Question about Craftsman Garden
How to replace steering gear on Craftsman indy 500 limited edition riding lawnmower
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,020 Answers
Check with SearsPartsDirect they will help
Posted on Feb 08, 2018
  • 86 Answers
SOURCE: won't go into gear
What kind of transmission is it gear or hydro ? What do you mean by not going into gear ?it wont move or you cant put it into the position such as 1,2 or f,r ?
Posted on May 09, 2009
  • 513 Answers
SOURCE: riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Posted on Jun 28, 2009
  • 513 Answers
SOURCE: Steering column
take the side pannels off of dash there are a few bolts & the steering column is held in by a long pin if i can further help e-mail me wade at
  • 43501 Answers
SOURCE: my craftsman riding lawnmower 42"
The first thing to check is the wheels on the back corners of the deck....amke sure that they are set at the same height and that the bearings are not out of the wheel, which would allow the deck to sink lower on one side.
If all of that checks out then you have problems under the deck....
The bearings that hold the blades can wear allowing one of the blades to drop, or one of the blades could be bent which could cause it to cut fix that bearings will have to be replaced or the blades will have to be replaced if bent.....
These would be the causes for your mower to cut unevenly...
Posted on Apr 09, 2011
  • 11 Answers
SOURCE: craftsman model 536270211 13.5 hp ride on lawnmower won't start
check for water and debrie in float bowl and spark at plug
Posted on Jun 07, 2012
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ... > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from
1995 Indy 500 EFI - won't start - Polaris Files > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
Lawnmower tractor turns more to the left then to the rightt
look at the plastic connector where the steering shaft meets the main gear the plastic wears out and the gears jump out of time its a $15 part at sears parts online
May 25, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Transmission will not go into gear once my riding lawnmover has warmed up
I'll assume you have a 5 speed. Check the ground drive belt and replace it if you find it worn as the unit won't move after it warms up. It's slipping after it gets hot, eventually it won't move at all even when cold. Hope this helps. If it's a Hydro drive let me know.
Dec 25, 2017 | Craftsman Garden
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
Have a 05 polaris predator 500, riding and it locked up now can't get out of gear..
i have a 1996 indy 500 trail and it is locked up cant turn the cluch and the rope is jamed. any sugestions
Oct 26, 2010 | Polaris ATV
My steering wheel will not turn towards the right. it sounds like it stripping gears. How do i repair it?
raise the hood and follow the steering wheel shaft down ti the gears. u either have gears stripped or a worn out bushing.get parts and replace or have a lawnmower repair person do it.
May 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Where is the choke located on a craftsman riding lawnmower? 42" deck
the should be a cable near the throttle on the dash by the steering wheel. if not look at the carb there should be a sliding choke on the front of the carb..good luck
Mar 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Sears craftsman lawnmower has steering linkage poping out of socket
It should have a keeper on the top or your linkage is bent, how does it compair to the other side or is this the linkage under the steering wheel?
Oct 22, 2009 | Craftsman Garden
Steering column
Jun 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
26 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
