Question about Kenmore Dryers
My Kenmore Elite gas dryer runs but does not heat up.
IFIXALL
  • 868 Answers
SOURCE: Kenmore Elite gas ddryer model 72062--No heat
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Posted on Aug 11, 2008
SOURCE: gas dryer wont heat
You may have a blockage somewhere in your exhaust line. I had to have my professionally cleaned, but it fixed the problem.
Posted on Dec 11, 2008
  • 175 Answers
SOURCE: Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Posted on Jun 09, 2009
  • 97 Answers
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
  • 135 Answers
SOURCE: Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Posted on Aug 27, 2009
Testimonial: "I replaced both works great thanks for the conformation."
Kenmore elite dryer not hearing
Most likely the heating element or wrong voltage if an electric dryer. If it is gas it could be the coils located on the gas valve. The gas valve itself. Or the ignitor.
Mar 06, 2015 | Kenmore Dryers
He3 gas dryer not heating
http://homeguides.sfgate.com/troubleshoot-kenmore-elite-gas-dryer-wont-heat-77443.html
Apr 30, 2014 | Kenmore HE3 Gas Dryer
I have a kenmore elite he4 dryer and it is running but isnt getting hot. Need to know where the fuses are located to check them
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 04, 2010 | Kenmore Elite HE4 Electric Dryer
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
check it out..
thank u..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Kenmore gas dryer model#73022 no heat when running
The first thing is to look at your tech manual and do a continuity test on the thermistor.
Oct 23, 2008 | Kenmore Elite HE4 Electric Dryer
Aug 10, 2008 | Dryers
My kenmore dryer is not heating
ck the igniter if it get hot red.if not .replace it.
Dec 18, 2007 | Kenmore 73952 Gas Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
