Question about Power Computers & Internet
How do i get my windows vista out of power save mode???
Yellow light on the monitor and the tower, will not let me escape when I push f8
  • 293 Answers
SOURCE: my LCD monitor is going into power saving mode
Your monitor enter to power saving mode to prevent further damaged. It's seems you got a busted backlight inverter... Need to replaced a new one or repaired it...
Posted on Oct 13, 2008
  • 68 Answers
SOURCE: Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to and check the bios, download if there is a bios update for the system.
Posted on Oct 30, 2008
SOURCE: LG LCD monitor goes in power saving mode
press fn + F5 buttons, screen will appear
Posted on Dec 21, 2008
SOURCE: L222WT flatron 21.6 monitor is not working
Power saving is the default the monitor goes into if it doesn't get the correct signal down the cable wires of the computer. There might be three culprits:  (1) the cable between computer and display (most likely), (2) the display itself (unlikely since you see the LG logo) and (3) the graphics card inside your computer.  #1&2 are easy to check by swapping with a friend for troubleshooting. #3 is tricker and more expensive and might require a savvy friend or a computer repair service (between $60 and $100/hour for labor) plus between $40 and $80 on for a new card depending on whether you need a analog or digital one. Don't waste money on super costly cards unless you use your computer for gaming.
Posted on Dec 28, 2008
  • 33 Answers
Posted on May 28, 2009
My 19 " LG Monitor
If you have a problem getting into safe mode using windows Vista or 7, boot up your computer. As soon as it tries to start windows turn off the power. When you try to start it again it should come up with a menu asking if you want to use safe mode or boot normally. Select safe mode.
Dec 14, 2010 | LG Flatron L1750S 17" LCD Monitor
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
Switch on computer tower and screen. Screen brings up LG logo and 'Activating power saving' then the screen shuts down. The tower continues to load Windows etc but I can't see a thing as the screen is...
For that when you power up the computer press F8 key then enter in safe mode then go to start menu->run type in run "chkdsk /r" without "" then restart computer then it fix errors .
If still not able to see windows then again press F8 then enter in enabler vga mode then go to display property and change screen resolution to 1024*768 then apply and ok then check.
If still same then you need windows disk boot computer with that disk.
When you power up the computer press F1 or F2 or "del" key then enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit then it boot with that disk.
Follow the procedure and enter in recovery console then type "chkdsk /r" then it fix errors on harddrive then after completion restart it again boot and this time choose "repair previous windows" then it repairs it then you can use windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 22, 2010 | Computers & Internet
My monitor says going into power save mode and goes off. The computer tower is still powered up and the power light on monitor blinks. when I press the power button on momitor it says monitor working check...
Disable Power Management on Windows 7 or Vista If you are using a desktop computer, chances are that you don’t want the computer to go to sleep automatically. This is even more the case if you are running Windows 7 or Vista in a virtual machine for testing purposes.
Disabling Power Management in Windows 7
Start by clicking on the power icon, and open up the More power options:
sshot-2009-10-21-23-05-42.png Under the “Additional plans” section, select High Performance, then “Change plan settings”:
sshot-2009-10-21-23-06-52.png Then change everything to “Never”, and save the changes:
sshot-2009-10-21-23-07-41.png Disabling Power Management in Vista
Disabling power management is simple and easy. First go to the start menu and click on the Control Panel.
Click on the System and Maintenance link:
vistacontrolpanel%5b1%5d.png Then click on the Power Options link:
poweroptions%5b1%5d.png Then select High Performance:
highperf%5b1%5d.png This will disable the automatic sleep mode, but will still turn off the display. You can click on Change Plan Settings to disable that as well if you want.
Jan 26, 2010 | Hannspree HANNS-G 19" Widescreen Monitor
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Tower went down
Most probably the power supply(SMPS) is out. Change it with one having the same wattage...............sodeep
Jun 08, 2009 | Computers & Internet
KDS product 17s, model 700p. I am getting the follwing message "mode not supported H 82.8khz V77.7hz" whenever I boot the computer. I cannot escape from the message. The computer it is attached to is...
Start in SAFE mode (press F8 wile booting) and choose SAFE mode from the menu to see if it works in Windows DEFAULT setting. Then reboot and reset to 32Bit, and 78Hz max.
My guess is that MSoft pushed a patch or SP to your box and IT replaced the dll your monitor was using.
Good Luck!
Let me know if this fixes it
Mar 26, 2009 | KDS Radius RAD-7c 17" Flat Panel LCD...
LG L1832S Monitor not working
LG monitor shows a green light and then goes in power saving mode and a yellow light appears,
Aug 13, 2008 | LG L1915S 19" LCD Monitor
Compaq FS740
try pressing escape. or press f8 when your computer starts up and then press factory restore
Jun 22, 2008 | Compaq fs740 17" CRT Monitor
Computers & Internet Logo
32 people viewed this question
Top Power Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
