Question about Element Televison & Video
Element ELEFT502 TV G1300 Series began to flash a white screen while watching the picture. Soon it went to a completely white screen.
The TV is not responsive to buttons on the set or to the remote control. To turn it off I have to unplug it. When plugged back in it returns to the bright white screen. Is there a board I can replace to fix this problem?
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
SOURCE: lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Posted on Sep 10, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 86 Answers
SOURCE: Samsung DLP tv w/ black picture will not power off.
If you are not able to bring up the TV's onscreen menu as well, it appears you have a problem with the TV's mainboard.  You didn't mention if the TV had any blinking error codes so if there aren't any lights flashing on the front, are there any on the sides or back to indicate the problem?  Not all TV's present error codes, but since the TV is maintaining power, it's worth a shot to look.  You could try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this still doesn't resolve the issue, service would be required so you would want to contact Samsung regardless of your warrant standing for service options.
Posted on Mar 26, 2009
I have a 50" element tv model#eleft502. My screen went black but I can hear sound and if I put a flash light to the screen I can faintly see pictures my one know what the problem is????????
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 26, 2016 | Element Televison & Video
I have a 50" element tv. Model # ELEFT502 The picture went black but sound still works. when u take a flashlight to it u can still see the picture. Easy fix??? Also where/how much would the part be?!
http://electro-medical.blogspot.com/
Jan 11, 2016 | Element Televison & Video
Need a picture of backlight for a element 50"flat screen tv model no ELEFt502
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 23, 2015 | Element Electronics Televison & Video
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
NO PICTURE CAN HEAR SOUND BUT SCREEN BLACK
If the picture faded over time and then went out completely....you have a bad digital main board. Hope this helps.
Jan 01, 2009 | LG 37LC7D 37 in. LCD HDTV
Lost picture on LCD TV
Hi.
Your problem is very lightly to be A faulty invertor pcb.
Relatively easy to replace but you may find it difficult to purchase.
The invertor pcb basically makes high voltage to strike up the tube lights behind the screen.
What make & model is your tv set & what country are you in.
http://dysonmanuals.llc.nu/
Chris..
Dec 30, 2007 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Element Televison & Video Experts
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
