What size sheet of gyprock for small patching jobs?
Can anyone tell me is there a limit on what I can bid on?
Yes, there are limits to what you can bid on when a Bid bond is required. A bond facility's term sheet will outline the single job size and aggregate limits. The single job size limit is self-explanatory and caps the job size of which a bond company will provide support.
The aggregate limit is the total remaining value of contracts on hand at any given point in time. These limits depend on your company's experience completing projects as well as the company's financial strength.
May 04, 2018 | Computers & Internet
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
How can above ground pool be repaired
It sounds like the hole is relatively small. You can make a patch using a piece of sheet metal or a piece of flat aluminum which you can purchase at Lowes or Home Depot in the hardware dept. Use sheet metal if the metal surround is metal. Use aluminum if the surround is aluminum. You can tell which is which by taking a magnet and touching the metal. If the magnet sticks, it's metal not aluminum. Cut the patch using sheet metal shears to a size that is 4 inches by four inches larger than the hole. Then you'll have two inches on each side of the hole. You are going to need to put the patch on the inside of the metal, between the liner and the metal surround. This so the hole edges won't tear the liner. When you cut the patch, round off the edges so there are no sharp edges. Take duct tape and cover the edges of the patch. Place 1/2 the width of the duct tape and apply it to one side of the patch and fold the other half over to the other side. You can cut a round patch, but a square or rectangle patch will be easier. Just cut the corners round. Purchase a small tube of silicone sealant ( when you but the patch material) and apply a bead around the patch edges and in the middle. Then affix the patch over the hole. Wipe off any sealant that ozzed through the patch so it doesn't bond to the liner.
Jun 01, 2014 | Karcher 2500 PSI Pressure Washer
Cannot print from the note pad
You need to make sure your note pad is not too (thick) and also
that it is the correct size of paper and not too small,(tip) sometimes small sheet can be attached to full size sheet to enable printer to print.
Nov 14, 2013 | Intermec PC43t
Whenever a print job is sent to my dell 3100cn laser printer, ?Load tray 1? appears in the small window of the printer. I loaded the tray several times but it doesn?t work. Please guide me through the...
You sent a paper size different of the requested by the printer. Just load the requested size or delete the spool.
Some PDF downloaded from internet has A4 or 8,5x11", maybe is requesting one of this sizes.
If you can not delete this message, delete the spool using the printer manual in the control panel of the printer.
Dec 11, 2010 | Dell 3100cn Laser Printer
My Deskjet 5740 has Resume light blinking, all other lights off. Will not print. Won't let me cancel printer queue. If I push the Resume button, the printer feeds a sheet and halfway through the next...
Sounds like it is expecting a different size paper than you have in it. In the item that you are trying to print confirm the page size. If it is a document that you download or someone sent you it could be in a different page size. To cancel it you will likely have to go into the printer settings and delete it from there then power off the printer and power it back on, this should clear the job. Windows will keep trying to print the job until it is successful or deleted. To see the print jobs double click on the printer icon then just highlight and delete it.
Jan 19, 2010 | HP DeskJet 5740 InkJet Photo Printer
Printed text is very small, not legible and does
Go to to print menu box i.e. press ctrl P. Look for zoom. There you will see "scale to paper size." Here select from the drop down list "no scaling" or "A4" depending your paper size. This shoule correct it.
In case you do not see these on your print menu click "properties" on your printer. In the box that appears look for "scale" and make it 100%. These are the components that control percentage size of original documents printed.
Dec 08, 2009 | HP DeskJet 930c InkJet Printer
Printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Need to stop rust & patch holes/damage
Not sure how you want to go about doing the repair or what tools or resources are at your disposal. You could rivet, braze, or weld stainless sleel, sheet metal into place. You could repair the area/s with regular sheet metal and then coat it with Rihno bed liner or something comparable to it. I've used Rihno, its great. Well let me know if that helps or gives you some other ideas.
May 31, 2009 | 1993 Jeep Wrangler
Paper mismatch paper size to small choose a large size
Deny
Dec 12, 2008 | HP Photosmart 8250 InkJet Printer
23 people viewed this question
k24674
jasbo
jasbo
