Question about Samsung Televison & Video
My 2008 Samsung LCD 55" tv has an intermittent problem where the picture changes to garbled multicolor lines in a grid. It seems to be related to how long the set is turned on. Faulty circuit board?
It runs better from a firestick and the tuner doesn't show at all. Might this be from a faulty main circuit board?
  • 38 Answers
SOURCE: faulty main pcb board , test cycle showing
as the guest above says do not remove the board there is no fault on it 4 sure good luck
Posted on Sep 08, 2007
SOURCE: Samsung LE40R51B no picture but turns on
i have the same problem i was told by a repairman that samsungs are known for bad psu. and that its expensive to repair
Posted on Feb 05, 2008
  • 718 Answers
SOURCE: how hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Posted on Mar 30, 2009
  • 343 Answers
SOURCE: main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
Posted on Jun 02, 2010
Testimonial: "thanks so much for your help"
SOURCE: My Sharp tv has vertical multicolored lines that
my new lc60le820un sharp is doing the same thing after two weeks. i called sharp they want to fix it. i want a new tv. after a few minutes of this i hung up and and called hh greg to replace it with a sony. thanks hh greg the sony is fine
Posted on Jun 14, 2010
Fix vertical lines on plasma tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 28, 2016 | Samsung PN50C450B1DXZA 50-inch Class...
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
Multicolored lines run vertically on the screen. Is it fixable? not sure what happened. Tv was given to me. Can see the picture otherwise.
The tv could have a dead tv LCD screen panel because of it is damages by a person or an object by hitting it.Than the tv it is not worth it or repairable if it is require a new tv LCD screen panel.Will cost the same as a new tv,if tv require a new tv LCD screen panel replacement.The LCD screen panel tv that have multicolored lines run vertically on the LCD screen panel and people given it to u and said not thing.The tv probally have a dead tv LCD screen panel already,Sorry tv like this,it is a garbage tv now,it only can be used as a salvages tv only for it electronic circuitries boards only.
May 08, 2011 | Televison & Video
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Have a Samsung LNS4695 DX LCD about 3 1/2 years old. When powers on will take about 5 secs and then picture but has thin, multicolored vertical lines. After turning off and on a few times, picture is...
yes this is due to bad caps I have replace dozens of caps for samsung tv's you can do it your self or have some body do it for you or ship the power board to me
Sep 04, 2010 | Samsung LN-S4695D 46 in. LCD HDTV
55 inch toshiba led tv audio sometimes gets garbled. must turn set off and on to correct
I have a Samsung 55 inch plasma that has experienced intermitent garbled audio, sometimes very frequent (a couple of minutes between episodes) and long in duration (several minutes). Switching to another channel and back would correct the audio.
I ran the auto program channel function a couple of times and it eliminated the gabled audio problem, except for infrequent (once every hour or two) and very short (a second or two in duration) episodes of gabled audio.
I found a thread on a CNET forum on this subject and it seems that the garbled audio problem affects a number of Samsung flat panel models.
Jan 16, 2010 | Televison & Video
My 3 year old shot water at the screen of my LCD tv. Showed the picture for awhile, then went white, now there are multicolored vertical lines. Will it dry out? How can I repair it?
lines in the screen means the screen itself is bad and would need to be replaced. No other way around it. If your TV is still under warranty you may want to contact Samsung and try to get it replaced thru them but if they see any damage they won't cover it so keep that in mind. Here is there tech support number:
1-800-726-7864 Mon-Sun 9am-9pm
Aug 08, 2009 | Samsung LN32A450 LCD Monitor
Brief Startup Problem
the tv has an intermittent problem in the video circuit and related circuit.it could be some cold solder that needs to be resolder.contact the tech to do the repairs.good luck
Apr 03, 2007 | Toshiba 36A43 36" TV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
