Three valve engine ?
Magnet should be able to remover it, industrial type as they are stronger, you can get them from out of a honeywell cat flap. inside the cat collar part, or try a magnetic inspection stick, this should be able to get the spark plug out but you have to be gentle as it wont be a stronger magnet.
SOURCE: Ford spark plug blow out
Do you hear about the spark p lock?This is the best way that you can fix your ford truck,even if you know a little bit about mechanic,you can do it by your self.It is a simple insert that go into of spark plug hole,and once that is in the bottom,just need to hit with a hammer and the problem has been fixed.Call this guy fortune del moral(7202204007)in denver, he can help you better.
SOURCE: spark plug wire diagram for 91 ford f150 302
here is a diagram, if u can't see it go to the link below.
http://autorepair.about.com/library/firing_orders/bl-fo-9225.htm
SOURCE: 2002 ford f150 4.2l wiring diagram
The COIL PACK TOWERS are numbered :
coil----3---4
pack---2---6
plug----1---5
The engine cylinders / spark plugs are numbered :
passenger side , front to rear , 1 , 2 , 3
-----drivers side , front to rear , 4 , 5 , 6
The spark plug firing order is ( 1 -4 - 2 - 5 - 3 - 6 )
