Question about Samsung Televison & Video
Have a samsung 42inch TV sometimes the picture goes off but sound stays on can happen after days or even weeks, regards John
Shuttle83
  • 1139 Answers
SOURCE: LCD LG 37" BLINKS 3 TIEMS AND GOES OFF
The overcurrent circuit is working as it should. You will have to have this set serviced by a qualified techniciam.
Posted on Sep 09, 2007
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
romsky79
  • 822 Answers
SOURCE: I have a 32
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. romsky79@yahoo.com
Posted on May 28, 2009
SOURCE: Samsung LCD TV, no picture only sound
My Samsung LNT4669F has two problems..the first is that it takes about 3 minutes to turn on. The red light at TV bases flickers on and off but the sound is there back and forth..Finally, the wite light at base turns on and the TV makes a noise as if it just got turned on and it stays on..why does it take so long?
Secondly, sometimes, the HD channels flicker so badly that I cannot even watch TV..so badly that sometimes the picture is blank..however, the regular channels are fine..Can you help?
Posted on Mar 08, 2010
  • 16 Answers
SOURCE: TV Turns on picture comes on for 30 seconds then
This is not the fix for this TV. I guarantee that none of the capacitors exhibit the common bulging characteristics of a faulty capacitor. The common answers to everyone's questions are to replace the capacitors. Most likely the culprit is the inverter board.
Posted on Mar 23, 2010
Sound no picture
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
Apr 05, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
I believe I may have blown a fuse on the tv. I live in germany and plugged it in along with my x box. It made a loud pop sound and now it will not turn on. But there is no smell of fried electronics on the...
If your tv is brand new and you owned it less than a week I suggest that you should return it to the store where you bought your tv and to be sure not to void the warranty and to save you from stress good day and best regards.
Aug 18, 2011 | Televison & Video
Sometimes Loses Sound
disconnect the hdmi cable from both ends it resets the sound signal!!!
May 06, 2010 | Samsung HP-T4254 42 in. Plasma Television
Samsung Plasma (HPN4239) when viewing TV something like a black film covers the screen - there is still sound but cannot see picture. Turning off the tv for 10-20 minutes restores the picture. Sometime...
Sounds like the X-Main bd has a problem. It provides the illumination drive signal to the Panel. It can also be the Main bd. Have a trained Samsung tech troubleshoot the set.
Jul 05, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Hi all i have a samsung 42inch plasma and i have sound , no pic ?
Your info doesn't indicate if you have a good onscreen display or not. If you do the problem is highly likely to be on the IO board on the rear patch panel of the tv. Replace this board and it should take care of the problem.
If you don't have a good on screen display the two common problems are either on the power supply module or the digital control module. Samsung is known to have problems on both these modules and an electronics technician should be able to remove these modules to inspect for cracked solder joints, or out of tolerance electrolytic filters.
If these conditions do not exist on either board then the power supply board should be replaced first before replacing the digital control board. Search for a vendor that will offer you a full refund will a small restocking fee if the board does not take care of the problem.
Apr 28, 2009 | Televison & Video
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
