Question about Kenmore Microwave Ovens
Where can I buy a new bulb for the Kenmore Elite Microwave Oven model 85513 and what kind of bulb is it? The bulb fits under the microwave oven in order to give light to the bench hot plates
SOURCE: kenmore elite microwave oven displays "Locked" and will not respond
My Kenmore Elite microwave (don't have the model number in front of me) also mysteriously locked its own keypad (we were sitting in an adjacent room, heard a strange beep, and got up to find the LED reading "Locked."). I pressed and held down the Stop/Clear button for ~10 seconds and it returned to normal.
Posted on Dec 17, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Owners manual for Kenmore Elite Microwave Model 66462
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgcaab351.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on Jan 18, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: how to change the bulb in a jes1288sh02 ge microwave oven
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
You can find an exploded view showing the the lamp assembly (location refer# 280) here.
You can order the lamp assembly by entering your full model number here. It is part # WB36X951.
MicrowaveSvc
  • 9047 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
  • 10865 Answers
SOURCE: kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Posted on May 29, 2009
Kenmore Elite microwave model 85513 doesn't heat like it use to only 1/3 power what has to be replaced
An intermittent or failing magnetron could cause the problem. Although extremely rare, an intermittent high voltage rectifier can also cause this.
Oct 16, 2016 | Kenmore Microwave Ovens
Http://tinyurl.com/yzjozk
i think your bulb fused because you change it without unpluging and the current\
directly hit the filament.
you should buy new one and try it again and remenber that you shoul unplug it first.
Dec 28, 2011 | Kenmore 62702 Microwave Oven
I need to buy a new glass turntable for my Kenmore Elite Model #721.66463 microwave. How do I find the part number. There are several turntables available
The correct part # is 3390W1G006.
You can contact Martin Microwave Inc. @ 1-877-894-0035. They carry the tray in stock, but it's not listed on their website (www.microwaveglasstrays.com) .
Nov 09, 2010 | Kenmore 64683 Microwave Oven
Lightbulb in microwave went out . can't find where it goes. we have a kenmore convection oven
In cheaper ovens it is not possible to get to without removing the outer case, so is not recommended by the manufacturer - They want you to buy a new oven because the lamp fails.
On the other hand, if you are meticulous, you can unplug, remove the outer casing and access the bulb, BUT YOU MUST ENSURE ALL SCREWS ARE RETURNED TO ORIGINAL LOCATIONS after repair.
Bulb is likely to be non-standard, but easy to fit.
It is very important that all shielding is replaced exactly as fitted, and the outer case is undamaged and refitted perfectly - or microwave energy is likely to leak at these points.
Feb 09, 2010 | Microwave Ovens
Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Jan 23, 2009 | Danby DMW1153 Microwave Oven
How do i change the light bulb in my Kenmore Elite Microwave
If it is like a microwave I had, you have to take the whole cover off. Just make sure it is unplugged before undoing the screws.
Dec 21, 2008 | Kenmore 63792 Microwave Oven
Kenmore 363.6367 internal light doesn't go on
I had the same problem! I was soooo frustrated! But, when my brother came to town, he took off the grill on the top of the micro hood, took out a few more screws, a plastic screen, another screw in the metal cover for the light and then reached in with his fingers to pull out the light bulb, we replaced it, then re-assembled it. It did take us about 30 minutes to do the job and you will need a phillips screwdriver, and a phillips screwdriver drill bit thing, but we were able to do it. I love having the light in the microhood again.
Dec 09, 2008 | Kenmore 63672 Convection/Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
