice
Feb 10, 2009 | Brother DCP 115C All-In-One InkJet Printer
Service Call Error 00020003 on Epson 7800
your printer needs to be reset let me no if you dont have the software and i will give you the link
Nov 29, 2008 | Epson Stylus Pro 7800 InkJet Printer
57 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
