Question about Vizio Televison & Video
My 47" Vizio TV went out during a lightening storm. The only thing it will do is show the Vizio symbol when it is turned on. Nothing else can be seen. I can NOT even turn it off with the power button
SOURCE: my Visco 32in lcdtv turns on but there is no picture or sound
Have you turned the screen on?
Posted on Apr 03, 2009
  • 10 Answers
SOURCE: Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
Posted on May 23, 2009
  • 308 Answers
SOURCE: 47" vizio died
Very high failure rate on this brand. Even after repair, something else will fail. Cut your losses and buy a brand name set.
Posted on Mar 25, 2010
cschindle725
  • 67 Answers
SOURCE: During a thunder storm, our power went out. When ...
blown fuse
Posted on May 22, 2010
  • 1684 Answers
SOURCE: hit by lightening need to replace fuse/vizio tv 47
The small ceramic fuses used in these units are available here:
http://www.ccl-la.com/catalog/index.php?cPath=39_114
Posted on Mar 28, 2013
My HDTV went out in a lightening storm. What could it be?
Is your TV plugged into a surge protector? If not it very well may have gotten a power surge during the lightening storm that fried components in the TV.
Or is the TV connected to a cable box? It could be that the cable box took the hit if it's not plugged into a surge protector.
Or a possibility of both.
Aug 03, 2015 | Proscan Televison & Video
What might be the problem on my Vizio XVT373SV HDTV that will not turn off and on properly?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 29, 2015 | Vizio XVT373SV 37" 1080p 120Hz Edge Lit...
TV Will not power on
HAVE YOU CHECKED PLUG AND INTERNAL FUSES
May 28, 2015 | Televison & Video
My ill dads Vizio VO320E showed classic symptoms of lightening damage so we purchased a new main board. Now the screen lights up but is showing pink and yellow horizontal stripes and some vertical sha
Mr. John either one of two things from start u have done right this is a common thing on flat sets hooked to Direct boxes by HDMI having surges come from box to set. The main board usually needs replacing, so either u received a bad board or u have multiple issues and possibly the T-CON board got surged from main board. This board is located above main and power in center at very top of screen. This will cause symptom that u are describing. Hope this helps.
Dec 08, 2014 | Vizio VO320E LCD TV
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
Mar 29, 2014 | Vizio E472VL 47 LCD HDTV - 1080p, 1920 x...
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
47" vizio died
Mar 25, 2010 | Vizio SV470XVT 47 in. LCD TV
Power went out during electrical storm. tv never
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
RCA 27v520t will not turn on
That's because somehow the lightening caused a fault in the power board.
Ypu can try an unplug for 2 hrs and then reconnect and start again If that dosn't work you will require intevention to replace the power supply
Aug 17, 2009 | RCA 35V432T 35" TV
Lightening?
it is possible to fix it. There may be some burnt fuses and a couple of resistors. But it can be fixed in my opinion.
Aug 19, 2008 | Panasonic PV-DF2735 27 in. TV/VCR/DVD...
Televison & Video Logo
22 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
