Question about Kenmore Dryers
My Kenmore 800 series gas dryer makes a very loud screeching sound when I start a drying cycle it can last up to 15 minutes what do I need to do
agitateme
  • 88 Answers
SOURCE: Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Posted on Jan 17, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). Searspartsdirect.com carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, repairclinic.com may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Posted on Aug 17, 2008
huuum
  • 750 Answers
SOURCE: KENMORE DRYER
Hello ENRIGHT11 Welcome to Fixya
My name is Huum,
You said,
DRYER MAKES VERY LOUD NOISE WHEN RUNNING. ALTHOUGH IT HEATS UP AND BEGINS TO DRY, IT STOPS RUNNING COMPLETELY AFTER ABOUT 5 MINUTES. IF YOU WAIT AN HOUR, YOU CAN START IT AGAIN, BUT IT AGAIN SOUNDS VERY LOUD (ALMOST A RATTLING SOUND) AND THEN SHUTS OFF AFTER 5 MINUTES
Faulty Blower Wheel
If you hear a great deal of noise coming from the blower area of the dryer when it is running, then the blower wheel could be defective.
The are many different designs for blower wheels and just as many unique failure modes. Vanes (fins) can break off the wheel and bounce around in the blower breaking more pieces. The blower can break around the coupler with the shaft. This can cause the blower to spin loosely on the shaft. The blower can form cracks which cause it to vibrate, etc.
You should also not be surprised to find foreign debris in the blower. The occasional bird, rodent or squirrel has been known to bypass the out vent cover. If they crawl into the exhaust tube the first thing they come into contact with is the blower wheel.
If the blower wheel is not spinning, or if it is missing vanes, it is not moving air efficiently. As a result, heat is not removed from the heat source and it can trip the high limit switch or blow the thermal cut-off.
Worn Belt
A worn belt can stretch and/or become brittle with age. The belt can then slip on the drum or motor to cause squeaking. If this is the case, the solution is to replace the worn belt.
The belt is not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, worn drum glides or worn drum rollers depending on brand and style.
When replacing the Belt is is a good idea to also change the Drum Support Rollers, Drum Glides, Idler Pulley and Clips. All of these items are economical easily changeable when replacing the belt. The upside is that your dryer will operate like new.
Recent Customer Symptoms:
Dryer makes loud noise when turned on. Dryer works and heats up OK but makes too much noise.
Worn Drum Glides
Some dryer models are equipped with Drum Glides. The front of the dryer rests on these glides. They provide a low friction surface on which the drum spins. After time however, this glides wear down. Much like an automobile brakes, these glides make a load grinding noise when they wear thin. This griding against the drum usually leaves a bare metal stripe that is visible at the point of contact. If the glides are worn, the solution is to replace them.
The drum glides not the only items that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum bearings, a worn belt or worn drum rollers depending on brand and style.
When replacing the Drum Glides it is a good idea to also change the Drum Support Rollers, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new.
Worn Rear Drum Bearing
Some dryer models are equiped with a Rear Drum Bearing. The rear of the drum rests on this bearing. It provides a low friction surface on which the drum spins. After time however, this bearing will wear down. If the bearing is worn, the solution is to replace it.
The rear drum bearing not the only item that can cause squeaking. It can also be caused by a faulty idler pulley, worn drum glides, a worn belt or worn drum rollers depending on brand and style.
When replacing the rear drum bearing it is a good idea to also change the drum glides, drum support rollers, drum belt, idler pulley and clips depending on make and model. All of these items are economical and easily changeable when replacing the rear drum bearing. The upside is that your dryer will operate like new.
Worn Drum Support Rollers
Some dryers such as Whirlpool/Kenmore brands are equipped with Rear Drum Support Rollers. The weight of the dryer drum rests on these rollers. They provide a low friction surface on which the drum spins when in operation. After time however, these rollers wear down. When they wear, often times they begin to elongate and form a non-round 'cam' shape. The result is that when the dryer is turned on it creates a rumble that sounds as though you are trying to dry a pair of tennis shoes. This sound is usually the drum being forced up and down on the non-round wheels. If the rollers are worn, the solution is to replace them.
When replacing the Drum Rollers it is a good idea to also change the Front Drum Glides, Drum Belt, Idler Pulley and Clips. All of these items are economical and easily changeable when replacing the glides. The upside is that your dryer will operate like new. Whirlpool
Kenmore models have a dryer maintenance kit that contains all of these items in a single kit.
Thank You For trusting us with your question
Please remember to leave a
solved rating before you leave!
Posted on Jan 23, 2009
  • 686 Answers
SOURCE: Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Posted on Mar 04, 2009
aasc
  • 1606 Answers
SOURCE: Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Posted on Jul 19, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Kenmore 600 Series Gas Dryer, about 2 years old. Makes a loud scraping or rumbling sound as drum turns, not constant but in a cycle, as if off balance. I checked to be sure it is level. What are the likely...
It is normal for the dryer to make sound due to the high velocity of air moving through the dryer drum and exhaust system.
A clicking noise may be the timer advancing.
Check the load for objects such as coins, nails, etc. Remove promptly from dryer.
It is normal to hear the dryer gas valve or heating element cycle on and off during the drying cycle.
The dryer should be level and installed on a solid floor.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jun 16, 2010 | Kenmore 63942 Dryer
Gas dryer not maintaining heat. The dryer heats at the start (after rest), and maintains the heat for about 15 minutes. After that, the dryer continues to tumble, but the dial (i.e. control timer knob)...
The problem is with the 2 little circular black coils next to the ignitor. They need to energize before the gas valve can open. They tend to get weak over time. I am 100% sure this is your problem. Good luck :)
Jul 14, 2009 | Washing Machines
Loud noise when running
Roper RGV4634KQ1 gas Dryer Starts to dry, turns 2-3 seconds, stops turning and makes loud screeching sound. Turn off to stop noise. Retry same situation.
Apr 16, 2009 | Roper RGX4634KQ Gas Dryer
Kenmore Ultra Care Fabric Series 80 dryer works sometimes
This sounds like the motor is bad. Hope you didn't pay too much for it. ;-)
Apr 01, 2009 | Kenmore 659 Electric Dryer
Long drying times model #11062712100
Try this and let me know what happens.
TIP OF THE DAY
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
:?) DRRXR
Feb 07, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
Nov 11, 2008 | Kenmore 63942 Dryer
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
