Question about Garden
Getting garden mulch and soil to Palm Lake Resort
Our 20 something holly tree is dropping leaves from the top down
Give it a good soak now.
Maintain moist, well-drained soil unless growing a dahoon holly, which thrives in wet conditions. Improve soil drainage and increase fertility by incorporating organic content, such as compost, into the uppermost layers of soil. Irrigate soil when the top layer feels dry to the touch; though these trees tolerate drought, they thrive in consistent moisture.
3 Lay a 2- to 3-inch layer of organic mulch, such as wood chips, on the soil surrounding the holly tree without pressing the mulch against the trunk. Mulch decreases soil pH, keeps weeds at bay and conserves moisture.
care for holly trees Google Search
How to Care for Your Holly Tree
May 12, 2018 | Water Water Heaters
How do I repair a dead patch of grass ?
Rake it clean of thatch.
if you can see dirt, add seed
if you cannot see dirt, stab the area with a spade every 1 to 2 inches. then add seed. just a disperse layer of seed (not a full solid covering of seed)
cover with 1/8 inch of top soil, manure mulch/mushroom mulch or chopped straw
water
let grow (water 2x per day - enough to wet the seeds)
mow ow the first time when more than 4" tall
Aug 05, 2014 | Garden
Spots on tomatoes
If the spots are mostly at the bottom of the tomato, more like one blotch, it is from not having enough lime in your soil. It is called bottom rot.Putting lime in the soil is called sweetening the soil with lime.This is what you need to do for bottom rot. If it is in other places and more than one spot, it could be from insects crawling on and defecating on the tomatoes or maybe a type of fungus or mold. Hope you only need garden lime. It will save your tomatoes from bottom rot since it is early in the year.
May 30, 2013 | Garden
Is compost good for land?
Compost is good for land and can be used to condition soil, to fertilize soil, to add humic acids, or as a soil pesticide. In an ecosystem, it can be used to control erosion, to construct wetlands, to cover landfills, etc.
Jan 30, 2013 | Garden
Want to Kill Clover in Vinca Beds
vinca is pretty hardy..but check the label on weed be gone ..if its not listed i would try putting it on a FEW vinca plants and observe if they survive...you will know in 1-2 days.
May 31, 2009 | Ortho Chickweed Clover Killer Pint
Landscape mulch in the fall problem
The uses of landscape mulch are not limited to weed control. Among the other uses of landscape mulch is as an agent to control erosion. Landscape mulch applied in the fall keeps the severe weather conditions of winter from eroding your soil and robbing it of valuable nutrients. And by insulating the frozen soil from the sun's rays on that odd mild day in the winter, you'll help your plants maintain the protective state of dormancy that they're in. As a bonus, when the landscape mulch decomposes, it will release valuable nutrients into your soil. Landscape mulch also improves moisture-retention in the soil, cutting down on your water bill in the summer.
Aug 27, 2008 | PDP Systems 1.5 Horsepower Electric Wood...
Compost and Mulch Comparison?
Compost should be worked into the soil (eventually, at least) to make it more fertile. Mulch, by contrast, is spread atop the soil, both to protect the soil from the elements and to suppress weeds. While it is true that organic mulches will eventually decompose, thereby themselves becoming compost, their function as long as they serve as mulch is distinct from the function of compost.
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
