M3--non-vibrato channel weak and distorted. Changed V2 but has no effect. Same for both manuals. vibrato both manuals strongand clean.
2 Suggested Answers
  • 5603 Answers
SOURCE: I have distortion on my
Look at your indicator LED... is it off for the clean? Does it show yellow for drive and red for more?
Depending on if this LED is showing these correctely tells me where to look for problem. If the LED shows these correctely, then problem is with the relays that do the switching or a few transistors that change the gains for the drive and more functions.
Posted on May 04, 2011
Testimonial: "thank you I don't how to deal with the problem myself but it could give a clue to a qualified engineer"
I just purchased the behringer djx 700, and the channel 2,3,4 are all distorted when i play music. Even when i listen to it through headphones you can still hear the heavy distortion. What can i do to...
You are probably overdriving the inputs. You haven't told us the source of the inputs and we can't guess where they may come from. You need to read the manual and make sure your source outputs are within range of what this unit requires.
Jul 17, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
When i plug an MXR micro amp (volume boost) in front of the supersonic, it works on the clean channel but does not affect the burn channel, Why? By the way, when plug in to the effect loop it does work...
DO NOT USE a guitar pedal in effects loop as it has the WRONG signal levels.
Also, when you boost the gain preceeding a distortion setting in an amp, the amp will just limit out and it will appear that the effects in the amp aren't working... but what is happening is you wind up with too much input signal and the "flat topping" distortion occurs right at the inout of the amp so no further can occur when you select a distortion in the amp.
Jun 22, 2011 | Fender SuperSonic 22 22W 1x12 Tube Guitar...
If the master output lights go above green (into yellow) the sound becomes slightly distorted even at low speaker levels. i have cleaned the output jacks but it is still distorted
Does the distortion ALSO appear when you listen with headphones? If not, the problem may be downstream. The driver for the mute control line to the mute transistors may have a problem. Make sure the mute is off.
Nov 02, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Vibrato will not go slower than 4 on the speed knob,70's bandmast
The schematic for the Bandmaster does NOT show anything regarding "vibrato"... they DO have "chorus".
Chorus normally involves higher rate vibrato and it is possible they don't have the control scaled very user friendly and not all of the rotation of the control is effective.
Finding the exact schematic is important to analyzing the problem. and while I can find a "Fender Bandmaster" schematic I have a feeling it is not the right one. You might post an exact model number.
Dec 03, 2009 | Fender Hot Rod Deluxe Guitar Combo...
I've got flashing lights on my digitech pds 1550 distortion pedal, guitar is clean only, no matter which channel I use
the flashing led indicates the effect is in bypass. the led lights solid when the effect is on. i suggest looking for a defective bypass switch or broken wire on the bypass switch.
Aug 06, 2009 | Alert Audio Players & Recorders
My over the air channel list program times are 1 hour behind.
I've just sorted the problem on my set , Samsung UE40S6300UXXU, L.E.D.
Enter, "menu"/system//time/clock/......make sure "clock mode" is set to "Auto" and scroll down to "Time Zone" make sure time zone is set to manual, go down to "GMT" and set it to GMT+1 and the job is done. Hope this helps
Mar 14, 2009 | Samsung LN46A630 LCD TV
Weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
Jan 18, 2009 | Intertherm P3RA-048K Air Conditioner
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Midi playing is
This is specific to AcidPro.
If you doubt, check the same at your friends PC/Laptop.
You will then be sure what i told.
May 23, 2008 | Computers & Internet
Rotel RX802 amp
I don't have a lot to go on here, but the amp should be repairable without too much expense. What specifically are the symptoms? Is it just that one channel is out or is that channel weak or distorted? I assume that you have checked for speaker fuses. Update this with a few more details, and I should be able to give you specifics.
Dan
Apr 03, 2008 | Audio Players & Recorders
32 people viewed this question
 Grubhead
Grubhead
